Best lift for the money
Discussion in 'Suspension' started by jlaurence32, Oct 28, 2021.
  1. Oct 28, 2021 at 7:47 PM
    jlaurence32
    jlaurence32 [OP] Well-Known Member
    Colorado
    2016 MGM TRD Sport 4x4 DCSB
    Have a 2016 Sport DCSB auto 4x4 stock. Looking to add 275/65R18 tires and 18x9 wheels. Want a 2-3" lift/leveling kit that ends up close to level. Will never go off road. Just stay on pavement. Looking to spend around $1500 for kit. What's the best for the money that'll give me a good safe ride and not wreck alignment/tires? Doesn't need to be adjustable.
  2. Oct 28, 2021 at 8:03 PM
    bobbysk123
    bobbysk123 Well-Known Member
    bobby
    2020 toyota tacoma TRD off road DCLB 4x4
    N/A
    Depends on what you want to use your lift kit for; mall crawling, rock climbing, trailing, ect. I can tell you based on my experience with the king shocks 3.0s. The king shocks are well designed and ride nice, but you have to end up coughing up about 5k-6k for shocks alone. then you have to consider the UCAs, leaf spring pack, ect. The king shocks are a tad bit expensive and you'll probably never need to use them to their full capability unless you drive through some rough terrain every day, but it's also nice to have it in case you need it. I have done some research into brands like; Bilstein, icon, and fox, and they seem to have a good reputation. I would try and avoid leveling kits, body lifts, and rough country lifts. The quality of the lift will depend on the price most of the time.
    robssol likes this.
  3. Oct 28, 2021 at 11:25 PM
    jlaurence32
    Colorado
    Ok, made my initial post more descriptive.
  4. Oct 28, 2021 at 11:48 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Don't install a spacer lift ever. Just my opinion. Most that do end up wanting to upgrade later. It's a crappy way to lift any truck.
    Bilstein 5100 is a good budget lift. That or Eibach pro.
    Pushing the limit of your budget look up bilstein 6112 front paired with 5160 rear. A step up from 5100's.
    There are a ton of options and opinions. This is just mine.
    airmax233 and Taco de cement like this.
  5. Oct 28, 2021 at 11:57 PM
    Taco de cement
    Taco de cement Well-Known Member
    Omar
    2021 trd off road
    Whats the difference between the 6112 and the 5100? Smothered ride?
  6. Oct 29, 2021 at 12:00 AM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Bilstein 5100 with add a leaf seems to be the go to for mid range price and low maintenance/moderate off road. That or OME.
  7. Oct 29, 2021 at 12:00 AM
    Superdave1.0
    SoCal
    6112 is a much fatter shock. Quite a step up from 5100 on and off road. I've ran both on several different vehicles.
  8. Oct 29, 2021 at 12:09 AM
    Taco de cement
    Omar
    2021 trd off road
    Damn. Your making me want to get these now lol what if you dont go off roading? You wouldn’t recommend them? Just stick to 5100?
  9. Oct 29, 2021 at 12:11 AM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    I’ve had an 05 4Runner SE V8 awd, an 87’ 4runnner and and 89 p/u. Every Toyota gets OLD MAN EMU.
    Cheap doesn’t mean better or last. Buy the best you can afford.
    whatstcp likes this.
  10. Oct 29, 2021 at 12:15 AM
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    I've ran the OME lift no complaints here. The 887x springs with the 90021 sports Id say it's a good contender for an entry level. Was this or the 5100, but can't speak on them. Just remember to consider UCA which will increase the cost and most likely go over your budget.
  11. Oct 29, 2021 at 12:39 AM
    Taco de cement
    Omar
    2021 trd off road
    Just saw this video and it does a pretty good job at explaining the Bilstein 5100 vs the Bilstein 6112.
    https://youtu.be/TpnISB3BLIc
  12. Oct 29, 2021 at 4:39 AM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I had good luck with Toytec 2.0 before I went down the rabbit hole. I've also read very good reviews about the Rancho kit. We put a rough country lift on my friends truck yrs ago, it's still going strong & he beats on it pretty hard
  13. Oct 29, 2021 at 11:20 AM
    jlaurence32
    Colorado
    If I do a 3" lift do I have to get a kit with UCA's? Some guys say yes, others no?
  14. Oct 29, 2021 at 7:29 PM
    TVH475
    Montrose CO
    Some say yes and some say no! Personally I ran my toytec 2.0 @ 2.5" of lift with a .25" spacer on top, so 3" of lift with stock uppers, alignment was not perfect, steered a little quick, but was just fine by me
  15. Oct 30, 2021 at 1:15 AM
    jlaurence32
    Colorado
  16. Oct 30, 2021 at 1:24 AM
    Superdave1.0
    SoCal
    All 3 of those utilize huge spacer/block in the rear. The lowest quality rear lift option.
    An add a leaf (AAL) is a much better option for rear lift on a budget.
    71tattooguy likes this.
  17. Oct 30, 2021 at 1:34 AM
    jlaurence32
    Colorado
    Yeah, the revtek has add a leaf for same price and rough country its 300 more for new leafs which is reasonable.
    Superdave1.0 likes this.
  18. Oct 30, 2021 at 1:46 AM
    Superdave1.0
    SoCal
    TVH475 and airmax233 like this.
  19. Oct 30, 2021 at 8:17 AM
    airmax233
    Southern California
    I’d buy it before it sell out. Plus it has upper control arms can’t beat that. Make sure to post pics when you install it. Some before and after with a review of how it rides. :thumbsup:
  20. Oct 30, 2021 at 11:52 AM
    R3b3lSon82
    R3b3lSon82 Well-Known Member
    2019 CG TRD OR
    Crikeymike and Dalegribble02 like this.
