Best snorkel to get?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ano'ai808, Sep 6, 2017.
  1. Sep 6, 2017 at 7:31 PM
    Ano'ai808
    Ano'ai808 [OP] HoloHolo Kalaka
    Ano'ai
    Kahului
    2019 TRD sport
    2.5 fox 3-4in front/rear Dirt king fab LCA/UCA Locked rear bumps OME leaf pack ARB air 15%-5%tints
    Looking to do one so wanting to know your likes out there!!!
  2. Sep 6, 2017 at 7:36 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    ARB is arguably the "best" it's also definitively the most expensive.
    People have had good luck with the Ebay/off brand ones you just throw the template away and measure twice, twice, and the drill ONCE.
    I've seen some acceptable looking home made ones as well, PVC pipe etc.
    Ultimately though the ARB is the lightest strongest most UV stable best fitting most engineered and tested snorkle. That's how they justify charging $600 for a plastic tube and an elbow.
    jc11taco89 likes this.
  3. Sep 7, 2017 at 7:45 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Love my arb snorkel. Worked fine with hurricane Harvey flooding that hit Houston.
  4. Sep 7, 2017 at 7:47 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Does the ARB connect to your a pillar? I have been eyeing a snorkel, but shying away because I don't want to drill into the pillar.. curious if others have used double sided automotive tape or something similar to avoid this..
  5. Sep 7, 2017 at 7:48 AM
    Bebop
    Nick
    I drilled into the a pillar. It was easy. Marked it with a black magic marker and drilled away. Put some rtv around the little insert rivets for the screws and everything was fine.
    Key-Rei and BassAckwards[QUOTED] like this.
  6. Sep 7, 2017 at 7:53 AM
    Babyjake16
    Babyjake16 @project_traitor
    Jake
    Utah
    2008 Super White Tacoma
    33" Nitto Trail Grapplers 17" TRD Matte Black Wheels ICON Stage 5 w/ differential drop 30% Tint 2 - Pioneer 12" Shallow Mount Subs Focal Speakers Pioneer Head Unit 2 - Pioneer Amps Custom Stickers/Badges Paracord Grab Handles Painted Interior (all panels, headliner and carpet) Clazzio Leather Seat Covers with leather arm rests Ditch Lights 3 - 8" HieseLight Bars in bumper Rock Lights - Cali Raised LED Custom Fabricated Front Bumper - Blackout Fabrication Rock Sliders - DOSECC Fabrication Bushwacker Fender Flares (color matched) Morimoto LED Fog Lights
    I'm actually going to be getting an ARB Safari snorkel here soon through my vendor. usually they have the lowest prices and maybe i can get it lower if a few of us order. pm me and i can check!
  7. Sep 7, 2017 at 7:54 AM
    Babyjake16
    Jake
    Utah
    Are you running stock intake?
  8. Sep 7, 2017 at 7:56 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    The best snorke to get is @Snorkie .
    Snorkie likes this.
  9. Sep 7, 2017 at 7:57 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    I have stock intake and an Airflow Snorkel.
  10. Sep 7, 2017 at 8:00 AM
    Babyjake16
    Jake
    Utah
  11. Sep 7, 2017 at 8:03 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    How about one of the stronger 3m double sided tapes? On expedition portal there are people using that stuff to attach panels to the sides of their campers.
    BassAckwards[QUOTED] likes this.
  12. Sep 7, 2017 at 8:05 AM
    BassAckwards
    Ill have to check that out, it seems like I remember reading about others using this as an alternative to the drilling! Thanks for the heads up!:thumbsup:
    otis24[QUOTED] likes this.
  13. Sep 7, 2017 at 8:09 AM
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    I didnt want to drill my A pillar so I stuck it on with the heavy duty outdoor 3m tape. Works great!
  14. Sep 7, 2017 at 8:12 AM
    BassAckwards
    Just what i was hoping for, thanks folks! :thumbsup:
  15. Sep 7, 2017 at 8:14 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I've had 3M tape on my Airflow bracket to the A-Pillar for several years and it's holding up fine. And that's with an Enginaire Pre-cleaner on it.
    uurx, TACOVRD, otis24[QUOTED] and 2 others like this.
  16. Sep 7, 2017 at 11:46 AM
    Bjo71
    Bjo71 Well-Known Member
    2014 MGM Tacoma prerunner v6
    I'm tempted to get one on my GX470 and Prerunner after driving through 1 1/2 -2 feet of water during Harvey. I'd feel like a poser with one on a 2wd truck tho.
  17. Sep 7, 2017 at 11:51 AM
    dcoursler
    dcoursler They call me Tater Salad
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    Currie Rock Jock High Pinion 60, JD Fab EVERYTHING, Fox shocks, Radflo Shocks, Archive Garage all the other things, spinny thing on top of the motor
    This cracks me up! Just drilled a 4" hole in your truck and you dont want to drill 3 little rivets holes.! I get it but still you have to see the irony
  18. Sep 7, 2017 at 11:56 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Fenders are easy to replace. A-pillars are not.
  19. Sep 7, 2017 at 11:59 AM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    I read some where on here about someone using military grade Velcro. The hard plastic kind.
  20. Sep 7, 2017 at 12:01 PM
    BassAckwards
    My thoughts exactly!
