Best options bolt on bumper (no cutting)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CWill, Sep 6, 2020.
  1. Sep 6, 2020 at 8:04 PM
    CWill
    CWill [OP] Member
    2019 TRD Sport 4X4
    Wanting to upgrade the front bumper but there aren’t a ton of options that don’t require cutting. Anyone have any opinions on the DV8 bumper or something similar?
  2. Sep 6, 2020 at 8:27 PM
    .45 Calibear
    .45 Calibear Well-Known Member
    Tri-Valley - San Joaquin Valley, CA
    17 TRD Off Road - REI Crawler
    Broverlandering kinds
  3. Sep 6, 2020 at 8:36 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I was stuck on this one a while back, I decided to run the stock front bumper till I tore it off...still going.
  4. Sep 8, 2020 at 4:30 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I purchased the DV8 Low Profile off of eBay for $355. It arrived with damage to the shipping box and had minor paint damage and missing hardware. I contacted the vendor and they provided a $50 credit to my PayPal account and have sent out a new hardware kit and touchup paint kit. The very good communication and fast action was heartening, and I feel even better to have the bumper for a $334 investment (Incl tax).
    In looking at the installation instructions and posts from others, I decided to weld additional gussets on the right angle brackets before installing.
    In my opinion the DV8 would need additional modifications to use the winch tray safely, and even pulling utilizing the shackle mounts posses risk of sub frame damage without additional buttressing. I purchased the DV8 knowing that it would require modifications and have accepted it’s limitations in exchange for the price. An advantage of the DV8 is you do not have to trim any of the plastic valances as you do with others. If I was going to mount a winch on I would probably just go with a full bumper.
  5. Sep 8, 2020 at 5:36 PM
    .45 Calibear
    Vitamins and Blackwolf like this.
  6. Sep 8, 2020 at 5:47 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    If you had not considered, I'm planning to buy an unpainted replacement bumper to cut up if I go that route. It's about $250 for OEM, $150 non-oem. There is a company also making replacement sections just for off road bumpers that doesn't have the fog light notch.
    Interbeing likes this.
  7. Sep 8, 2020 at 7:51 PM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    100% of the full bumpers that don’t require cutting look like shit. The stealth/slim bumpers are OK but they won’t get you the type of clearance that a full bumper will.
    Just cut it.
  8. Sep 8, 2020 at 9:29 PM
    CWill
    CWill [OP] Member
    2019 TRD Sport 4X4
    Yours looks great man. I’m fine with it not being top notch performance wise, as long as it looks great and can handle some minor stuff. I think you’ve sold me on that exact bumper.
  9. Sep 8, 2020 at 9:40 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Check out victory 4x4. They have a no cut slim front bumper that looks real nice.
  10. Sep 8, 2020 at 10:47 PM
    Interbeing
    Austin, TX
    Here is a photo of the gussets I got welded to the L brackets. Also drill a hole in the back of the bumper where the light bar bracket is welded to the bumper to allow you to run the wiring for the light bar through and be able to hide the wiring. I also drilled weep holes on both sides of the bar mount to avoid water settlement. You’ll understand when you see the bumper physically. I also repainted the drill holes and also reached in and painted the interior portion of the bar light mount at the same time. Once aligned, I torqued the mounting bolts to 63 ft lbs. Oh yes, I replaced the supplied mounting bolts with Grade 8 Stainless, it came with ungraded.
  11. Sep 8, 2020 at 11:00 PM
    Interbeing
    Austin, TX
    It does look pretty good, and it’s quite well built, 1/4 inch steel with pretty good powder coating (Built in Mexico). But if you really want to mount a winch and plan to do a lot of wheeling, a full bumper is a better way to go. 60754F91-B71A-4EA5-B28A-3F97F4E85B8C.jpg
  12. Dec 16, 2021 at 5:15 PM
    Suppressed_Alaska
    Suppressed_Alaska Member
    Alaska
    2020 Cement TRD Off Road
    Bit off topic, but does your truck have any lift? Or are those just bigger Tires and what size are they? It looks really good.
    and good to know that the bumper is ready for winching out of a mud bog.
  13. Dec 21, 2021 at 9:07 PM
    SeniorSpan
    SeniorSpan Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    G'day CWill
    You may like this: Victory4x4 Tacoma Front Winch Bumper | Blitz | 3rd Gen (16+)
    www.victory4x4.com/product/VT3FB.html
    I just finished the install yesterday. Elected to go aluminum for weight. I also installed a Smittybilt X20 winch. The bumper weight plus the winch can be done by one person as I did this myself, but would have been quicker with a helper.
    The install was easy and only had to remove/cut one plastic part under the truck per the instruction. It's designed to be able to replace all the stock parts should you every want to that one day.
    There's a install video on the website to see what is actually done for the whole process.
    Cheers
  14. Dec 21, 2021 at 10:33 PM
    itzryyster
    itzryyster Well-Known Member
    Cement
    2021 Tacoma TRD Off Road 4x4 Short Bed. Bilstein 6112/5160, Bilstein B8 Upper control Arm, Wheelers Front Bump Stop, Icon RXT Leaf Pack, Wheelers UBOLT Flip Kit with upgraded rear Bump Stop. CBI Gas Skid Plate, RCI Transmission/Transfer Case Skid Plate, RCI Diff Skid, Runnin4Tacos Control arm Skid, MB Custom Fab Sliders, VOLK TE37x 16x8 w/ Nitto Ridge Grappler 295/75/16, TRD OEM Intake, TRD Radiator Cap, TRD Oil Cap, TRD Exhaust, 21 TRD Pro Tail-lights, Odyssey Battery, Cali Raised Bed Rack
    I've been trying to find one that doesn't cut the bumper as well but doesn't seem to be many options. Might have to lean towards SSO since it isn't too extreme.
  15. Dec 21, 2021 at 11:55 PM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    I have an SSO on the way. I did not find anything I liked that did not require cutting and finally gave up. For a daily driver, I think bumpers like SSO's slimline will have less of a detrimental effect on gas mileage.
    I had been looking and a BAMF Hybrid with these to avoid cutting https://runnin4tacos.com/products/bumper-caps-2016-2020-toyota-tacoma
    For me, the primary purpose of the bumper is to hold a winch, so may add these https://c4fabrication.com/collectio...nt-bumper-frame-support-brackets-3rd-gen-2016 though I'm not certain they will work with the SSO.
    itzryyster[QUOTED] likes this.
  16. Dec 22, 2021 at 2:49 PM
    itzryyster
    Cement
    Thanks for the updates and links. I will look into those and most likely lean towards SSO's bumpers as well. :thumbsup:
    lostMarbles[QUOTED] likes this.
  17. Jan 25, 2023 at 9:47 PM
    ScottinAZ
    ScottinAZ New Member
    Scott
    2018 DCSB TRD Off-Road
    GoFast Camper, Bed Stiffeners
    sorry to resurrect the thread but curious about mounting the x20 winch. Did you have to relocate the control box or mount it to the left? Getting ready to install this to my 3rd gen with the same winch and just looking for any tips or experienced pointers.
    Thank you!
  18. Apr 27, 2023 at 12:11 PM
    Telkins88
    Telkins88 Well-Known Member
    Ohio
    2021 TRD Sport 4x4 Premium
    Goodyear Ultraterrain AT 265/70r17 1” front and rear lift
  19. Apr 27, 2023 at 12:22 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    There are a couple of red flags on that bumper.
    One, they don't show the mounting hardware/backside of the bumper,
    Two, there are no shackle points (indicating they know it isn't rated for squat)
    and Three:
    At that point, the stock bumper would outperform this under all conditions, including as a low speed brush guard. Even my cheap chinesium bumper weighs 75 pounds, and its the same shape and size as that one.
    Telkins88[QUOTED] likes this.
  20. Apr 27, 2023 at 12:41 PM
    perterra
    perterra Well-Known Member
    Tejas
    Looks like it just covers the plastic front bumper cover. I dont think it replaces anything. They have them with winch mounts and clevis points if you need it heavier. This is strictly cosmetic cover for parking lot bumps
