Best oem replacement front struts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, May 6, 2021.
  1. May 6, 2021 at 10:15 AM
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    Any suggestions? My stock set up with 1.25” spacers was way nicer than these bilstein struts and JBA uppers. Considering buying oem replacement struts and putting my spacers back on and my stock uca’s. I don’t do wheeling so it’ll be fine. 98 Tacoma 4x4 2.7L
    1997tacomav6 likes this.
  2. May 6, 2021 at 10:28 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tacoma's don't use struts.
    Bilstein 4600's are what you want if going back to stock.
  3. May 6, 2021 at 10:35 AM
    98_3RZ_NIC
    please show me a 4600 with a coil over it
  4. May 6, 2021 at 10:38 AM
    98_3RZ_NIC
    I use my own springs. I have to get new ones. The ome ones I have won’t work with those shocks.
  5. May 6, 2021 at 10:43 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well you were asking about shocks, so I listed the OEM replacement.
    You'll either need new springs from the dealer, used (not my suggestion, but you can find them free), or generic replacements from Moog or someone.
    You won't find them sold as a coilover assembly as coils generally last longer than the shocks being replaced.
  6. May 6, 2021 at 10:45 AM
    98_3RZ_NIC
    i just don’t know what length to get. Those 4600 are like 18” extended and 13” collapsed
  7. May 6, 2021 at 10:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You do know to just look for coils to match your vehicle right?
    Moog and whoever else, will state A, B, and C work with 6 lug Tacoma's.
    Then they might even list rates such as 500lb, 600lb, etc. as well as what vehicle type is recommended per spring type
    Example 500lb may me be for a Prerunner, because it lacks a front diff and cv axles. This is basic stuff.
  8. May 6, 2021 at 10:50 AM
    98_3RZ_NIC
    stuff I know nothing about obviously. That’s why I’m asking for help to point me in the right direction.
  9. May 6, 2021 at 10:55 AM
    98_3RZ_NIC
    could you post a link for the coils you would buy for the 4600’s?
  10. May 6, 2021 at 10:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No worries
    But some companies offer different spring rates for the same vehicle for that very reason above.
    Only thing I can't help with are the different manufacturers that offer OEM type coils for your trucks.
  11. May 6, 2021 at 10:57 AM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
  12. May 6, 2021 at 11:17 AM
    1997tacomav6
    Denver
  13. May 6, 2021 at 11:25 AM
    98_3RZ_NIC
    dont wanna lift it that much. Just wanna go back to stock with my 1.25” spacers. Ride was great and I liked the stance.
  14. May 6, 2021 at 11:59 AM
    98_3RZ_NIC
  15. May 6, 2021 at 12:01 PM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
  16. May 6, 2021 at 12:04 PM
    98_3RZ_NIC
  17. May 6, 2021 at 12:05 PM
    AmherstAndy
    Andy
    Masshole
    You don't tell us what kind of engine, body and drivetrain your truck has, and no one is gonna go through your old posts to figure it out. You need to do your own homework on this.
  18. May 6, 2021 at 12:05 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    KYB, happy as a clam with mine. Check @RockAuto . :thumbsup:
    Wessty and Das it mang like this.
  19. May 6, 2021 at 12:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You do know, adjustable coilovers allow you to 'adjust' the preload to give you a lot less lift than what they're set for.
    If you only want a 1" lift, you can do that with a variety of 2.5 coilovers.
    Just saying, his King's suggestion isn't a bad one.
  20. May 6, 2021 at 12:09 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Here's a 5100 with a coil on it. 4600 will look identical.
    Having a coil spring on or off it is not what makes it a coilover or a strut. It's the upper control arm that makes it a coilover. A strut essentially acts as an upper control arm and the shock/coil combo.
    Our trucks have coilovers from the factory.
    You can get stock height Kings. But those are also really spendy for just street driving.
    If you just want nothing special stock height, the Monroes are fine. Without any accessories, like a steel bumper or a winch, you can just get the pre-assembled units like what was posted above, although I'd buy from an actual auto parts retailer, not Amazon.
    You can also just get the shocks, and re-use your current coil springs (assuming they're stock), although they're more than likely worn out anyway.
