Best (steel) front bumper?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Jan 30, 2022.
  1. Jan 30, 2022 at 10:05 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Coastal extreme clearance and Warfab both seem very high clearance, and at the top of the list for that reason.
    With ARB being at the bottom of the list for the same reason; poor clearance due to the front of it jutting out extremely far, creating a bad approach angle.
    Full hoops seems like a good idea for many reasons. A small reason being an attachment point for things like limb risers, to the hoops.
    But bigger reason being full protection coverage in the front, even if from hitting a deer.
    (helps protect radiator, grill, headlights, etc.)
    There's not many other bumpers out there that boast all of that (hoops, clearance). Only other one I can think of that does is ATH Fab.
    Rest of them don't have hoops at all.
    How would you narrow it down to picking 1/finally decide?
    I just noticed the ATH Fab one pictured above is for post-facelift, which is probably what kind of Taco the owner had/has and first built it for. IDK if they have a pre-facelift version, or if this makes it simply a good idea to switch over to post-facelift parts, whatever is needed to make that conversion above the bumper, including lights and grill.
    Here's the Coastal, you can see just how much it tucks in with their lower skidplate
    Here is the new warfab with single hoop. One thing I just realized is it may even be lighter in weight than other bumpers, to avoid making your mpg THAT bad. Because less metal is used, and tubing is used, which may reduce weight by having hollow/empty space inside the tube.
    Lead time may not be too big of a factor because if you really want something then it's probably worth the wait. May be worth nothing that different shops have different lead times or things in stock.
    One cool part about having any tubes, is it can match the rest of your truck. Like if your sliders are tubes and you have any tubing in the rear bumper, a front that way will keep it looking the same. Vs. rear + side tubes than nothing but squares blocks and rectangles up front...
    I don't know if there's downsides to full hoops. Like if it makes working on the truck harder or removing the headlights. Would suck if you have to remove the bumper if you need to replace a headlight!
    Recovery points are recessed on the Warfab for clearance but not on the ATH.
    IDK if the Coastal even has any, or if they can be added.
    I also don't now how would one mount lights (such as fog) onto the Warfab but when there's a will there's a way.
  2. Jan 31, 2022 at 11:31 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Have you considered a C4 Hybrid?
  3. Jan 31, 2022 at 12:40 PM
    DEDAFLO670
    DEDAFLO670 Well-Known Member
    Manuel
    Waipio
    15 Trd sport
    Bay Area off-road (BAMF) build solid bumpers
    _Rhoades likes this.
  4. Jan 31, 2022 at 12:46 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I'm not sure if you're talking about the regular War Fab bumper or their frame chop version but I'm pretty sure they only sell the frame chop as a kit and don't sell a bumper for it. You have to make your own. The frame chop kit has what you need to relocate your cross member and a winch plate to start a bumper build around.
    The regular warfab bumpers bolt right up. I just assumed you were talking about the frame chop version since you mentioned the extreme clearance coastal bumper which also requires cross member relocation
  5. Jan 31, 2022 at 12:49 PM
    TegoTaco
    Ontario, Canada
    108B70AC-592E-48D1-B866-277C12E1BBD2.jpg E516E8AE-3040-41F2-8448-712391885A64.jpg 463AECB1-C79B-4DE9-9AA2-51169D9BFBA5.jpg 97B15C45-B092-4193-8A8F-1EB86CDEEBB2.jpg B34567B3-E265-4C3F-AA02-E16706E59C18.jpg 854359B8-D9ED-493D-9BB7-06088F39893B.jpg 27C7FC57-AF75-456A-A437-562CC2F73CEA.jpg FD62BD80-492B-48F5-8853-2CB621CADCF2.jpg C798E9FB-FC29-414A-8584-C6D80E7C7830.jpg
    Torspd likes this.
  6. Jan 31, 2022 at 1:29 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I don't really care for the first one or the last one in the first post, but I do like the middle one. Never really cared for the tube look under the headlights. JMHO
  7. Jan 31, 2022 at 2:26 PM
    Family1st
    Family1st Thneeds?
    Upstate New York
    2010 DCSB 4x4 auto SR5 52,000 miles
    -All Pro dual swingout rear -AllPro Front Bumper -Lear topper -Prinsu CabRack w/Cali-raised lightbar -Rhino Rack Pioneer Rack for topper(sold) Rhino Rack tracks and Aero bars for topper -AluCab 270 Shadow awning -Roofnest Condor XL -Weathertech fronts/rears -ARB series II 50qt -Total Chaos bed supports -5 SCS RAY10’s Dark Matte Bronze w/285 75 16 Atturo M/T -FOX Performance Elite front coilovers with ICON tubular UCA -FOX Performance Elite rears riding on RXT (option 3) -Brand New Frame (dealer installed) -IN THE MARKET FOR Sliders, fridge slide, Considering decked system (in desperate need to organize), Electronics control center, as the list gets shorter it keeps getting longer.
    I’m struggling with a front bumper choice at the moment. Trying to save weight where i can, but not sold on the tubes under the light look, especially cause i can’t really afford to spend $1,000’s on lights to fill the void. How about tube function? Are 1.75” tubes strong enough to bounce off a rock or obstacle, without pushing into the fender? Or are the corners vulnerable to damage? I’ve got to make a decision soon with lead times being what they are, it will soon be 20 weeks + for some.
    Grey 2015 likes this.
  8. Jan 31, 2022 at 3:10 PM
    TegoTaco
    Ontario, Canada
    I waited 6 months for mine was originally told 8-12 weeks.
  9. Jan 31, 2022 at 7:14 PM
    TacoTuesday1
    FL
    i mean for what it’s worth WarFab rear bumpers use tube as do pretty much all rock sliders and they seem to handle hits fine
    Sometimes there are options of HREW vs DOM
    Torspd likes this.
  10. Jan 31, 2022 at 7:17 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    i realllllllly like this bamf bumper looks amazing.
    But i also really like the c4 overland
  11. Jan 31, 2022 at 8:27 PM
    TacoTuesday1
    FL
    I think some bumpers say “crossmember relocate required” - anyone know what that means?
    I’m guessing the front stock metal crossbar on the truck might have to get cut off or something
  12. Jan 31, 2022 at 8:32 PM
    the_black_tacoma
    the_black_tacoma Well-Known Member
    Griffin
    IN
    2008 Black Tacoma SR5 AC
    A couple
    Yes, the nicer brand ones discussed so far are definitely better looking, but I’m pretty happy with my Trail Gear bumper, way cheaper and didn’t even have to wait a week to get it.
    GetterDun likes this.
  13. Feb 1, 2022 at 11:27 AM
    Cryptictoy
    Cryptictoy Well-Known Member
    Esperance, N.Y
    I'm would take a guess that it's the front lower piece that has the bolt on wings on ends, as low as the bottom of radiator , which is the problem for the front of the trucks for fabbing a bummper up with nice clearance.
  14. Feb 1, 2022 at 2:16 PM
    xplorn
    xplorn Well-Known Member
    Ken
    Oregon, USA
    '10 DCSB OR
    I built a 4x4labs from a kit. They aren't up on his web site but he should have pieces in stock. Kit is quicker to get and you can make it fit as you like. I like the hi-lift cutout on the wings and I did the tube to give some light protection. If you had Luke build it he could whip up tube hoops to suit. He also has an in-house powdercoat oven.
    r2pinter likes this.
  15. Feb 1, 2022 at 5:29 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I’ll always love my eBay 1 piece bumper. Best $500 spent. 001ED448-06FC-44F5-A51F-6E51BD78A9B8.jpg
  16. Feb 1, 2022 at 8:35 PM
    thegrandpoohbah
    thegrandpoohbah Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    @Alexely999, is that the DV8? Looks like they've doubled in price since you got yours.
    Alexely999 likes this.
  17. Feb 2, 2022 at 9:34 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Yeah the 1st one that came out. I’m not a fan of the newer multiple piece ones
  18. Feb 2, 2022 at 9:36 AM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    I'm partial to the SSO Slimline series, but WarFab also makes some really mean looking stuff.
  19. Feb 3, 2022 at 1:30 PM
    BrycenW01
    BrycenW01 Member
    Brycen
    06 DCLB
    Coastal offroad
