Best phone mounts for Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patrickday, Jan 12, 2019.
  1. Sep 7, 2022 at 5:41 PM
    #221
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    That's where I have my gps mounted.
  2. Sep 8, 2022 at 8:38 AM
    #222
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Yep, the "pillar mod" can be used for quite a few things. Like @HawkShot99 and I'm sure many others, mine has a dedicated GPS there. For my phone, I use the Panavise. Both make for convient access and viewing.
    stbear likes this.
  3. Sep 8, 2022 at 10:24 PM
    #223
    NDTRD
    NDTRD Active Member
    15 DCSB TRD OR
    ma2co likes this.
  4. Dec 2, 2022 at 7:20 AM
    #224
    ma2co
    ma2co Active Member
    Nebraska
    '13 dcsb trd off road w/tow package
    I love the Offroam as well. It's solid, does not block the vent, can still adjust them from side to side, and can close it some but not all the way, which works for me.
    BraddahRO, NmapFE and Bluebros like this.
  5. Dec 2, 2022 at 8:59 AM
    #225
    HawkShot99
    Kingston, NY
    When I had a phone mount in front of a vent it worked great in the summer, but caused overheating during the winter. Even when I had the heat set on windshield defrost enough air came out the vent to overheat my phone.
  6. Dec 2, 2022 at 11:06 AM
    #226
    ma2co
    ma2co Active Member
    Nebraska
    That wouldn't be fun. I haven't had that problem in the past and this Offroam keeps my phone further away from the vent than the previous generic holder I was using. First winter with it. I also tend to place my phone in there with more of it extending on the top end. But yeah, I wouldn't be a fan if its placement was impacting my phone's performance.
  7. Feb 12, 2023 at 3:16 PM
    #227
    Waasheem
    Waasheem
    2007 xrunner
    I’ve had several. Currently I don’t have a phone mount in the Tacoma. I plug it in, it pairs to the head unit and I put it in the cubby forward of the shifter. Since I don’t drive it much it hasn’t been a problem. But on longer drives, the cubby gets hot enough to get the phone hot and stop working.
    This one sorta worked in the Tacoma, I replaced the cd slot thumb screw with a bolt and nut so I could shove it in the cd slot and tighten until it made a cracking plastic noise. It still had to constantly be shoved in tighter or it would work itself loose and fall out.
    https://www.amazon.com/gp/product/B07PWS5WJC?ie=UTF8
    This one, another stupid design, used gravity for the lower arm to rest against something. You hit a bump it would jump up and down throwing the phone out.
    https://www.amazon.com/gp/product/B00LPM9IBO?ie=UTF8
    This one is the same brand as the previous, a well designed cradle. I made it just loose enough to slide the phone in and out. It was able to hold it in over bumps unless the bump was extreme enough to slam the top of my head against the roof. I didn’t use the vent mount, instead took it apart and screwed a piece directly to my work truck dash. It lasted over 5 years, ended up breaking when I tried to remove it.
    https://www.amazon.com/gp/product/B00UJGVIK6?ie=UTF8
    This one I’m using in my work truck now. Ram mounts are excellent but takes 2 hands.
    https://www.amazon.com/gp/product/B00JUW8Z1K?ie=UTF8
    Offroam makes what looks like a good vent mount option that doesn’t clip to the vent, it clamps into a corner. But the odd sized 20mm ball isn’t going to work with Ram mounts. I don’t like the squeeze the sides cradle.
    https://getoffroam.com/products/air-vent-ball-mounting-base-toyota-tacoma-2nd-gen-2005-2011
    I read through every page. Some are no longer available.
    So I’m thinking I could use the Offroam mount with a Macally cradle and maybe some Ram balls and arms.
    I’m curious if anyone has already tried doing something similar.
  8. Feb 12, 2023 at 3:36 PM
    #228
    Days_last
    Days_last Active Member
    '08 4.0 DCLB
    Great until your phone over heats and turns off. I have yet to find a more convenient mounting location though, so my phone stays hot, lol.
  9. Feb 14, 2023 at 6:38 PM
    #229
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    I rock a Nite Ize magnetic ball mount. Flat metal disc attaches to the back of the phone/case, ball mount adhesive to the dash or flat surface. All u gotta do is slap it up there & be done. Theres a rubber insulator in between that helps u angle or swivel it however u want and it stays put even in rough terrain. I have a mount ball in all my cars so it doesnt matter which one i get into. Super easy and u can but the pieces individually if needed on Amazon. 68DA8967-68CA-4D18-AB36-84F38EEBB5DC.jpg
    stbear likes this.
  10. Mar 12, 2023 at 6:52 PM
    #230
    ma2co
    ma2co Active Member
    Nebraska
    Decided to post this pic since people keep talking about their phones overheating. Not really sure how people are mounting them. Been using it all winter without problems.
    NmapFE and Days_last like this.
  11. Mar 12, 2023 at 7:12 PM
    #231
    6 gearT444E
    Deep South
    Herculiner Hootus
    I just installed my offroam today and so far so good. Really tight grip on the phone and mount feels sturdy.
    ma2co likes this.
  12. Apr 9, 2023 at 12:28 PM
    #232
    Waasheem
    Waasheem
    2007 xrunner
    Offroam seems to be the best option as far as the mount base goes. I don’t care for window suction cups, cd slot, cup holder or pinch the vent types. If I decide I don’t like the phone cradle, I could try getting creative and build my own Frankenstein setup. I like the macally cradles. The ram cradle is secure but I don’t like needing 2 hands to mount or dismount.
  13. Sep 27, 2023 at 7:41 AM
    #233
    15ACOR
    15ACOR Well-Known Member
    2015 TRD OR
    I did the pillar mount w the x-grip. For a larger phone w an otter box it is absolute garbage. The phone would be more secure in a toddler’s hands.
  14. Sep 27, 2023 at 1:09 PM
    #234
    Elkhart
    Elkhart Well-Known Member
    Anthony
    New England
    2013 TRD Sport DblCab Long Bed, Mica Silver
    Stock
    New to the forum good to be here, first tacoma (2013 trd sport in Silver Mica)
    Researched a bit and after a couple of weeks of throwing my phone in the cup holder I picked up the Hondo Garage 'Un-Holey dash mount' to pair with the Ram 'quick grip phone holder' Very happy with both.
    Opted not to do the A pillar mount since it felt odd as a righty, and then in reading the user manual, found out left side phone/gps mount not advised due to the Driver side airbag in the pillar.
    SilverBulletII likes this.
  15. Sep 27, 2023 at 4:13 PM
    #235
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I have an Off-Roam as well. It's expensive, but I love it. Best phone mount I've used yet. Holds up well to aggressive wheeling as well.
  16. Sep 27, 2023 at 5:06 PM
    #236
    Waasheem
    Waasheem
    2007 xrunner
    I did get the offroam. It’s decent enough to use. One hand on and off. I figured out putting the cradle upside down works better. Cons: if I have the heater on, even with it set to blow at the floor, enough hot air comes out to overheat the phone.
    The ram mount in my work truck is also decent enough to use. Cons: If I bump it, it twists. 2 hands required for on and off. The rubber grabbers wore out but replacements are cheap. https://www.amazon.com/gp/product/B00BTFIEJO?ie=UTF8&th=1
    I
    had a macally mount which was my favorite. Slide it in slide it out. No squeezing or anything required. They changed the design so the one I had is no longer available, similar to this one. https://www.amazon.com/gp/product/B00UJGVIK6?ie=UTF8
  17. Sep 27, 2023 at 5:22 PM
    #237
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
  18. Sep 28, 2023 at 12:21 PM
    #238
    Elkhart
    Anthony
    New England
    Stock
    Check out the RAM quick grip for a one handed on and off. I swapped out mine from a RAM X-Grip for the same reasons and it's while it's plastic, and requires some assembly (screwing in posts, and attaching ball mount), it feels well built.
    https://www.amazon.com/ram-mount-quick-grip/s?k=ram+mount+quick+grip
  19. Sep 28, 2023 at 6:37 PM
    #239
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    I've gone through the x-grip and the quick-grip and wasn't a fan of either (if anyone is interested I've got both I'll sell for cheap). Now I use this and its the best so far. One hand function. Solid grip. They make the mount in different strength spring options for both mellow driving, and all out sending.
    Tackform Enduro 25LITE Phone Holder - Spring Tension Optimized for in Vehicle Use, Truck and Fleet, Rock Crawling - Compatible 25 Series Products - 25.4mm Rubber Ball https://a.co/d/9Xymt9r
  20. Oct 2, 2023 at 6:29 AM
    #240
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    I’ve tried sooo many phone mounts over the years. By far, this is the one I have had not a single issue with long term, off road, or daily driving … works great with my iPhone with a thick case . Has never fallen off. Just my experience with it.
    UPDATE: 2 years strong and not one issue
    batcat420, jackn7 and ma2co[QUOTED] like this.
