Best Roll In Bedliner Product
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sixgun, Aug 4, 2011.
Which do you Prefer?
  1. Herculiner
    47.3%
  2. Rustoleum
    8.9%
  3. Duplicolor
    11.6%
  4. Bondo RollIn
    0.9%
  5. Monstaliner
    6.3%
  6. Scorpion
    1.8%
  7. Grizzly Grip
    3.6%
  8. Lava Liner
    2.7%
  9. Gator Guard
    0.9%
  10. Raptor
    14.3%
  11. Others
    16.1%
  1. Aug 5, 2011 at 9:51 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I hate to say it, but the people recommending Herculiner probably haven't ever tried anything else. I would bet that every single one of them would choose Raptor liner over Herculiner every day of the week if they had used both and had seen the difference first hand.
  2. Aug 5, 2011 at 9:52 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    So do you need a compressor for raptor liner? Or did you just roll it?
  3. Aug 5, 2011 at 9:55 AM
    Box Rocket
    Adam
    Syracuse, Utah
    I used a compressor and sprayed mine. It's the best way to get a good finish. I just borrowed a cheap compressor and bought Schutz gun. The gun is cheap (I think I paid less than $30). Make sure you mask what you don't want to be sprayed VERY WELL. It can get everywhere.
    I supposed you could roll it and it would probably work just fine, but the bottles are designed to work with the sprayer. They have empty space at the top where you add the hardener, shake it up and the Schutz gun screws right onto the bottle. It can dry fast in the gun, so I made sure that I sprayed some mineral spirits through the gun between each bottle just to keep it from clogging while I got each bottle ready.
  4. Aug 5, 2011 at 10:34 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I've used other rattle can bedliners and they didn't work nearly as well as the herculiner that is all my experience. From your pictures it looks very good, better than the herculiner, but the process to spray it on sounds much more difficult than applying herculiner. I'm reconsidering doing my bed in herculiner now after seeing those pictures. :cool:
    I have a cheap compressor that would probably work. I don't really have experience painting with a compressor/spray gun, how difficult would it be for me to do this? If it's not too bad I might even consider redoing my rocker panels lol.
  5. Aug 5, 2011 at 4:44 PM
    Sixgun
    Sixgun [OP] Well-Known Member
    Mobile, Alabama
    2024 DCSB TRD OR
    That was my draw back with raptor. I'd prefer a spray on though I don't own the tools to do so.. also might coat the inside of the cab floor. Lots of prep. Looks a lot nicer than Hurculiner.
  6. Aug 5, 2011 at 8:30 PM
    JohnDavid
    JohnDavid Active Member
    Martinsburg, WV
    02 Tacoma TRD
    100% Stock
    I voted Herculiner. I just rolled my bed last weekend with the stuff. I was rather impressed with the ease of application, the consistency of the product, and how well the product set up after it cured for a few days. I had been wanting to replace my old over-the-rail drop in bedliner for a while. I found a coupon on here for $35 off a purchase of $85 or more at Advance Auto...so I got my Herculiner for pretty cheap.
    I did a quick google search for Raptor and found this...http://www.tptools.com/Product.aspx?display_id=2600
    I might give Raptor a try on my 08 Tundra since you can get a whole kit minus the compressor for $99
  7. Aug 6, 2011 at 10:22 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ive used both. i used raptor color match on my tailgate...and herculiner on my bumpers. and i'd still go with herculiner. it fading some doesnt bother me..and i like the abrasiveness of it.
  8. Aug 6, 2011 at 10:42 AM
    kmok
    Kyle
    Columbus, Ohio
    I don't mind the fading or abrasiveness either, it looks like a flat black when it fades and does not turn grey.
  9. Aug 7, 2011 at 4:20 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I thought these sprayed in linners were bullet proof, but I read that guys are having to touch them up.
    Just as well leave the toyota linner in the box pull it out once a year and touch up the bare metal spot with a rattle can bed linner, (Rustoleum )
  10. Aug 7, 2011 at 4:43 PM
    Country
    Country Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    I used al's proliner from 4 wheel parts
  11. Aug 7, 2011 at 6:32 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    FWIW...my 1st hand experience applying Herculiner.
    The prep work sucks! I spent a good 4 hours sanding. There are just too many tight curves in our trucks to use an orbital sander or such so I did it all by hand. Throw out the 3m/scotch brite pad that is included in the kit...its worthelss. I purchased 2 - 100 grit sanding pads (they look sort of like sponges with sandpaper glued to them) and they worked great getting into all of the tight spots! Masking everything off took another 90 minutes + and then I cleaned out the bed with Xylene (as per the instructions) talk about fumes! I think I lost a few brain cells there...
    That was the hard part. The actual application of the liner was fairly easy. As long as you possess a few basic painting skills, you can do this project. It took me just shy of an hour to do each coat, 4 hours dry time in between.
    Must haves for the project:
    -2" and 1" blue painters tape (take your time, get it on straight)
    -100 grit sanding pads
    -knee pads (I have some with hard plastic pads and they did scrape up the liner when I was doing the 2nd coat. Maybe I didn't wait long enough, maybe I should have gotten the soft gel type kneepads)
    -heavy duty latex gloves
    -coveralls or 'disposable' long sleeve shirt and long pants
    -xylene (quart) they recommend using xylene for thinning out the liner and for clean up. I didn't have to thin it out at all and only used a minimal amount for prep and clean up. I could only find gallon jugs at the local stores though ($20!) so I've got a lot left over....:mad:
    All prepped and ready to go!
    First coat drying
    And do apply the newspaper all the way down the sides of the truck and up to at least the bottom edge of the back window. I had a few slips and drips that could have spelled disaster if I hadn't have taken the time to do that!!
    I'll get some finished pics later this week.
  12. Aug 10, 2011 at 10:06 PM
    Box Rocket
    Adam
    Syracuse, Utah
    Professionally sprayed liners like Linex, or Rhino Linings are pretty "bulletproof", but that's part of why they cost so much . The DIY ones just aren't the same quality, and usually don't go on as thick. It's one of those you get what you pay for things. I still say that the best DIY liner is Raptor liner. Sprays on well and has a good finish and is suprisingly durable. It can scratch and chip like any of the DIY liners, but I have had very few issues with mine. Touch up is a peice of cake though so no biggie.
    ~$100 for a Raptor kit vs. $600+ for a professional sprayed liner......That's going to be up to the individual and what he's willing to pay for.
  13. Aug 11, 2011 at 11:47 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Good luck getting Heculiner to look as good as this. Raptor Liner ftw!
  14. Aug 11, 2011 at 12:50 PM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    I dont know how "bullet proof" Line X is. My dad had it in his pickup and parts of it peeled up.... maybe the installers didnt take the time to prep it right but for $700+ it should have been. I would go with a DIY one so that you can touch it up yourself.
    I herculined the interior of my 90' pickup and am happy with it... but the raptor stuff that Box Rocket used looks pretty nice. If I ever do the bed of my Tacoma I will be giving that a serious look.
  15. Aug 11, 2011 at 1:05 PM
    #35
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
    Decisions - Decisions?:confused: Like to see some pics of both the Herc and Raptor 1 or 2 years down the road. They all look killer right after you apply them IMHO.
    Had the Line X on my Silverado and that stuff is TOUGH. It also comes with a lifetime warranty iirc. Thats another pos bang for you get what you pay for:)
  16. Aug 12, 2011 at 12:46 PM
    #36
    Box Rocket
    Adam
    Syracuse, Utah
    I will try to get a better photo, but the Raptor liner I used in my trailer looks pretty much the exact same as the photo I posted earlier right after I sprayed it. Hasn't faded a bit in the 3 years since I did it.
  17. Aug 12, 2011 at 6:52 PM
    #37
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    x69
    My friend has herculiner in his tacoma. It's been about 3 months, it's fading, it's still amazingly abrasive and rubbery.
    I used to have line-x in my 2000 chevy. It peeled pretty much everywhere.
    My friend's dad has rhino liner in his f-150. Freaking awesome stuff, costs lots though
    I have raptor liner in the interior of my 82 jeep. The stuff is without a doubt the best diy stuff I've ever seen. There's tons of dust from when I go off roading without a top, and I can hose it down for 5 minutes or take a sponge to it and it's clean. It hasn't faded at all, and I haven't been easy on my floorboards.
    EDIT: my friend has grizzly grip in his ram 1500, it's peeling everywhere. that stuff sucks
    You can do what you want, but I would try very, very hard to find a compressor to borrow. Raptor liner is amazing, and I'm still amazed by it
  18. Oct 20, 2011 at 9:25 PM
    #38
    1998tacomaowner
    1998tacomaowner Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    i dont know what is on my truck but its super smooth and really durable i would love to get more of it but dont know what it is
  19. Oct 22, 2011 at 10:56 AM
    #39
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Good info. Any recommendation for roll on type? Going to do my truckbox when I get back.
  20. Oct 22, 2011 at 7:58 PM
    #40
    ALawrence
    ALawrence Well-Known Member
    Andrew
    Oklahoma City
    03 Tacoma Sr5 Double cab 4x4
    i did the roll on Herculiner. it's rough, but stuff isnt going to slide around. biggest tip would be to spray down a dark primer first, with my red truck, missed spots show through easy... although the idea isnt to miss any spots.... make sure you scuff up the bed good to, the herculiner will peal up if it doesent adhear good... i like it though, makes my truck look 100 times better
