Best rainguards?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maine_Tacoma13, Jun 25, 2019.
  1. Jun 25, 2019 at 5:39 AM
    Maine_Tacoma13
    Maine_Tacoma13 [OP] Well-Known Member
    What have you guys purchased for rain guards? I'm looking into getting some but not sure what some quality ones are. Pics would be great too!
  2. Jun 25, 2019 at 5:42 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    I have avs in channel. They're pretty good, they work as well as you would think they do, as long as its not raining sideways it keeps your windows decently dry so you can see in the rain. And if you want your windows down in the rain they keep some of the rain out.
  3. Jun 25, 2019 at 5:47 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Is a rain guard the same thing as a window deflector?
    Weathertech
  4. Jun 25, 2019 at 5:48 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    I have AVS in-channel as well. I bought the external stick on kind, but didn't like they look, so they are just sitting in my garage.
  5. Jun 25, 2019 at 5:48 AM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    Those look better than mine
  6. Jun 25, 2019 at 5:54 AM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    Not sure if quoting from a different thread works, BUT....
    These are on my truck, AVS in-channel low profiles. Love them and they help tremendously to keep the truck cooler here in Florida. Haven't had any rain enter the lowered window with these installed.
    Jak53 likes this.
  7. Jun 25, 2019 at 6:01 AM
    trajiiic
    trajiiic Well-Known Member
    I got the weathertechs and managed to break off some of the plastic into my door when trying to get them to work without the window going down automatically. Ended up getting the AVS in channel rain guards. After about 3 weeks in the TN heat they close perfectly every time. But they would only close intermittently before 3 weeks.
  8. Jun 25, 2019 at 7:00 AM
    usernotfound
    usernotfound Well-Known Member
    Brandon
    CO
    '20 4Runner TRD OR
    Probably a dumb question, but has anyone had any issues with the in-channels scratching tint or causing it to peel at the edge? It's entirely possible that I simply don't understand how these are installed, so this might be an irrelevant concern.
    Quicksander17 likes this.
  9. Jun 25, 2019 at 7:02 AM
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    No problems at all. I have 25% tint on my driver and passenger side doors and have no peeling of tint at all.
    usernotfound[QUOTED] likes this.
  10. Jun 25, 2019 at 7:04 AM
    kiett
    kiett Well-Known Member
    South Carolina
    15 TRD PRO & 94 Hardtop Turbo MR2
    The in Channels are contact the outside of the glass, tint is on the inside. The rubber seals should be able to rub the tint without removing it since it pinches it a little bit more.
    VaToy likes this.
  11. Jun 25, 2019 at 7:04 AM
    THE_KiRRAx
    Tampa, Florida
    Due to the rainguard being on the opposite side of the glass as the tint there should be no contact between the two. The only problem that MIGHT arise depending on the product you purchase is the added tension between the glass and the inner window track at the top but if the tint was install good then it shouldn't cause any issues at all.
  12. Jun 25, 2019 at 7:05 AM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
    Tint is applied on the inside of your door glass. The outside of the door glass is what comes into contact with the in-channel deflector. It would be impossible for the deflector to touch the tint.
  13. Jun 25, 2019 at 7:07 AM
    Airborne22
    Airborne22 It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    AVS Low-Profile, in channel, flat black. Love em!
    BroHoGrow, SR-71A and Sgt.Tee like this.
  14. Jun 25, 2019 at 7:23 AM
    THE_KiRRAx
    Tampa, Florida
    Something to note:
    The AVS in-channel low profile window vents attach via a strip of adhesive to the outer most inner seal of the window. They are very secure but can't comment on how well they remove without damage to the seal if you ever needed to take them off. Material is thinner and more flexible. Looks as though they are more injection molded type of manufacturing. I own these and love them.
    The weathertech in-channel window vents attach (only have experience with these on three other make vehicles) via pressure and tension only, no adhesive (usually). They can be a bear to install at times but hold very securely in place. They are a bit thicker and rigid. They give the impression of an acrylic heat formed, then machine to finished specs type of manufacturing.
    Both are great products, can't comment on the actual Weathertechs for Tacomas though.
    BroHoGrow and SR-71A like this.
  15. Jun 25, 2019 at 7:40 AM
    Kev757
    Kev757 Well-Known Member
    2018 Tacoma TRD PRO MT
    I had Weathertech in my old truck and loved them. Looked great and made in America!
  16. Jun 25, 2019 at 7:50 AM
    kiett
    South Carolina
    When looking for mine I wanted a couple things:
    1: good quality
    B: inchannel
    III: flush with vehicle (no poke)
    5-1: relatively good price
    It lead me to buy EGR inchannels
    Had the low profile avs they felt cheap and returned them before I even put them on.
    Was going to get the weathertechs but hated how big the channels were in the corner almost blocking the side view mirrors. They don’t use any tape in the front just the rears. To me it’s just made sense and also about half the price of weathertech ones to boot!
  17. Jun 25, 2019 at 7:57 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Had AVS on my 2001. Eventually the adhesive will fail and they just free-ball in the channel, but did stay in place.
    Have WeatherTechs now on the 2015 and they are holding up just fine with pressure only.
  18. Jun 25, 2019 at 7:59 AM
    Somebeach
    Somebeach Active Member
  19. Jun 25, 2019 at 8:03 AM
    CarverLB
    CarverLB Who Dat?!
    Bryan
    Long Beach, Mississippi
    2021 Trd Sport 4x4
    I have AVS in channel and I also had the paint matched. I haven't had any issues.
    Jak53, RangerComa and THE_KiRRAx like this.
  20. Jun 25, 2019 at 8:05 AM
    THE_KiRRAx
    Tampa, Florida
    Oh god I can attest weathertechs aren't moving, ever. Hurricane could come and those wouldn't vibrate, they are held in place strong. Gotta brute force those bad boys in but definitely aren't going anywhere after that.
    The AVS were already on my truck when I bought it but I kinda prefer them over weathertechs due to the solid black and low profile. They are two completely differently materials though, each have own pros and cons I think.
