Best spring compressor for our coils?
Discussion in 'Suspension' started by nickrick78, Feb 4, 2023.
  1. Feb 4, 2023 at 9:50 AM
    nickrick78
    nickrick78 [OP] Well-Known Member
    Nick
    Pittsburgh PA
    Tacoless for now
  2. Feb 4, 2023 at 1:28 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I have the SPC's. I've used them about 5 or so times on my truck and friends trucks. They work as advertised and I've never felt unsafe using them.
    They're a little tough to get the fingers in and out of a preloaded coil, but assuming you don't compress the coil too tight, it's not a problem. I've also used them with the shocks still mounted on the truck to change the preload on 700 lb coils. It was a tight fit and probably easier to just pull the coilover off and do it on a bench.
    I have no experience with the Eastwood design, but their tools are typically high quality. I do think you may have trouble fitting the plates between the coils on a heavy spring.
    Ultimately, the best compressor is a wall mounted one.
    Area51Runner and GilbertOz like this.
