Best lift to fit 33x12.5s on 2018 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaLover2864, Aug 14, 2018.
  1. Aug 14, 2018 at 7:30 PM
    YotaLover2864
    YotaLover2864 [OP] Member
    05’ Navy Blue TRD Sport 4x4
    285/70/17s on 17x9 inch rims. Billstein 5100s set to 2.5 inches in front, none in back.
    I have recently gotten a 2018 Tacoma TRD Sport 4x4. I want to fit 33x12.5 without having to trim plastic or metal (I know it’s a lot to ask but it’s a new truck and I don’t want to mess with it). I know I will likely have to trim some but if I did I’d rather chop some metal instead of any plastic. I was thinking of getting a 3 inch Rough Country suspension lift and going with 33x12.5x20s on 20x10 inch rims with a -24mm offset. Is this a good choice? If not, what size lift and type of lift is best. I am willing to spend whatever it costs but I’d like to not overspend if I don’t have too.
    Also, what is the best rim size for 33x12.5s. I want to get 20x10s but idk if the truck can handle 20s. Are 18s a better size? And if so, how wide of rim? If 20s would work, how wide would that rim need to be.
    Hobbs likes this.
  2. Aug 14, 2018 at 7:33 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  3. Aug 14, 2018 at 7:35 PM
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    Welcome to the forum.
    I would start here
    https://www.tacomaworld.com/threads...2016-tacoma-presented-by-toytec-lifts.395798/
  4. Aug 14, 2018 at 7:35 PM
    ScottyR
    Vancouver BC
    2016 DCLB TRD Sport
  5. Aug 14, 2018 at 9:50 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    What you are asking about is not very popular on this forum but there are a few that run drop bracket lifts. Not sure on the 20s, was never a fan of wagon wheels
    Anyways the problem is not really about going up but going out. The 12.5 wide part will give you some trouble. A 10” rim is a good non-offroad wheel width size for a 12.5 tire.
    There are a lot of suspension options but you will have to trim, cut, weld, and bang to fit them. Could always go long travel!
  6. Aug 14, 2018 at 10:11 PM
    Xx_buckshot
    Xx_buckshot Well-Known Member
    Brennon
    South central Livingston parish
    2018 tacoma trd or
    I got 3" blocks rear and 2" plate on front shocks And im running 20s with 33x12.50 and no cutting and minimal rubbing. Have hub spacers not sure size have to check. Brother in law runs same as me on his 3rd ge . I got nitto trail grappler and he runs Dick cepek 33x 12.5
  7. Aug 14, 2018 at 10:12 PM
    toycoma 2016
    toycoma 2016 Well-Known Member
    jason
    Williamsport, TN
    2021 cement OR 4x4 dcsb
    Lots
    Heres proof it can be done. Found on Instagram less than 10 minutes after reading your post. Hope this helps.Screenshot_20180815-000928.jpg
  8. Aug 15, 2018 at 4:24 AM
    YotaLover2864
    Thanks to all who have responded. Would an 11.5 inch wide tire be a lot easier to fit than a 12.5 in wide tire? Not to concerned about the width I would just like to get 33s. And if I could fit them on a 3 inch lift I’d like that more than a 6 inch. 4 inches is maximum I want to go.
  9. Aug 15, 2018 at 5:38 AM
    JoeCOVA
    Joe
    Colorado Springs
    285s are generally the go to tire size for most. However you will still have to trim, maybe a CMC and make some modifications, and better UCA that let you set caster to +4.
    People who say they don’t rub are lying or never turn their wheels. There is rubbing usually at full lock or when the suspension is flexing.
    You can search the forum and the suspension forum here for 33s and 285 to get more info.
  10. Aug 15, 2018 at 6:28 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    @Darkgoatracer ran 33x12.50 for a long time... now he's on 35x12.50.... on a 3 inch lift
    Darkgoatracer likes this.
  11. Aug 15, 2018 at 7:10 AM
    Backcountry Bandit
    Backcountry Bandit Member
    2018 Taco TRD Sport Crew Long 4X4
    3" Rev Tech lift 33/12.5/17 Comfoser Tires 17x10" Moto Metal rear air bags
    33/12.5/17. 3" revtech lift. removed the front air dam. no rubbing at all during everyday driving. slight and i mean slight rub at full articulation and only in reverse. -12 offset. no wheel spacer. loooooove it
  12. Aug 12, 2020 at 6:16 AM
    B.Peak
    B.Peak Well-Known Member
    Brian
    SWFL
    '19 Tacoma TRD Sport 4X4
    '19 Tacoma TRD Sport 4X4, Premium and Technology Packages OME-888 Coils w/ OME-90021-P Nitrocharger Sport Shocks- softer valving ToyTec .5" Top Spacer OME-EL095R-P Rear Leaf Pack w/ OME-60091-P Nitrocharger Sport Shocks Eibach 1" Lift Block OME Upper Control Arms OME Driveshaft Carrier Bearing Drop Kit ToyTec 1" Diff Drop ECGS Clamshell Bushing 18X9 Enkei RPT-1, 0 Offset on LT305/65R18 TOYO Open Country M/T 2020 OEM Limited Grill 2020 OEM Limited Fog Light Bezels MESO Stage 1 Total Tail Light Kit All Interior and Exterior lights replaced with Diode Dynamics LEDs TRD Cat Back Exhaust Passenger Door Smart Key Mod
    I assume you have a 17x9 wheel, if so do you think you would have an issue rubbing the UCA if you had a zero offset wheel?
  13. Jul 3, 2021 at 5:56 PM
    Rainman443
    Rainman443 Well-Known Member
    A Big Island
    2021 TRD OR
    Do they rub your mudflaps at all? Do you do any offroading?
  14. Jul 3, 2021 at 5:59 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    angle grinder and hammer, no lift required
