Best speakers for 2020 Tacoma
Discussion in 'Audio & Video' started by PizzaPlanetDriver, Jan 9, 2020.
  1. Jan 9, 2020 at 10:17 PM
    PizzaPlanetDriver
    PizzaPlanetDriver [OP] New Member
    2020 Tacoma SR5
    Stock so far
    Hello everyone,
    I’m new to having a Tacoma. It’s my first one. It’s a Magnetic Gray 2020 SR5 V6 Double Cab 5’ bed. Will post pictures soon.
    The stereo is the 8” screen as I wanted the biggest one. However, it didn’t have an option for the JBL speakers to go along with it apparently. So I’m trying to install JBL speakers or JL Audio speakers. Does anyone know which speakers would be best out of those two brands? Which speakers should I specifically to look into? Also, if there are any issues I should be aware of before I install such as additional wires, issues some of you may have encountered, etc.?
    please and thank you!
  2. Jan 10, 2020 at 12:34 AM
    Roldy
    Roldy Active Member
    Harry
    Oregon
    2017 Tacoma TRD
    TRD Pro Grille TRD PRO Skid Plate BFG KO2 265/75/16 K&N Cold Air Intake Bed Mat 35% Front Windows Tint
    There’s a great write up on someone that did Kicker’s all around for his 2016+ Tacoma non JBL. I actually followed his exact setup and it sounds amazing! Search for the best sound under $250 and it’ll come up.
  3. Jan 10, 2020 at 6:26 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you keep the OEM head unit, recommend you get efficient speakers, 92db or better.
    CLVol1255 likes this.
  4. Jan 19, 2020 at 5:10 PM
    keonigt
    keonigt Da Nurse
    Ewa Beach, HI
    2020 Tacoma TRD sport
    What do you mean by efficient speakers?
  5. Jan 19, 2020 at 5:24 PM
    rnish
    Tacoma 2nd gen
    Speakers with low power requirements.
  6. Jan 19, 2020 at 6:26 PM
    orangeblue
    orangeblue Active Member
    19 Tacoma TRD 4WD
    I just ordered Hertz Uno replacements. They are 94.5 dB efficient, interested in how they sound!
  7. May 26, 2023 at 12:20 PM
    MAKtaco
    MAKtaco Well-Known Member
    Michael
    2018 Cement Tacoma TRD off road
    How do you like the hertz uno’s orangeblue?
  8. May 26, 2023 at 7:57 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
  9. May 26, 2023 at 9:30 PM
    ZMan2k2
    Richard
    ‘Berta
    Define “Alpine system”? Headunit, speakers, amp(S), sub(S), etc.
    What features do you not want to lose? Birdseye cameras, steering wheel controls, center cluster info screen? Need the deets man!
  10. May 27, 2023 at 6:33 AM
    ZMan2k2
    Richard
    ‘Berta
    Got it. :thumbsup:
    Okay, so, safest bet on the cameras and such, not Alpine. From what I’ve read, most P-n-P option is the Sony XAV-9500ES. Keeps the cameras, just not sure about the center cluster info screen. https://trailgridpro.com/products/sony-xav-9500es-plug-play-bundle-16-22-tacoma/
    From there, go to www.Crutchfield.com and search up your desired speakers. Crutchfield, when you buy speakers from them, include the adapters to connect the speakers to the vehicle harness, no cutting, and brackets to mount said speakers. Personally, I prefer the Type-R lineup, components in the front, coaxial in the rear.
    Sub requires running power and ground wire (power from the battery, ground to a GOOD body ground), as well as an RCA cable and remote turn on from the headunit to your amp mounting location, as well as a good amp. Then you need a box/sub combo in another suitable location. Again, personally, I have a Hertz MPS300 sub(MPS250 works easier) and a KENWOOD XR901-5 5 channel. I’d suggest a KENWOOD XR601-1 for its smaller size and 600w at 2ohm and 400 at 4ohm.
  11. May 27, 2023 at 9:17 AM
    ZMan2k2
    Richard
    ‘Berta
    :headbang: Rock on! Crank it up!
    Conquistadors likes this.
