Best Snow Tire Recommendations (WY)
Discussion in 'Wheels & Tires' started by rower1138, Sep 24, 2021.
  1. Sep 24, 2021 at 11:37 AM
    rower1138
    rower1138 [OP] Member
    Cassie
    2017 Toyota Tacoma Off Road
    Hey TW!
    I am entering into my first winter in with my 2017 Taco. I'm trying to find input on the best snow tires. BUT the weather conditions I'm looking into at unique as i live in rural Wyoming. I live up a single lane dirt road, that can become windblown and not easily plowed (eventually, snowmobiling does become necessary but I'd like to drive my truck for as long as possible). I'm looking into General Grabber ATX and the Falken Wildpeaks. I am also contemplating studs (there are no salt on the roads and therefore packed snow or ice is common on road ways and mountain passes even if well plowed) which leaves me with the Generals only, as the only option I have found.
    I just want to see what other folks have experienced in similar conditions? I have been living in the mountains for over a decade and simply used to an AWD vehicle, so this is a new adventure with the truck.
  2. Sep 25, 2021 at 12:02 AM
    thegrandpoohbah
    thegrandpoohbah Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    An all terrain tire with the 3PMSF rating is not going to be as good as a dedicated snow tire. My vote would be the Nokian Hakkapeliitta LT3 studded.
  3. Sep 25, 2021 at 12:04 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    BFG Commercial Traction T/A have been good to me
  4. Sep 25, 2021 at 9:00 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Michelin Latitude X-Ice Xi2.
    Check your state laws about studded tires. Many states have banned the use of studs.
  5. Sep 25, 2021 at 12:25 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Just replaced my Blizzak dmv1 with the dmv2 last winter. Was not disappointed, they’ve handled everything I’ve ever driven through from Oct to Mar in the interior of BC- including three nights a week drives on the backroads to the ski trails, trips over mountain passes, and everyday city driving in fresh snow.
  6. Sep 25, 2021 at 12:41 PM
    That1GuyKev
    That1GuyKev Well-Known Member
    Kevin
    2021 TRD OR Army Green
    285/75/16 General Grabbers ATX on pro comp wheels 16x8 0 offset. Bilstein 6112 front and 5160 rear
    Vote for the Wildpeaks! I never ran them in full snowy road but they were great going up to Big Bear when it had just snowed the day before.
  7. Sep 25, 2021 at 12:45 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Hello there! I lived in Gillette for a handful of years, and had I believe 3 different sets of tires while I was there... Are you looking for a 12-month tire, or something that you swap to when the weather starts to get bad?
  8. Sep 26, 2021 at 3:26 AM
    FRE1809
    FRE1809 Well-Known Member
    Long Island,N.Y. ; USN ( Ret.)
    I have been using Bridgestone Blizzak as my winter tire. I'm impressed better than what I was expecting as far traction and wear. I get to work in any winter storm and I go to Maine in the winter on long weekends. I feel very confident in the vehicle traction it's the other people that don't have winter tires that makes me nervous. Bridgestone recommends to run there tires once the outdoor air temp. is below 45 degrees. You wouldn't be disappointed with Blizzak. USN 7P Proper Prior Planning Prevents Piss Poor Performance. G.L.
  9. Sep 26, 2021 at 10:32 AM
    rower1138
    Cassie
    I'm looking to swap out summer versus winter tires. I'm located up in Dubois.
  10. Sep 27, 2021 at 5:10 PM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    Grabbers or Wildpeaks are not proper winter tires. I've run Grabbers 8 months of the year, and Blizzaks for winter for the last 6 or so years. Traction difference is night and day when I put the blizzaks on. Generally speaking, AT tires aren't very good in the cold, even on dry pavement. They get super hard and break loose easily.
    Recently replaced the grabbers with Wilkpeaks, and will likely spring for a set of proper winters come November. Hakkas, Blizzaks, or Ice-X are all good choices.
    If you swap when avg daily temps are about 40-50 F, your winters will have good life. If you keep running them when it gets any warmer and you will burn them up in no time.
  11. Sep 27, 2021 at 6:19 PM
    jcampbell474
    jcampbell474 Well-Known Member
    North Carolina
  12. Sep 27, 2021 at 6:22 PM
    Bishop84
    Bishop84 Well-Known Member
    Start with a snow rated all-terrain, and buy dedicated winter tires later if its not enough.
    Falken Wildpeak, Toyo AT3, Goodyear Duratrac, BFG KO2 all work.
  13. Sep 27, 2021 at 7:10 PM
    Hiker46
    Hiker46 Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    I live in No. Colo and both the OEM GY Wranglers and Cooper AT-4s have been good winter tires for the CO winters. I have found that the SL rated tires might not be the best for our region, especially for dirt and rocky FS roads. I experienced 1 slow-leak puncture with each set. Luckily I carry a compressor which allowed me to limp home. I'm currently looking at the C/E rated options.
  14. Sep 28, 2021 at 4:05 PM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    General Grabber Arctic's for the win!
  15. Sep 28, 2021 at 4:12 PM
    krtek
    krtek Well-Known Member
    Steven
    Snoqualmie, WA
    2021 Tacoma TRD Sport - 6MT
    GFC V2 Platform Teraflex Falcon Shocks + OME Springs/UCAs Ricochet and RCI skid plates Tuned by @tonered And more...
    Been using Blizzaks DMV2 for a couple years and super impressed. Drove in a bunch of snow for months during ski season and had zero issues, tons of grip.
    vtown likes this.
  16. Sep 28, 2021 at 4:20 PM
    skiwaves8
    skiwaves8 Well-Known Member
    Pagosa Springs Colorado
    TRD
    Kanati trail hog they are set up for studs I live rural over 150" a year and 75% of our roads are dirt and I prefer them over the Duratracs and are usually cheaper. I run them on my Ram CTD and have zero problems and I run through 18" of snow often!
  17. Sep 28, 2021 at 4:29 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    My Cooper S/T Maxx are pretty great in snow and off road. I imagine with studs they would be amazing!
  18. Sep 29, 2021 at 6:06 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I have been using Toyo Observe dedicated winter tires for 20+ years out in the high Rockies of Colorado.
    Toyo has MicroBit which is ground walnut shells added to the tread rubber. Walnut shells are the hardest plant material in the world.
  19. Sep 29, 2021 at 6:09 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    My Firestone WinterForce were awesome last year. Threw them on some stock steelies bought off CL.
    tinker_troy and vtown like this.
  20. Sep 30, 2021 at 1:20 AM
    Poindexter
    Poindexter Well-Known Member
    north of Denali
    15 V6 auto 4x4 mag gray
    Rower, there is a sticky in this subforum up at the top about winter tires.
    I don't know much about winter in Wyoming except all the snow fence along I-80 made my short hairs stand up on end when I drove through in the summer.
    The main thing about winter tires is they are all compromises. If you come up with an excellent tire for deep snow on unpaved unplowed roads (Nokkian Hakkapellita) you will bobble down plowed ashphalt like a front end loader when your taco gets up around 45-50 mph. If you choose a tire for cold weather on plowed interstate (Continental used to make an excellent one) you will be getting your snowshoes out for the unpaved unplowed section.
    It seems to me the main thing, if you want to stay in the heated cab and not be waiting on a tow truck or digging snow out from under your rig, is to pick the two (possibly three) conditions you have to deal with the most and accept that the tire you chose will not be ideal for other winter challenges.
    Blizzaks are widely regarded up here as the "best" snow tire that doesn't have studs, but there are other tires in the same class now, and all of them are not so great on black ice. In the winter tire sticky try paging back five pages or so from the end and then read forward for the last 2-3 years. I do run Blizzaks under my wife's Rav4, but she doesn't go off pavement at all and might drive 2 miles a year on unplowed asphalt.
    I have heard of walnut shell before as eurowner mentioned above and will be checking those out before I spring for a new set of Nokian Hakkas- but for work I take my truck to customer homes, which means I deal with a lot of unplowed unpaved driveways, or can carry my work tools back and forth from my truck. My personal compromise here is to settle for 45 mph on plowed ashphalt, but not have to carry my tools very far.
    rower1138[OP] and eurowner like this.
