BEST PENETRATING OIL
Discussion in 'Technical Chat' started by JAMES399, Jun 22, 2017.
  1. Jun 22, 2017 at 8:01 AM
    JAMES399
    JAMES399 [OP] EL CAPO
    JAMES
    Alejandria Antioquia Colombia S.A.
    White 2003 Hilux DCSB 4x4 HI-RIDER +. 2.4L I-4, 5 spd.
    275/70R16 tires, gasolina or CNG fuel, Konig shox, Energy Suspension poly bushings,
    I have seen a reference to this "home-brew" penetrating solution in some other threads on the forum.
    Practical Machinist Mag™ recently published some information on various penetrating oils that I found very interesting. Some of you might appreciate this.
    The magazine reports they tested penetrates for break out torque on rusted nuts. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a “scientifically rusted” environment.
    Penetrating oil .......... Average Break-out Torque
    None ........................... 516 pounds
    WD-40 ..................... ... 238 pounds
    PB Blaster .................... 214 pounds
    Liquid Wrench ............... 127 pounds
    Kano Kroil .................... 106 pounds
    ATF-Acetone mix...............53 pounds
    The Automatic Tranny Fluid-Acetone mix was a “home brew” mix of 50 - 50 automatic transmission fluid and acetone. Note the “home brew” was better than any commercial product in this one particular test. Also notice that Liquid Wrench was almost as good as Kroil for less than 1/2 the price.
    I have used this mixture for years. Carried a spray bottle of it in my truck. I was an in-home appliance repair tech for 30+ years, and this stuff saved my ass many times getting rusted nuts or bolts off of a washer, dishwasher, whatever. A 50-50 mix of ATF and lacquer thinner works equally well. BE CAREFUL when using it around paint though.
    - JAMES
  2. Jun 22, 2017 at 8:05 AM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    I remember that info years ago. There is a video of someone putting force against a bearing if I recall to demonstrate.
    ATF has such an awful stink though that just last but that thinner may kill it though.
    thanks for posting the info.
  3. Jun 22, 2017 at 7:37 PM
    red79cj7
    red79cj7 Well-Known Member
    Middle GA
    2016 DCLB 4x4 TRD OR & 2011 DCSB TRD OR
    2016 - Toytec 3" Coil & AAL Lift, 265/75/16 BFG KO2s, 100XQ Topper w/Thule Tracker II Racks, Pop N Lock Tailgate Lock 2011 - Leer 100XQ Topper w/Thule Tracker II Racks, Pop N Lock Tailgate
    Best bang for buck of regular store bought stuff I have found is Liquid Wrench.
    I have been through quite a bit of it "wrenching" on my 38 year old '79 CJ.
    It hasn't let me down yet.
  4. Jun 22, 2017 at 7:40 PM
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    Been using PB Blaster for years and think it's the best. Other than that you can soak just about anything in diesel fuel overnight and it'll break loose.
  5. Jun 23, 2017 at 11:14 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I hear the down side to the ATF /Acetone mix is it does not store well otherwise it would be sold .
    Is this true??
    I happen to like Kroil but have used them all over the years
    Arctic Taco likes this.
  6. Jun 23, 2017 at 11:44 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ATF/acetone stinks ? what, and PB blaster doesn't ?
    anyhow, all good info.
  7. Jun 23, 2017 at 1:22 PM
    Flytmech
    Jase
    Geneva Alabama
    We used kroil in my FBO for a few years, switched to PB Blaster because we couldn't tell much difference between the two and PB seemed to be easier ro find and cheaper.
  8. Jun 23, 2017 at 2:58 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Kano Labs had a Super special here back maybe 10 years ago
    I think I bought 10 cases split between a few of there products
    A few gallons
    Some of the smaller cans and some of the larger ones
    I will more then likely still have enough for quite some time yet
  9. Jun 23, 2017 at 3:05 PM
    J.M Taco
    J.M Taco Well-Known Member
    Central California
    '17 Tacoma Quicksand DCSB TRD OR 4x4
    We use Schaffers Penetro 90 at work and swear by it. We've tried some of the other easily accessible brands like Kroil, PB Blaster, Liquid Wrench, etc. but the Penetro is what we keep going back to.
    Only downside is that it's not readily available at most auto part or box stores.
    http://www.schaefferoil.com/penetro.html
  10. Jun 23, 2017 at 3:10 PM
    Clearwater Bill
    Billy
    Largo Florida
    Do NOT make the mix with laquer thinner. No where near the same properties as acetone, and it is not included in the age old list of tested products either.
    Often just straight ATF will work well. But I find Kearney Rust Buster pretty reliable
  11. Jun 23, 2017 at 6:01 PM
    JAMES399
    JAMES
    As long as you keep it in a sealed container, storage is no problem. When I was working in a tight area, and had to use a wrench w/o much leverage, the ATF/Acetone saved the day for me many times. I like RUST BUSTER too. Comes in a squeeze bottle with a long nozzle which is handy.
    - JAMES
  12. Nov 27, 2018 at 8:58 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Kroil,
    sea foam(?)
    Liquid wrench
    Stryker420 likes this.
  13. Nov 27, 2018 at 8:59 AM
    hallux
    hallux Well-Known Member
    Spit.
    Oh wait, not that kind of penetrating oil.
    I've had best results with PB Blaster on my 67 International Harvester.
  14. Nov 27, 2018 at 9:00 AM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Kroil or PB blaster...
  15. Nov 27, 2018 at 3:15 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I've used everything except the ATF/Acetone mix. Of those, I prefer Kroil, but all of the others are fine.
  16. Nov 27, 2018 at 3:41 PM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Best initial answer so far. Every time I bust out the Kroil, my wife gives me the O face lol
  17. Nov 27, 2018 at 3:47 PM
    relkins0413
    relkins0413 Well-Known Member
    Kings Mountain, NC
    2013 Silverado 2500HD Duramax
    Interesting I have never heard of the atf/acetone mix. Have always used Kroil both at home and in industrial environments at work. Love the smell and it works great. PB blaster is a close second for me.
  18. Dec 21, 2018 at 4:45 PM
    kalaukoa
    kalaukoa Well-Known Member
    Kailua
    2011 TRD OR 4x4 Access Cab
    I have used the ATF and Acetone mix. IMO it works better than PB Blaster, WD-40, and Liquid Wrench.
  19. Dec 21, 2018 at 4:48 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  20. Dec 22, 2018 at 12:18 PM
    Rosa Klebb
    Rosa Klebb Member
    Tucson, AZ
    2012 4X4 Access Cab
    Still Thinking ? ? ?
    What type of container do you use for your ATF/Acetone home brew?
