Best rim/tire setup for a 2007 tacoma with a 3inch lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yeet, Mar 20, 2019.
  1. Mar 20, 2019 at 1:49 AM
    yeet
    yeet [OP] New Member
    2007 toyota tacoma access cab 4x4 6-speed
    3inch lift with Bilstein 5100's
    greetings my fellow yota enthusiasts,
    new here and have owned a partially stock 2007 tacoma access cab for a while now. Ive put a 3inch Bilstien 5100 lift in and now its time for a rim and tire upgrade from the stock 16's.
    I would love to hear every ones ideas/thoughts on sizes that wont cause me too much grief in the trimming department.
    intended for 60% road 40% off road
  2. Mar 20, 2019 at 3:55 AM
    BC714
    BC714 Member
    Bryan
    2013 Silver Tacoma TRD Sport
    None yet
    Are you planning on cutting, or do you want a no-rub tire for staying stock?
  3. Mar 20, 2019 at 5:12 AM
    psyWAR1988
    psyWAR1988 Well-Known Member
    2012 DCSB TRD Barcelona RED
    2012 DCSB 4x4 TRD Sport in Barcelona Red Suspension/Driveline Front – Icon LT 2.5 Coilovers Rear - Icon Progressive 3-leaf add a leaf with overload with Bilstein 5100s Icon Tubular UCAs with Delta Joints Toytec 3 degree axle shim OME FK29 CB drop kit Wheels/Tires/Armor Desert Rat Rattler Tracker II rims BFG A/T KO2s 275/70/17 U.S. Off-road Hidden Winch Front Bumper (powdercoated diamond flat black) Trail Gear Weld-on Sliders (painted Hammered Black Rustoleum) Mods TRD cat-back exhaust TRD Pro Grill install TRD Pro Headlights install ARE MX Camper Shell (plasti-dip black) Redline Tuning Hood Struts Relentless Tailgate all metal skin plate Relentless Off Road all-steel tailgate cap Total Chaos Bed Stiffeners Precision LED Interior Lights Birddawg Rear view mirror relocate w/ ram ball AJT Designs CNC Billet 6061-T6 Aluminum Tacoma short shift Knob (Anodized Black) AJT Designs Injection ABS Climate A/C Knobs (Black with Black Anodized Alum. screws) AJT Designs Injection TRD Key FOB case (Cement Gray with Red Anodized Alum. Screws) UNI Filter Mod Weathertech Floor Mats AVS window rain guards MagLite Mod 8 inch Mini Antenna mod Mob Armor Cell Phone mount OneTigris Tactical Molle Seat Back Panels with Molle Pouches (Cutters, Medical, Axe etc) De-badged To-Do (Have but not On yet) Entune Radio Bezel for radio, center console, 4x4 knob (awaiting shipping but purchased) OG Fabrications “Oh shit bar” Aluminum Overhead Molle Panel (awaiting delivery OG Fabrications Center Console Aluminum Molle Board Panel (awaiting delivery) ECG Bushing for Vibration Wheeler’s front superbump stops. Rear Diff Breather mod
    https://www.desertrat.com/c-1181390-tire-wheel-packages.html
    Best place imo ever to get Tim and tire combos. This is where I bought my rim and tire combo. Comes shipped, mounted and balanced. I got 275/70/17 BFG A/T KO2s on Desert Rattler Tracker II Black all four for 999$ out the door. I don’t use the center caps but you could and put a nice toyota or trd decal on top and with the carbon fiber accent, would look good. 2AF4FB5E-9FBF-4557-A3ED-E20A3DE5542C.jpg I’ll add a pic on the truck for eye candy later
    jross20 likes this.
  4. Mar 20, 2019 at 9:42 AM
    psyWAR1988
    Here are the rims on my truck with the tire combo. Im not at 3 inches, I like it a bit lower on my Icons, but it will give you a good idea.
    Sidney Vicious likes this.
  5. Mar 20, 2019 at 10:56 AM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    The most popular sizes for a 3" lift are
    265/75/16
    265/70/17
    Those are about the same height, just under 32" tall
  6. Mar 20, 2019 at 10:58 AM
    Dimestore55
    William
    Richmond, VA
    265/75/16
  7. Mar 20, 2019 at 11:01 AM
    psyWAR1988
    If you go with these sizes you **should not** have too many rubbing issues, especially on 3 inches of lift.
    If you do, here are things to consider. If you run front mud flaps, it may rub on these, and you might have to take them off (the stock mud flaps have a weird hump on them that sticks out, thanks toyota..). Also, if you still have rubbing you could try a spacer (like a Spidertrax 1.5 wheel spacer) that would offset a bit more and may clear up rubbing issues. Worst case, you may have to trim the front or rear internal plastic a bit...worse case, do the Cab Body Mount Chop mod...but with 32s, you should be ok.
  8. Mar 20, 2019 at 11:05 AM
    psyWAR1988
    Correction 1.25 wheel spacer. Also, mine are bigger at 275/70/17 so I had some rub...if you go with a size that @Dimestore55 mentioned, should be ok.
  9. Mar 20, 2019 at 11:36 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    My 4x4.jpg NITTO TRAIL GRAPPLERS LT285/65R18 ( 32.83 X 11.93 )
    FUEL HOSTAGE 18 X 9 WITH -12 OFFSET
  10. Mar 20, 2019 at 11:44 AM
    15TACOSPORT4X4
    Stan
    Trying to figure out how to add a pic of my truck. Where on TW do they explain this.
  11. Mar 20, 2019 at 12:04 PM
    psyWAR1988
    When you are replying, click where it says upload a File. Then upload it from the computer, and click full image not thumbnail. Post and voila.
  12. Mar 20, 2019 at 12:18 PM
    15TACOSPORT4X4
    Stan
  13. Mar 20, 2019 at 12:38 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Ultra 107 wheels,Falken A/T tires 255/85/16
  14. Mar 20, 2019 at 12:44 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    255/85r16 Cooper ST-MAXX, 16x8" Pro Comp 31 Series rims. 3" OME lift when I have the right alignment specs there's no rubbing.
    BassAckwards likes this.
  15. Mar 20, 2019 at 12:46 PM
    psyWAR1988
    Well you sure arent rubbing on a stock front bumper thats for certain..AMIRITE! Really tho, no rub on the cab mounts at all?
  16. Mar 20, 2019 at 12:48 PM
    Beretta4x4
    Josh
    Temple, TX
    No rub on the cab mount unless I'm wheeling with caster set below 2°. Killed a mud flap though lol. That was with the stock bumper. I just got the ARB two weeks ago.
  17. Mar 20, 2019 at 2:25 PM
    spazjensen
    spazjensen Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    OP asked about wheel setup as well, which im trying to figure out to. With a three inch lift what offsets could he run without any cutting or banging? Does a -12mm offset require any trimming or could an 18mm offset be ok as well?
  18. Mar 20, 2019 at 2:29 PM
    KJP
    KJP Well-Known Member
    Kevin
    2013 Tacoma DCLB
    Elka coilovers, supercharged, 4.56 gears, ARB front and rear, 255/75/17 BFG, other stuff that weighs a lot
    First gen rims with some paint and 265's. First gen rims have slightly less backspacing so they stick out more, which is what I wanted. Cheap and aluminum, and looks good IMHO.
  19. Mar 20, 2019 at 2:33 PM
    psyWAR1988
    The more - negative offset you have the further IN the rim is where the mounting surface is located that contacts the hub, and inevitably less actual rim metal is under the well 9IE the rim protrudes MORE) . The more + positive offset means the mounting surfarce is closer to the rims outside edge, meaning more metal under the well, and less outward rim protrusion. YOu have to look at your set up, find out what your current offset is (on stock rims I am assuming), and determine if moving offset ( -/+ )ie (rim out/or rim in) you want/need or can afford due to how much space you have currently.
    tacofish likes this.
  20. Mar 20, 2019 at 2:35 PM
    psyWAR1988
    He is right, but to clarify, when he says "less backspacing" he means going towards center or into negative, which means more sticking out.
    EX: +30 offset and going to +20 offset is "less backspacing", but its still positive of the centerline where rim backspacing measuring starts, but the 20 will protrude more than the 30, but not more than a 0 or negative offset wheel which will protrude a LOT more.
