best subwoofer between 50-80w RMS?
Discussion in 'Audio & Video' started by EricU, Aug 13, 2015.
  1. Aug 13, 2015 at 4:49 PM
    EricU
    EricU [OP] Well-Known Member
    Englewood, CO
    possibly a post better suited for a true audio forum but i know theres a few audiophiles on here.
    im the never ending cycle of changing stereo systems im now changing gears to the sony headunit MEX-XB100BT, 40wRMS X 4, or 40w X 2 and 70w X 1 to a sub channel using the rear speaker channels. so now im on the hunt for a sub that preforms decently and is very efficient and can do well at 70w RMS.
    I was looking at a few Dayton 6 1/2" and 8" woofers which seem to be a nice option for about $50 bucks. I can build a decent size box if needed but the smaller the box the better for me. likely build a ported box in the traditional sense, unless a certrain speaker preforms exceptionally well in a 1/4 wave t-line box.
    any suggestions?
    not looking for crazy bass, just filling the lows from 120hz on down.
  2. Aug 13, 2015 at 6:59 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    You sure you can bridge those rear channels? 99.999% of headunits will shit brix if you try and bridge channels on them.
  3. Aug 13, 2015 at 9:59 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    A headunit powered sub?? :confused:
  4. Aug 14, 2015 at 5:05 AM
    ike3000
    ike3000 Well-Known Member
    surprisingly this head unit is designed to bridge the rear channels to power a sub. i've never seen that concept before.
    i would definitely go ported to boost efficiency and try to find something with high sensitivity.
    this dayton gets decent reviews and high 80s sensitivity: http://www.parts-express.com/dayton-audio-dcs165-4-6-1-2-classic-subwoofer-4-ohm--295-198
    the only downside with any vented enclosure is that you need some type of subsonic filter to prevent over-excursion below the tuning frequency. it doesn't appear this HU provides such a function.
  5. Aug 14, 2015 at 9:23 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    WITH A WAPPING 70Wrms from a deck which in real world would translate to much less power i highly doubt he would be in need of a SS filter.
  6. Aug 14, 2015 at 4:21 PM
    EricU
    Englewood, CO
    Yeah, thats what my friend at work and i talked about today.
    Also talked about doing 6x9 subwoofers in the rear speaker location if theres enough room for a box behind the panel. but i think they require more power than whats provided
  7. Aug 26, 2015 at 7:57 PM
    Minnetacoma
    Minnetacoma Well-Known Member
    Elliott
    Minnesota
    96 tacoma sr5 with oe sunroof
    3.5 fabtech suspension lift with dirt logic shocks, Wheelers Alcon 8 pack rear leafs with extended brake line All pro rock sliders Cbi DIY front bumper with m8000 winch Cbi bushmaster 1.0 non swing arm 33x10.5 BFG mud terrains Skid row front skid plate Trs headlight retro fit fxr 2.5in projectors with rbg halos Audio/electrical upgrades K2 73ah lithium battery Big 4 upgrade 300a Ohio generator alt Alpine type r 6.5 coaxials in front Alpine type s 6.5 coaxials in back Alpine double din touchscreen Digital designs z3 15” subwoofer Digital designs m4 amp Alpine ktp 445u behind the dash amp for speakers 152db
    Lol cracked me up too
  8. Aug 26, 2015 at 7:58 PM
    Minnetacoma
    Elliott
    Minnesota
    That headunit does 40 watts peak not rms... Your rms will be about 17-18 per speaker... Silly
  9. Aug 26, 2015 at 8:02 PM
    Minnetacoma
    Elliott
    Minnesota
    Best advice is no longer be that guys friend he's an idiot... Lol without a proper amp your sub will be seeing frequencies it is not designed to play... A sub is designed for lows... and that headunit will be trying to play the entire bandwidth lol
  10. Sep 1, 2015 at 3:59 PM
    sqa4life
    sqa4life Well-Known Member
    2017 SR5 4x4 DCLB MGM
    Why not just add a powered sub for under 150 bucks, if you're not expecting crazy bass?
  11. Sep 1, 2015 at 4:49 PM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
  12. Sep 1, 2015 at 6:29 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    whether you can or not bridge channels on a head unit to power a sub, a minimum should be 200 watts. personally, I have to have at least 500, and with my setup, I am running 1200(zed minotaur) with my 2 sundown audio sd3 10s. they are probably only seeing 500-800ish, but best to have headroom.
  13. Sep 1, 2015 at 8:42 PM
    Justinlhc
