Best surface prep to paint over chrome? Also, applying bedliner
Discussion in '1st Gen. Tacomas (1995-2004)' started by Colchicine, Oct 18, 2018.
  1. Oct 18, 2018 at 7:03 AM
    Colchicine
    Colchicine [OP] Well-Known Member
    Newport News, Virginia
    | 2000 | 2.7L | 4x4 | Auto | Standard cab |
    I've got chrome rear bumper on my 2000 that is showing some rust. I would like to cover the outside of the bumper with bedliner. Since the surface doesn't have to be very smooth, I plan to use some coarse sandpaper on it, but not necessarily taking it down to bare metal.
    1. I seem to remember other discussions talking about using an etching primer on chrome. Since bedliner isn't really a paint, can it be applied over primer?
    2. Also, in my one experience with applying bedliner I was not happy with the irregular pattern I got using a foam roller. Since I don't have the ability to spray the bedliner, it will need to be brushed/rolled on. I was thinking instead of using a stencilling method, where I have a foam sponge that I apply the bedliner with a dabbing motion. It seems like I'd get more control over the distribution of the lumps. Thoughts?
  2. Oct 18, 2018 at 11:02 AM
    skedrc
    skedrc Well-Known Member
    Preston
    Elko
    2005 MT 4wd
    I painted my rear bumper on my 96' (I believe its the same exact bumper?) and I just used a electric sander with some 200 grit if I remember correctly. You dont want to use a wire brush or super low grit sandpaper because it will leave gouges, unless you do a higher grit sandpaper later. When painting do several coats, I believe I did around 5.
  3. Oct 18, 2018 at 3:44 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Plastidip
  4. Oct 18, 2018 at 3:58 PM
    Indy
    Indy Master of all I survey.
    Op has a rusty bumper and he's going to put bedliner on it. Gouges aren't much much of concern. Once you decide to skydive without a parachute the color of your socks shouldn't be an issue :)
  5. Oct 18, 2018 at 3:59 PM
    Indy
    Personally I'd dip it as well. Prep consists of washing it real quick and letting it dry.
  6. Oct 18, 2018 at 4:44 PM
    pairodice
    Jay
    SF NM
    Mine was rusty and dented, plasti dip worked awesome and easy to prep. I did bedliner on my old tacoma, sanding and prep took a few hours. It looked nice when it was new but faded badly after about 3 months. I wouldn't use herculiner
  7. Oct 18, 2018 at 8:44 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    It's very hard to get paint or anything else to stick to chrome. It may stick for a while but it will probably/eventually fall off. I'd suggest really sanding the shit out of it but using too coarse of a paper will leave sanding scratches showing through the paint. The only sealer/primer that I can think of that ,might stay stuck forever would be PPG's DP-40 and that requires a professional to apply. As in spray gun, respirator and know how. You can paint over the DP-40 for up to 7 days unless the surface gets contaminated. The other reason to have a shop to apply it in. Doubtful anything else will stay stuck to chrome forever and even DP-40 might not. Unless there is a newer product on the market I don't know about. Which is VERY possible. For prepping chrome for paint.
