Best overlanding electric generator
Discussion in 'Outdoors' started by KrypticZer0, Jul 19, 2021.
  1. Jul 19, 2021 at 8:59 AM
    KrypticZer0
    KrypticZer0 [OP] Well-Known Member
    Western Idaho
    2007 TRD Sport LB 4x4
    What size and brand is the best quality/priced electric generator for 1-2night overlanding trips? What I would be looking to power is a small fridge/cooler that plugs into 12v power, phones, sounds machine at night for the kids and other miscellaneous needs.
  2. Jul 19, 2021 at 9:01 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Solar/ Dual battery is the most Overland, Dometic/Goal Zero and other portable battery packs are also pretty Overland, Honda is known to be quiet, and then there's a guy pushing a 2nd alternator "Never take a generator overlanding again"
    Or just book a site with power hookup...
    But really those loads listed can be run off your single battery in your truck for 1-2 nights. Get some portable phone battery packs and a battery powered noise generator.
    YF_Ryan likes this.
  3. Jul 19, 2021 at 9:08 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  4. Jul 19, 2021 at 9:11 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    TBH any deep cycle battery would have no problem running your fridge. I ran mine for the longest time and sometimes still do off my deep cycle and let it sit for 12 plus hours sometimes with out cranking the truck. Thats with other accessory's (lights) running. That being said i have recently acquired a jackery 240 and it will run the fridge for about 20 hours from a full charge with the fridge on eco mode. Id get the 300-for a 1-2 night trip.
  5. Jul 19, 2021 at 9:24 AM
    KrypticZer0
    Western Idaho
  6. Jul 19, 2021 at 9:25 AM
    KrypticZer0
    Western Idaho
    I would love a jackery with a solar panel lol they are pricey though!
    Brian422[QUOTED] likes this.
  7. Jul 19, 2021 at 9:33 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
  8. Jul 19, 2021 at 9:36 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    yea i won mine from a jockey giveaway. So that was nice.
  9. Jul 19, 2021 at 9:40 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Don't have to have a seperate power source, but I'd definitely install a 12v low voltage cutoff
  10. Jul 19, 2021 at 9:50 AM
    YF_Ryan
    Kent, WA
    ARB and Dometic, at least, both have a setting to automatically cut off at some voltage level. I always set at the highest voltage when running off my House batteries, even thought they weren't needed for starting. If using a solar generator though, most lithium ones require you to run your fridge on the lowest voltage shutoff, since Lithium runs at such lower voltage.
  11. Jul 19, 2021 at 9:56 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Good point, but OP didn't give a brand, better safe than sorry. Or also get a jump starter pack.
    YF_Ryan[QUOTED] likes this.
  12. Jul 19, 2021 at 10:07 AM
    KrypticZer0
    Western Idaho
  13. Jul 19, 2021 at 10:08 AM
    KrypticZer0
    Western Idaho
    That’s awesome
  14. Jul 19, 2021 at 10:13 AM
    YF_Ryan
    Kent, WA
    I think EVERY person should have a jump pack in their car!! Work great for other things too. Recharging phones, running small 12v Accessories (I run a 12v Water pump from one and 4x light a life 350 Goal Zero lanterns in our screen room), and of course jumping a car.
    Sandman614[QUOTED] likes this.
  15. Jul 19, 2021 at 4:18 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    For a deep cycle battery? how long would it last just with the battery and an inverter? few days? If running fridge and charging phones?
    I feel that's a cheaper alternative, than those fancy jackrys and GOOLOO
    I also heard you can charged a dead AGM battery.
  16. Jul 19, 2021 at 5:50 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I ran mine off 12v I put in bed and ran it for 12 plus hours with lights charging phones and what not and truck still started up the next day no problem.
  17. Jul 19, 2021 at 5:51 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I’ve got the diehard 720CCA battery
  18. Jul 19, 2021 at 6:12 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Best to run as many 12v appliances as possible. No real need to bring 110v things and convert 12v to 110v and back to 12v or 5v
    Shellshock and YF_Ryan like this.
  19. Jul 20, 2021 at 7:33 AM
    YF_Ryan
    Kent, WA
    THIS ^^^^
    You should absolutely stick to 12v stuff. Just running an inverter eats power without even plugging anything into it! And with the power loss every time you change voltage you are just throwing away even more power.
  20. Jul 20, 2021 at 1:06 PM
    OldSkoolArcher
    OldSkoolArcher Well-Known Member
    Nick
    PA
    '24 Tacoma OR, '24 Defender 110, '15 WK2
    Two weekends ago, I ran an Iceco VL45, with insulated cover, on a Duracell AGM Deep Cycle 31M Battery for just shy of 72 hrs. I prechilled the fridge at home using 110v and then utilized 12v for the 72 hrs. I was using the VL45 as a fridge, not a freezer and had it set between 39 and 41 degrees Fahrenheit. I used the fridge for food, not drinks, so I wasn't getting in it all that often, probably 10x per day. Outside temps ranged from 70 to 85 degrees. When I unplugged the fridge the battery was still cranking away.
    This is the battery I have: https://www.samsclub.com/p/duracell...p-size-31dtmagm/prod3590232?xid=plp_product_4
    KrypticZer0[OP] and BalutTaco like this.
