BEST ROOF RACK FOR OUR NEEDS?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by youcanrunnaked, Nov 28, 2023.
  1. Nov 28, 2023 at 3:36 PM
    youcanrunnaked
    youcanrunnaked [OP] Active Member
    I’m looking for a roof rack for our 2021 Tacoma TRD Off Road, double cab, short bed. My wife and I have Hobie Mirage kayaks. They are 12’ or 13’ long and around 70 lbs each. [CORRECTION: Kayaks are 85 lbs each (fitted hull; unrigged). So 170 lbs, total.]
    My wife bought a goalpost-style bed extender, but with the kayaks in the bed, they stick out very far. So we are thinking of getting a roof rack to transport them, either with double kayak cradles, or with them mounted on the rack at the front half, with the raised goalpost extender supporting them from the back.
    Note that we are looking to take the truck camping, so a roof rack system that is versatile enough to work for other outdoor uses as well would be a plus.
    Would the Toyota OEM accessory roof rack work for either or both methods?
    Are there better choices?
    Any advice or experience you can impart is appreciated.
    EDIT: Found the Toyota rack weight rating: 100 lbs. No indication if that’s static or dynamic, but either way, inadequate for my needs. So looking at the more rugged aftermarket choices.
  2. Nov 28, 2023 at 4:15 PM
    bbal
    bbal Well-Known Member
    I got the Yakima baseline towers and 58” round bars. Then you can add whatever kayak holders you want and get some NRS straps (2 per boat… I’d get the 12 foot long 1 inch ones and you can shorten them if needed). Whole thing will be around $600-800. Yakima website will walk you through the setup. if you want to cut costs on it compare eBay/etrailer/Amazon/REI/rerack. The beauty of the baseline set up is once you have the front and rear bars set up the exact right distances they go on and off the truck in less than 10 minutes so you won’t have to keep them on all the time. They also will not damage the truck at all and you won’t even be able to tell they were on there. Edit: damn they have really raised the price on the towers. But I see plenty of them on eBay for much less.
    TacoManOne and Malvolio like this.
  3. Nov 28, 2023 at 4:36 PM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2021 4runner "Luna" 2023 Solar Octane MT "Solaris"
    What do the kayaks weigh? The roof rack will be fine either way. But remember, you have to lift that thing up onto or off of the cradle, potentially alone.
  4. Nov 28, 2023 at 5:22 PM
    youcanrunnaked
    As for getting them on and off the truck, I’m thinking one person in the bed, one on the running board (leaning in, with the door open). I’m in FLA (gator country) so likely not paddling alone. But as with the mounting system for transporting the kayaks, I’m open to suggestions.
  5. Nov 28, 2023 at 5:26 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Thule has roof rack yak accessories. Also see Yakama.
  6. Nov 28, 2023 at 5:34 PM
    bbal
    Dang 85 is heavy. I’ve got a 70lb canoe I put on every now and again and it’s not fun. Unless you’re 6 feet plus that will be a two person job. Yakima makes an extender called a boatloader that extends out from the front bar sideways when needed, and that could help. I’ve used it for my canoe when loading it solo.
    Malvolio likes this.
  7. Nov 28, 2023 at 5:41 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I would not go oem rack unless it was just for looks or very light items(skis, snowboards, etc). For mounting any rack I recommend Rhino ditch tracks since they’ll allow for a variety of roof options than can also work interchangeably with roof tracks on a shell. I keep my Thule bars racked inside the shell and in a few minutes can have both on the cab, both on the cap, or one on each with any spacing I want. I have another set at home if I want 3 or 4 bars. Mostly drive with none for mileage and noise.
    There are good reasons for choosing something else. I’m sure you’ll hear them.
  8. Nov 28, 2023 at 7:01 PM
    G2.M6
    Fort Collins CO
    I also wouldn't haul ass with them up on top either. Maybe refer to a wind load diagram. But at 60 or 75 that will create an enormous uplift. That will pull on your rack no matter which you get. Have you considered a pull behind trailer? I did a bunch of salt water kayaking. But they had depth finders down riggers and peddle drives.
    I always throw that in the bed. My advise.... you can keep your kayaks set up. If your fishing it's huge. You would have to add your gear, add the depth finder, ect ect... unnecessary dock time. The Yakima bed extender or a trailer.
    OZ TRD likes this.
  9. Nov 28, 2023 at 7:12 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Do not use the OEM rack - It is only rated at 75 Lbs per the below quick search:
    https://www.tacomaworld.com/threads/weight-limit-on-stock-roof-rack.338554/
    (Pretty useless and it is Fugly)
    Your load is 100 lbs + above - STATIC load. Now you start moving... add windage and you are looking to be featured on one of those FAIL videos on youtube...
    (Please post link when applicable!)
  10. Nov 29, 2023 at 7:30 PM
    Jruk
    Jruk Un-Known Member
    Middle West of the US of A
    2021 Army Green TRD Off-Road DCSB 4x4
    I use an UpTOP’s rack with Malone Seawings. My 2 kayaks are about the same size as yours and they fit side by side. Unusual setup but it works nice without having to use J cradles.
  11. Nov 30, 2023 at 6:38 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    vicali likes this.
  12. Nov 30, 2023 at 8:36 AM
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    I have an UpTOP rack and used a Thule Glide and Set kayak carrier for my hobie. Outfitted with fishing gear, it was probably around 90 lbs and not fun to load by myself. I would prop the bow on my rtt and slide her into place (a little crammed but i was able to fit a second hobie up there as well and the UpTOP held everything just fine) Have you heard of the Hullavator? $$ but really nice. https://www.thule.com/en-us/water-racks/kayak-and-canoe-racks/thule-hullavator-pro-_-1685448
  13. Nov 30, 2023 at 8:53 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Given what you're looking to do with it, a roof rack is the wrong choice. Just get yourself a ladder rack.
    Or if you want to pay 3x the price, get yourself a bed rack. No, it's not the same thing. One is designed to be functional and sturdy, the other is "designed" (by someone with no knowledge of engineering) to get you likes on Instagram.
    OZ TRD likes this.
  14. Nov 30, 2023 at 9:17 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
  15. Nov 30, 2023 at 10:13 AM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Kargomaster III might work out OK for kayaks:
  16. Feb 22, 2024 at 9:41 PM
    TacoTuesday1
    FL
    If you're looking at cab racks
    Sherpa is said to be the best. Probably looks to be the best.
    Probably strongest and thickest metal (grand teton)
    only thing I've seen it not have that another rack may have is a dropdown front fairing for light bar that can manually open/close to run the bar.
    D.A.S. Taco and bulalo like this.
  17. Feb 22, 2024 at 10:13 PM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    I went with the Yakima system for naked roofs. I like being able to remove the rack. After 1000's of miles, my satisfaction is absolute. I recommend buying a solid single-step step-stool to help you secure the boats for whichever rack you ultimately choose.
    DrRansom and OZ TRD like this.
  18. May 7, 2024 at 3:00 PM
    youcanrunnaked
    UPDATE: I decided to go with the Prinzu.
    It was between the Prinzu and the Sherpa Grand Teton. Despite the Prinzu having higher ratings for static and dynamic load, I liked the Sherpa a little better. However, it was a lot more expensive (by around $400). The Sherpa arguably looks a little nicer, but the only tangible advantage I saw was the Sherpa has a slightly easier (and IMO better) mounting system, with no silicone sealant needed.
    The other advantage used to be that Sherpa uses stainless steel hardware. It looks like Prinzu heard the complaints about rusting hardware, because the new version Prinzu rack comes with all stainless steel hardware. They've also upgraded the crossmembers to the stronger Prinzu Pro design, so the weight ratings advantage of the Prinzu over the Sherpa is significant. I decided the Prinzu Pro, while very nice, is only a marginal improvement over the basic Prinzu, and probably overkill for my application.
    Now to find the time to install it. I may be back for more advice, but please feel free to offer any tips or tricks for installation. Thanks.
  19. May 7, 2024 at 3:02 PM
    TacoTuesday1
    FL
    new Prinsu is redesigned
    Not sure the price compared to Sherpa or when they do sales
    Bought mine used for less than a Prinsu
    Sherpa came out with sport which is thinner and cheaper than Grand Teton. Don’t know if the metal thickness and associated load ratings matter.
    heard the thicker one is for serious builds and Sport is for light duty couple of little things on it
    couldn’t justify thinner as thicker metal was one of the few whole selling points of the rack back when they were the only one 1/4” while everyone else was 3/16”.
  20. May 7, 2024 at 3:09 PM
    youcanrunnaked
    The redesigned Prinzu retail price was over $300 less than the Sherpa Grand Teton. Then they gave me a 10% new customer discount, so the total with sales tax was over $400 less than what the Sherpa would have cost. I like the Sherpa a little more, but not $400 more. Buying used, you got a good rack at a decent price if you paid less than a new Prinzu. I did not consider the Sherpa Sport, given the static load of 170 lbs of the two large kayaks I plan to haul, and the much higher dynamic load once they get into the wind.
