Best Parts Store for Brake Parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by CrippledOldMan, Jul 22, 2020.
  1. Jul 22, 2020 at 11:01 PM
    CrippledOldMan
    CrippledOldMan [OP] Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I pretty sure that my front rotors are warped, since I can feel them shimmy when I hit the brakes. At some time this year, I'm going to work on them, and If possible, get the rotors turned. There's only on parts store here in Salisbury N.C., that I can find that still does that.
    In the event, that they can't be turned, which parts store has the best brake parts. Buying from a stealership isn't any option, since their so way over priced. So fellow TW members, who has the best parts for the money, Rock Auto, Parts Geek, O'reilly, Auto zone, Advance, Napa. I just want to get the best parts I can get for the money. Really appreciate any input.
  2. Jul 22, 2020 at 11:05 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Rotors are cheap, I just put on a set from oriellys, get parts at cost plus tax. They are fine so far.
    Also check your lower control arm bushings, they can cause a similar sensation.
  3. Jul 22, 2020 at 11:13 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @Old green toyota , I hope it's not the control arm bushings, since I just had a 4 wheel alignment done, and they told me everything looked good.
  4. Jul 23, 2020 at 12:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No real 4 wheel alignment for our trucks seeing as how the rear is a solid axle.
  5. Jul 23, 2020 at 1:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Any more if I don`t use Toyota I will go with Napa if they send the wrong parts or I order the wrong numbers returns are easy.
    Most rotors are so easy to swap and the price has dropped so low along with quality it is not really cost effective to turn them.
    Shops all used to have the equipment to cut rotors and drums not so any more add in the added time to send them out adds more time and expense.
    The old ones make great bases for stands.
    jackn7 and Taco critter like this.
  6. Jul 23, 2020 at 6:24 AM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    I buy off Rock Auto, my local parts store tends lack inventory.
    But my advice, if you front caliper are old & crusty... I would look into buying a Powerstop complete kit that includes new calipers, rotors and pads.
    billybop90 likes this.
  7. Jul 23, 2020 at 6:32 AM
    ElTaquitoJr
    ElTaquitoJr Well-Known Member
    01 Tacoma PreRunner 4 cyl
    I would run into warped rotors pretty often until I swapped out my break calipers and rotors for tundra parts.
    Might be something to consider. The replacement rotors I used were from auto zone.
  8. Jul 23, 2020 at 12:29 PM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Is power stop better than ebc? I have the same problem and was considering buying ebc rotors and pads. Sorry, not trying to hijack your thread op.
  9. Jul 23, 2020 at 1:09 PM
    mattvivsound
    Southern MD
    I never used ebc pads... but those who have, they're comparable. I was suggesting the powerstop kit because it comes with calipers (no core charge).
    jackn7[QUOTED] likes this.
  10. Jul 24, 2020 at 8:01 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Not a problem were all in the same boat here. Trying to learn, and get the best bang for our buck.
  11. Aug 25, 2020 at 8:37 PM
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I wound up going with the Powerstop Z36 kit and couldn't be happier!
  12. Aug 26, 2020 at 1:04 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Better brakes are always Good !
    If I was working on a Fun Vehicle that I would not be really put out waiting 3 to 5 days for parts
    I like being able to call in the afternoon and everything I need shows up by 10.00am
  13. Aug 26, 2020 at 1:12 AM
    deadpocketss
    deadpocketss Dingus
    Ian
    Colorado Springs, Colorado
    '24 Subaru Crosstrek Premium
    RockAuto or Amazon is always cheapest for me. Definitely shop around though.
    I usually get PowerStop. Z17 is fine for OE replacement and Z23 is good if you need a little more stopping power. IMO Z36 is pretty overkill unless you're towing often.
  14. Aug 26, 2020 at 1:38 AM
    Krogers128
    Krogers128 Well-Known Member
    Kyle
    WA
    1995.5 Paradise Blue Tacoma SR5 V6
    OME complete kit. 881 coils. Dakar Leafs. JBA UCA. 265/75-16 Goodyear Ultraterrain.
    I got a set from summit racing, EBC Green Stuff pads with their OE replacement style. Pretty happy overall. Got to my house in two days.
    CS_AR likes this.
  15. Aug 26, 2020 at 4:04 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    There is a rating code on brake pads to indicate stopping power that is assigned by DOT testing. Nothing magic.
    A brake pad with OEM stopping power will have a FF braking coefficient. Most of the top-shelf parts store brand pads are FF rated.
    Pads with the most breaking power are rated GG.
    In between OEM FF and the top GG is FG. -- Wagner Thermoquiet with the integrated shim for Tacoma only is an example of FG pads.
    EBC Green is GG
    The last time I bought a bunch of products to record the stopping coefficient was last year. EBC green pads are rated GG.
    Some Bosch Pads are rated GG
    Toyota OEM is rated FF
  16. Aug 26, 2020 at 4:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Rotors don't warp. I'm sure someone will want to argue that point. I'm not going to do that because you can read the white paper on the topic on StopTech's website.
    What you are feeling is excess pad material that has collected on the rotor face, causing the caliper to pulse as the rotor rotates.
    IF the rotor is in good condition otherwise (exceeds min thickness stamped on it's edge measured at the deepest groove) try cleaning it with brake cleaner and scotch brite pads. The ones that mount in your drill are good.
    Just leave your old pads on if they have any meat to them, bed them as you should new bits (read up if you don't know how to bed new pads) and see what happens.
    If the rotors are not good enough to bother with cleanup, I'd just get new ones. I've found that the $ delta in turning and new isn't worth the aggravation of the trip to the machine shop anymore. Turning prices have risen, rotor prices have fallen.
    In my SCCA ride I used Hawk stuff. I wanted high initial bite but wasn't worried about long term heating like track folks would be. Which mine worked fine on the street too.
    Everyone I knew who chose EBC stuff gave them up at about 50% wear, as they felt they were overrated.
    I found Bembro marked rotors could be had at NAPA, don't know if that's still the case, and they wore quite well. What you should select depends on how you use the vehicle. If it's basically just transportation and OE braking power is adequate for you, just using the higher end parts house bits should be fine.
    And don't give up on actual OE parts shopping. Some of the Toyota vendors have good pricing. You can mix bits too, if that works for you. NAPA rotors, Advance Auto calipers, Toyota pads (as an example).
  17. Aug 26, 2020 at 5:20 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    thanks for all the reply's. It will give me plenty of reading material to look up.
