best roof rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ripcityota, Feb 26, 2018.
  1. Feb 26, 2018 at 8:28 AM
    ripcityota
    ripcityota [OP] Member
    Christian
    2014 Pyrite Mica Tacoma TRD Sport
    -3" rough country lift kit -XD811 Rockstar II Wheels 18'' -nittoexograpplers AWT
    I am looking for a roof rack that is affordable and fits my 2014 Tacoma double cab long bed
  2. Feb 26, 2018 at 9:14 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
  3. Feb 27, 2018 at 8:12 AM
    ripcityota
    Christian
    the Prinsu is perfect...going to save up for that big purchase.
  4. Feb 27, 2018 at 8:25 AM
    WhiskeyTaco
    WhiskeyTaco Well-Known Member
    Zach
    Denver, CO
    2011 White Tacoma Access Cab TRD Off Road
    Frontrunner and Warrior Products also make roof racks.
  5. Apr 23, 2018 at 6:21 AM
    SOLID
    SOLID Well-Known Member
    Jamie
    Louisiana
    2017 Magnetic Gray Tacoma TRD Off Road
    265/70R16 Duratracs SPC 25470 Upper Control Arms Old Man Emu 90021-P Nitrocharger Sport Front Shocks Old Man Emu 887 coils Old Man Emu 60091-P Nitrocharger Sport Rear Shocks Old Man Emu EL119-P Leaf Springs Old man Emu Carrier Bearing Drop Cali Raised Kick Out Rock Sliders Goose Gear Rear Seat Delete WeBoost Signal Booster Switch Pro SP9100 8-Switch Panel Power System Vertical Switch Pro PowerTray with install kit Cali Raised Off Road Switch Pro Mounting Panel upTOP Overland | 38" Dual Function Light Bar Baja Design rock lights - w/ scenePOD 2.0 - 4 - Roof Rack - Bed lighting - 2 - ground - frame - 6 UpTop Bravo Roof Rack UpTop Truss MID Height Bed Rack Mountain Hatch Tailgate Insert Cali Raised LED - Bed Channel Supports 23Zero RTT - Breezeway 62 with LST 23Zero Canopy Condition 1 Case - Roof mount WaterPORT 3.8-gallon self-pressurized water tank Joolca HOTTAP camp shower system Desert Does It Seat Jackers - 2 Desert Does it Front Multi Mount Panel Element fire extinguisher Hi Lift Jack Hondo Garage Un-Holey Phone Mounts - 2
    I'm in the market for a roof storage system too for my 2017. Any knocks against or advice for the factory rails and a clamp-on basket?
  6. Apr 25, 2018 at 9:33 AM
    SP Taco Truck
    SP Taco Truck Member
    2015 MGM Tacoma
    I went back and forth between prinsu and warrior. I ended up going with the warrior. It comes black powder coated, has the optional air dam, and I liked the idea of inch square bars for mounting. Look around the web for the warrior products 4860 platform rack and you can find some good deals. I can add some pictures when I get home if anyone wants to see it.
    I married my tacoma likes this.
  7. Apr 25, 2018 at 10:18 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Looks like kc lights is making roof racks for our trucks now too
    SOLID and I married my tacoma like this.
  8. Apr 25, 2018 at 10:22 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Gobi,$2000.00
  9. Apr 25, 2018 at 10:37 AM
    ALwoodsman
    ALwoodsman Well-Known Member
    North Alabama
    2013 4x4 DCSB
    Baja Utility Rack, SOS Concepts sliders, Bilstien 5100, OME 884, Toytec AAL
    I have a BajaRack flat utility on mine.
  10. Apr 25, 2018 at 11:25 AM
    HoulaHauler
    HoulaHauler Well-Known Member
    Andy
    Gwinnett Co., Georgia
    2013 1G3 DCSB
    What are you needing it for? I just bought the OEM because I really only needed it for my 12ft solo canoe. Stupid easy install and got it for $276.
    TireFire, Glocker23, Beauxdon and 3 others like this.
  11. Apr 25, 2018 at 11:33 AM
    Yukon
    Yukon Well-Known Member
    2009 Magnetic Grey SR5
    Do you want it over your cab? Or camper shell? I installed a vantech J1000 that's a "low profile" 72 inch crossbar on my shell and love it.
  12. Apr 25, 2018 at 1:03 PM
    SOLID
    Jamie
    Louisiana
    Form follows function, right? I REALLY like being able to lock the tonneau & tailgate when we're in urban environments. However, a couple of times a year we are going to take road trips (5k miles +) where we need to haul more gear than will fit under the tonneau cover. So I'm thinking the factory rack and maybe a basket for our road trips.
    I've also seen some slick, low-profile, locking containers for rooftop baskets. Anyone got an opinion/source on those? I really appreciate the info and feedback. Thanks ya'll.
  13. Apr 25, 2018 at 1:05 PM
    SOLID
    Jamie
    Louisiana
    When I finally go into full "bug out mode" I think I'll go that route too. But for now I like the idea of the locking tonneau cover + over the cab storage.
  14. Apr 25, 2018 at 1:07 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    They bought out/acquired M-Racks who used to sell their racks for ~$799, and now KC retails these racks for 1200. Either they made them better quality and now cost more to make, or they jacked up the price to squeeze more money.
    The M-Racks also did not use factory bolt points and required holes put in the roof. But maybe KC changed that to be more vehicle specific. Idk.
    Edit: after looking over the install directions, yeah you have to drill holes in your roof.
  15. Apr 25, 2018 at 1:08 PM
    Yukon
    I went that route because I haul two kayaks and use saddles so I needed the crossbar to be reeaaal wide. Considering one kayak is 34 inches wide and the other is 30, I also have a DIY rod pod that I put in the middle.
  16. Apr 25, 2018 at 1:22 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    Drill 6 holes? It uses the stock roof rack hole locations just like the OEM rack. Only access cabs require drilling but that goes for all access cab racks.
    scott96929 and LithiuM23 like this.
  17. Apr 25, 2018 at 1:34 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    HoulaHauler and scott96929 like this.
  18. Apr 25, 2018 at 1:37 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    the OP is a 2nd gen.
    Here’s the actual installation instructions for 05-2016 Tacoma’s if you need further clarification:
    http://docs.wixstatic.com/ugd/e5eb7b_9f8901546217405eb3d3cba3abbcfb31.pdf
  19. Apr 25, 2018 at 1:38 PM
    pta_taco
    pta_taco Exploring when I can
    Patrick
    Greenville, South Carolina
    2016 TRD Off-Road
    https://www.tacomaworld.com/threads/pta_taco-2016-offroad-build.493686/
    No drilling required for double cab. Have had mine for two years. No problem hauling kayaks, lumber and tent.
    JPTaco1974 likes this.
  20. Apr 25, 2018 at 1:40 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    I have a GOBI, it’s stout.
    Beauxdon likes this.
