Best ratchet straps?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by particleman, Nov 17, 2016.
  1. Nov 17, 2016 at 11:20 AM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    I also use Ancra straps - the ones with the built-in soft tie. Ancra makes really good stuff and they will last a lifetime.
    They can be readily found on Amazon...
  2. Nov 17, 2016 at 12:02 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
  3. Nov 17, 2016 at 12:34 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    THIS ^^^^
  4. Nov 17, 2016 at 12:42 PM
    DRJ1014
    DRJ1014 Well-Known Member
    CA
  5. Nov 17, 2016 at 9:22 PM
    Ice8
    Ice8 Well-Known Member
    Vancouver, BC
    2017 MGM Tacoma TRD Off Road SB
    A few listed in the signature
    Same here, I got them at Costco in Vancouver B.C. for $30 or so.
    TacomafromTacoma likes this.
  6. Nov 18, 2016 at 8:57 AM
    Mtneer
    Mtneer Active Member
    Another handy strap is the Rok Strap brand bungee cord, I use them on my motorcycle to secure my tool pouch or for extra security when I use the a tail pack that has built in bungees. They come in different strengths and lengths, are adjustable, they may cost a bit more but just like an Ancra brand strap they seem to work well. When you're hauling something expensive or a load that requires the tailgate to be down, you don't want to skimp on a budget tie down, the extra cost of a quality product is nothing if you lose an item or if piece of furniture goes flying out the back of your truck and someone hits it.
  7. Nov 18, 2016 at 9:01 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I bought a set of 4 SnapOn straps, from Sam's. they are nice. The handle has rubber, which makes it comfortable to really crank down on the ratchet. the strab itself is a nice width, which prevents the strap from digging into whatever it is you are strapping down.
    They were, like, $19.99, or something like that.
  8. Nov 18, 2016 at 9:08 AM
    taco206
    taco206 Well-Known Member
    Costco and Sam's Club usually carry a nice 4 pack for like $22. they are medium size, not too big not too small. I have strapped cars with them. during Christmas time home Depot has a nice little 8 pack of ratchet tie downs for $10!.
  9. Nov 18, 2016 at 9:11 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    I personally like to have some heavy duty 3" wide freight straps, and a series of light duty 1"wide "throw away" ratchet straps.
  10. Nov 18, 2016 at 9:14 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I use 3" wide nylon straps made for strapping down cars and trucks for everything. I've had too many of those cheap ones break from abrasion or Chinese metal.
  11. Nov 18, 2016 at 9:50 AM
    TacomaBandit126
    TacomaBandit126 Well-Known Member
    Santa Ana, CA
    17 Toyota Tacoma TRD
    Harbor Frieght. I got 4 500 pound load hatchet straps for 10 bucks and 2 camdown ties for 5
  12. Nov 18, 2016 at 9:54 AM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Adding d-rings in the bed bolts adds strong tie down points. first mod I did to each of the three Tacomas I've owned. the dodge rings are plug and play.
    https://www.tacomaworld.com/threads/installed-d-rings-in-the-bed-pics.28533/
  13. Nov 18, 2016 at 9:57 AM
    Aw9d
    Aw9d That one guy
    I got some Snap-on's from Costco. Ended up getting a 4 pack on sale for $20. Super beefy.
  14. Nov 18, 2016 at 11:49 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    https://www.cpsc.gov/Recalls/2016/Alltrade-Tools-Recalls-Ratcheting-Tie-Downs/
    These the ones you got?
  15. Nov 18, 2016 at 11:56 AM
    #35
    User Name01
    Bolbi Stroganovsky
    CusterFan[QUOTED] likes this.
  16. Nov 18, 2016 at 11:57 AM
    #36
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I honestly buy the cheapest because they all break or tear so I gave up.
    If I had to recommend some, try to find some Air Force Cargo straps, they are 5k lb rated and rarely break. Zync plated I believe but if they can handle air drops, mud drags and general abuse they will work for you.
    EDIT:
    Found them for you.
    https://www.amazon.com/Cargo-Strap-5000-Lb-Capacity/dp/B005E0SOJ0
    Toyko Joe likes this.
  17. Nov 18, 2016 at 12:29 PM
    #37
    NotrailsinVA
    NotrailsinVA Member
    logan
    2017 toyota tacoma TRD Off-Road
    Fox 2.5 extended remote w/total chaos uppers up front. Fox 2.0 extended remote w/ deaver leafs in rear. ECGS swap. 285/75/16 wild peaks
    We use these at work, they work great! Just remember to WD-40 the ratchet mechanism to prevent corrosion for longevity.
    Spare Parts and CusterFan like this.
  18. Nov 18, 2016 at 1:10 PM
    #38
    CusterFan
    Those work well. I use to strap down heavy duty pallets of 8" Howitzer rounds with these in the back of a M520 Goer.
    Wish they made them in 10' lengths. I know you can cut them off!
  19. Nov 18, 2016 at 1:25 PM
    #39
    CusterFan
  20. Nov 18, 2016 at 1:35 PM
    #40
    taco206
    I have "snap on" ones that have red straps, not yellow. And yellow ones branded good year. obviously these aren't real snap on products just licensed under their name. like the bullshit little snap on China generator. Maybe after some recalls Snap On will reconsider their business model.
