Best rear brake drums and shoes for Tacoma...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jpugh2003, Mar 14, 2019.
  1. Mar 14, 2019 at 5:51 PM
    jpugh2003
    jpugh2003 [OP] Well-Known Member
    James
    2019 Silver Tacoma SR5 RWD
    So Toyota seems to have problems with their brake drums warping prematurely. So what are the best aftermarket brake drums and shoes that ya'll have had through experience?
    El_Taco_Blanco likes this.
  2. Mar 14, 2019 at 5:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yours is the first I have read about since I joined a few years ago. Most drums are lasting 70K+ from what I've read. Do you tow a lot?
  3. Mar 14, 2019 at 6:27 PM
    jpugh2003
    James
    I do not. My first 2019 SR5 had warped drums in the rear and most vibration threads I've read talk about warped drum problems on new ones all the time. But I figured since they are cheap on sites like CAID.com, I get some really good ones and shoes.
  4. Mar 14, 2019 at 7:20 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Understood. Even if you read one hundred threads on bad drums remember there are close to a million 3rd gen tacomas now. It's all about scale.
    Good luck I hope you get rid of the issue!
  5. Mar 15, 2019 at 8:23 AM
    El_Taco_Blanco
    El_Taco_Blanco Well-Known Member
    New Mexico
    2018 TRD OR DCSB
  6. Mar 15, 2019 at 8:42 AM
    laskdjn
    laskdjn Well-Known Member
    2019 Tacoma SR Access Cab 4x4
    I just had the drums replaced on my truck last week on warranty.
  7. Mar 15, 2019 at 9:06 AM
    18TRDOR
    18TRDOR Well-Known Member
    Kyle
    New Philadelphia, OH
    2018 TRD OR DCSB 6MT
    I don't know of any "high performance" drums or of any drums that could potentially withstand heat a little better but one option would be to have a very light machining pass done on a new drum to true everything up then, do a cryogenic treatment to help strengthen the steel. Just my .02 but I'm interested in hearing what has worked for others because I can feel a light vibration coming the rear brakes on my truck after 14k miles.
  8. Mar 15, 2019 at 9:09 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    OEM lasting 100k+ miles seems pretty damn good to me.
    Warped isn’t common, I’d replace with OEM and forget it.
    Paul631, whatstcp, hiPSI and 3 others like this.
  9. Mar 15, 2019 at 9:15 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Drill cooling/venting holes in them for efficiency
    ohcaltexscar, whatstcp and Hootbro like this.
  10. Mar 15, 2019 at 9:19 AM
    woodsbuggy3
    woodsbuggy3 Member
    NE Ohio
    18 OR MT
    I had a very similar problem with my 2nd gen. Turns out the tire shop was overtorquing the lugs distorting the drums.
  11. Mar 15, 2019 at 9:25 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Mine were replaced under warranty and the vibration came back right after the shoes wore in. I bought aftermarkets and had the same issue. There's something else going on other than just warped drums.
    I ended up reinstalling the oems and then backed my adjusters off a little bit. The vibration is much better. I've heard of others saying that the dealer said their brakes were adjusted "too tight". I have a theory that the rear brakes cause the drive shaft angle to change just enough to cause driveline vibration... but who knows...
  12. Mar 15, 2019 at 9:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    Brake drums don't warp. But even if they did, wear items like brakes are not warranty items.
    So if it was 'warped', it's on you. But its a manuf. flaw, thus the warranty applies.
    The warranty replaced drums are actually out of round; made wrong by the supplier.
    hiPSI likes this.
  13. Mar 15, 2019 at 9:41 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    I'd like to hear more about cryogenic treatment to strengthen cast iron
  14. Mar 15, 2019 at 11:53 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    On some 3rd gens the axle flange is warped, causing run-out. Even if the drum was concentric, if it's mounting to something warped, it'll be out of round too.
    Cl4aub likes this.
  15. Mar 15, 2019 at 3:07 PM
    jpugh2003
    James
    Much better vibrations as in less?
  16. Mar 15, 2019 at 3:32 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I had a rear drum replaced in the first 10k, but it was due to over torquing not a faulty part
    jpugh2003[OP] likes this.
  17. Mar 15, 2019 at 3:34 PM
    jpugh2003
    James
    Mine happen between 20-30 mph and sometimes without the brakes, like acceleration or coasting. Other speeds the braking seems fine and smooth.
  18. Mar 15, 2019 at 3:58 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    From my experience, when it comes to drum brakes, go OEM for the drum, pads and hardware. The biggest problems I have had in about the 8 or so drum brake jobs I have done in my life, have always been with aftermarket drum parts.
    Paul631, whatstcp and Skydvrr like this.
  19. Mar 15, 2019 at 4:10 PM
    jpugh2003
    James
    Do you feel vibrations in steering wheel between 20-30 mph on your 19?
  20. Mar 15, 2019 at 4:17 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    Nope, rides smooth
