Best lube for squeaky leafs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stocklocker, Aug 8, 2021.
  1. Aug 8, 2021 at 10:10 PM
    Stocklocker
    Stocklocker [OP] Well-Known Member
    17TRDORDCSBAT
    I just went on a very dusty trip and I’ve got the squeaky leaf spring situation now. I thought it was a joke, until it happened to me, and realized how bad it can actually be.
    I have heard guys jack up their trucks via the frame, to open up the leaf, and spray lube etc in between the leaves to stop this.
    What is the best lube option you’ve tried?
  2. Aug 8, 2021 at 10:20 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Personally I've had luck with wd40. Just load it on.
    Stocklocker[OP] and Skydvrr like this.
  3. Aug 8, 2021 at 10:21 PM
    bigbadbarty
    bigbadbarty Well-Known Member
    Granite Falls, WA
    2021 Tacoma OR DCLB
    Funny. Did Stampede Pass yesterday and halfway down mine started squeaking. 3,000 miles. I’m gonna follow this thread for sure.
  4. Aug 8, 2021 at 11:02 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Check if tsb applies to you. If not, pressure washer then pb blaster silicone is good
    Stocklocker[OP] likes this.
  5. Aug 8, 2021 at 11:06 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    He asked for a lubricant, not a penetrant. Personally, I'd go with KY.
  6. Aug 8, 2021 at 11:22 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Recommend any NGLI #2 Multipurpose
    IF you want to go the distance, pull the pack and separate the leafs and put lube on the leaf ends and around the center pin.
  7. Aug 8, 2021 at 11:27 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Desert inhabitant here.
    Pressure wash the dust/sand out first. Then spray a silicone spray if it still squeaks.
    If it didn't make noise before (and you didn't cause any damage hot dogging it off-road) just the pressure wash should do it.
  8. Aug 9, 2021 at 12:47 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Idk what Toyota did. But my squeaks went away after the messed w mine.
  9. Aug 9, 2021 at 5:50 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I had squeaky leafs on my 2001 tundra that would drive you nuts. Lubing them was temporary at best. I ended up removing the leafs, and separating them while installing some of these thin teflon/plastic pads between them, and clamping them back together. Never had another squeak of clunk in all the years after.
  10. Aug 9, 2021 at 6:10 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    The best I've seen is taking the pack apart and greasing everything including the thin metal "shims"
  11. Aug 9, 2021 at 6:18 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Speedway leaf liners P/N 91033038-BLK
    Been running these for two and a half wheeling seasons with no lube and no maintenance. No squeaks from the leafs. A bit labor-intensive to install as you have to undo the center pin and separate all the leafs.
    zoo truck likes this.
  12. Aug 9, 2021 at 6:18 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    When mine get squeaky, I hit the them with some motorcycle chain lube as that's what had laying around at the time. Worked great the first time I used it and have been continuing to use it ever since :thumbsup:
  13. Aug 9, 2021 at 6:38 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    Did these on my Dakars and never once had a squeak. And this was after many wheeling, mudding, and water-crossing trips. They're easy to install and trim.
    3JOH22A[QUOTED] likes this.
  14. Aug 9, 2021 at 6:40 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    That is what my local spring shop did for me. New anti-friction pads never a squeak now living on a dirt road. Hated the squeak
  15. Aug 9, 2021 at 6:56 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I prefer KY for the front...his issue is the back so I'd go with Astroglide.
  16. Aug 9, 2021 at 7:09 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Better to put on the Speedway liners than to put it in bareback. You also gain about half an inch.
  17. Aug 9, 2021 at 11:13 AM
    zoo truck
    None
    Thats exactly what i used...don't know if the same but when i bought mine it said they were made with teflon. This was over 15 years ago. They work great.
  18. Aug 9, 2021 at 11:16 AM
    zoo truck
    None
    I use to do that for my tundra...after 1 winter the squeaking and clunking was back. This works, but its the short term answer if you live up north.
  19. Aug 9, 2021 at 11:18 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Jack up the truck in the back to create space between the leaves , use an air compressor to blow them out, then use a lubricant that has graphite in it.
  20. Aug 9, 2021 at 11:52 AM
    STalon92
    STalon92 Well-Known Member
    Santiago
    2021 Cement OR DCSB
    After installing an add a leaf, mine sounded like an old farm wagon going down the road until today. Just bought Lucas Chain Lube this morning at the auto parts store and the annoying squeak is now history.
    Technique likes this.
