Best Suspension Options for Towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trstno1, Feb 13, 2021.
  1. Feb 13, 2021 at 1:23 PM
    Trstno1
    Trstno1 [OP] New Member
    Brent
    2014 silver 4dr. Short bed Tacoma sport
    Hey guys -
    I have a 2014 Tacoma Sport. I recently purchased a 22ft. trailer for 2 Polaris RS1's. The trailer is about 1050Lbs and the machines together with full fluids are about 3000Lbs for a total of a 4050Lbs load. The truck is rated for up to 6500Lbs. Its definitely a fairly heavy load for the truck, but I still get to where I'm going, albeit a little slower. The only thing I don't like is how much the rear of the truck sags with the trailer hooked up.
    I've done a lot of research on the internet and have come up with a couple possible solutions:
    1. Icon 1.5" progressive add a leaf w/ Biltein 5100 shocks in the front and back. $600
    or
    2. Blue or Black SumoSprings - $220 -$240
    What's the better bet here? The truck has 40k miles on the clock. And after spending the coin on the trailer and machines the best bang for the buck would be great. Eventually I'll be purchasing a larger truck to tow with, but I want to wait to see what the 2022 Tundra's are all about first. What's everyone's thoughts?
    Thanks in advance.
  2. Feb 13, 2021 at 2:22 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Of the two choices you provide I would pick the sumo springs. The aal's will lift the vehicle when you're unloaded giving you lots of rake and aren't exactly designed for what you want. They will probably wear out prematurely if you are going to be towing a lot and eventually sag as much as stock suspension. The sumo springs to my knowledge won't lift but prevent sag. More better in this application imo. But the ultimate choice I would pick would be airbags. Lots of adjustability and made for towing.
  3. Feb 13, 2021 at 2:38 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I’d take a look at the Firestone ride right airbags. I have these with daystar cradles and it’s great when towing and/or completely bogging down the bed. Cradles if you’re ever off-road. If I recall correctly you’ll be in the sumo springs price range.
    Accipiter13 likes this.
  4. Feb 14, 2021 at 8:50 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    If you go with SumoSprings go blue. The blue ones will work fine because your towing not carring the load and want to keep your ride quality when not towing. The black ones are more dense and would be overkill since you're not carrying the load in the bed of your truck and will create a firmer ride when empty or not towing.
    Here's a link to Q&A's that helped with my decision.
    https://www.supersprings.com/which-density-is-right-for-you/
  5. Feb 14, 2021 at 11:22 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    My 5x10' utility trailer with golf cart is about 1200 lbs, tongue weight about 250 lbs. I have Air Lift air bags and 25psi levels the truck (stock springs). On the truck now for 6 years and still going strong. Lifetime warranty.
    Unless you off road and chassis articulation is an issue, Daystar cradles aren't necessary (IMO).
  6. Feb 14, 2021 at 12:20 PM
    nsargeant
    nsargeant Member
    09 Tacoma TRD Sport
    I have the blue sumo springs. They really limit the squat from heavy tongue weights and I haven't really noticed any change in ride quality when not towing
  7. Feb 14, 2021 at 1:08 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Airbags, as mentioned above.
  8. Feb 14, 2021 at 8:35 PM
    shift957
    shift957 Well-Known Member
    Cacapon River, WV
    11 AC OR
    Another vote air bags. Can be adjusted for different weight loads and keeps your same ride quality when not towing.
  9. Feb 14, 2021 at 8:48 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I say sumo springs.
    I had firestone airbags for about 3 yrs and it got to be a hassle with the constant leaks I was having. It would be every year I would need to make a warranty claim with firestone on a leaking bag. I don't know if was the type of bag (cylindrical shape with vertical walls vs donut with round walls) causing pinching, or the fact that I was a high mileage, high off road, heavy hauling, heaving towing use case b/c of work (crop advisor) that causes excessive wear on the bags, but I got sick of the down time the firestone bags were causing on my truck.
    Airbags also limit suspension travel much more than sumo springs
    I really like the zero maintenance aspect of Sumo springs. You don't have to maintain a min 10 psi in the bags.
  10. Feb 14, 2021 at 9:42 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Can you run a weight distribution hitch? That's the better solution since it transfers weight off the rear axle. Search YouTube for airbags vs weight distribution and there is a pretty good video that covers this.
    You'll need to account for the weight shift and make sure that you don't exceed your trailer axle's load rating.
    Also, make sure you have the correct tongue weight on the trailer, to far back and it'll cause sway.
    I towed our travel trailer (24ft and 5,500lbs loaded) for a year on stock suspension using a weight distribution hitch.
