Best leafpack?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Nov 28, 2021.
  1. Nov 28, 2021 at 2:49 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    What's the best leafpack?
    I hear there's pretty much only 3 to pick from.
    -OME medium duty
    -OME heavy duty (both called Dakar)
    -Icon RXT
    From what I've heard:
    -OME leafpacks suck. They squeak and sag. Not sure if even cheaper than Icon
    -Icon RXT is supposedly the best. I think they used to be $1k but now appear to be $600-700/set
    currently running OEM TSB leafs w/ cheap AAL + spacers and hoping to replace it at some point to resolve the axle wrap
    truck feels weird accelerating and I'm sure that's contributing
    tacotoe likes this.
  2. Nov 28, 2021 at 2:54 PM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    Before this thread takes off I'll say it, all but the cheapest light duty no-name leaf pack will be an improvement over the stock springs.
    boston23 and tacotoe like this.
  3. Nov 28, 2021 at 2:58 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    No squeak or sag with OME springs. 4 years in use.
    If had to do over would just get the medium load spring.
    Montana_Actual and Woodini like this.
  4. Nov 28, 2021 at 2:59 PM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    This
  5. Nov 28, 2021 at 3:03 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I own a turd gen but my OME mediums have been great, and i have a fiberglass shell…
    And lbest” leaf pack for what type of usage? Constant load, frequent hauling, desert running?
    DG92071, tacotoe and SomeGuy_GRM like this.
  6. Nov 28, 2021 at 3:44 PM
    TacoTuesday1
    FL
    so is heavy for weighted beds ie camper shell + roof top tent?
    as opposed to medium duty for everything else?
    I heard if driving with heavy duty leafpack and bed unloaded, that it makes for a horrible ride
    so maybe that would make medium-duty worth it in that case...
    honestly, hauling is non frequent. no constant load. no desert running.
    These trucks are 4x4 rocky mountain climbers; never had the intent to delete front axles and drive 5hr to drive some circles in a sandbox
    actual desert trucks don't use leafs
    tacotoe[QUOTED] likes this.
  7. Nov 28, 2021 at 3:52 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Okay then for your use id say custom deavers would be the best.
    Otherwise i like my medium duty dakars for riding Forest Service roads
    tacotoe likes this.
  8. Nov 28, 2021 at 4:05 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    Alcan, custom made for your truck
    kingk0ng, boston23 and Naveronski like this.
  9. Nov 28, 2021 at 4:07 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I'd rather stab myself in the face than run dakars again. Squeaky garbage. Deavers, RTX, or ATS springs (have been fantastic for me)
  10. Nov 28, 2021 at 4:11 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Icon RXT IMO. Have installed a few sets, they are really nice. Come with an extra leaf and can be configured to 3 different stages. Like buying 3 leaf packs in one.
    My OME were sqeaky but performed well.
    4x4cajun, crashngiggles and tacotoe like this.
  11. Nov 28, 2021 at 4:13 PM
    TacoTuesday1
    FL
    Yeah I really don't know if custom is best or not
    I imagine it's better because what you lose in load carrying capacity, you might gain in ride comfort
    ie 300lb springrate (if that is such a thing) vs 600lb for more weight in the bed
    unless something universal is fine that can handle varied normal use (every Tacoma carries stuff sometimes)
    not to say my spacer + AAL couldn't carry anything, it would just sag.
    I think Deaver is $1100 vs. $700 for RXT, so the lower price makes RXT sound more appealing
    plus the customization options of it; they ship you extra leafs I think, for you to pick how to set it up based on things like desired ride height
    really will be looking to match prior ride height, as I have OME 887 front springs kind of matched regarding truck height measurements
    I'll have to check FTG but I think the rear is basically 2.5" above stock, due to AAL (1.5"?) + spacer - the spacer was either 1" or 1/2" because sellers claim the way spacers work is that they double actual vs. lifted height
    aka 1/4" taco front lean spacer = 1/2" lift, or 1/2" rear block = 1" lift
    so if I was looking for 1" lift that means I'd have put a 1/2" spacer, which I can get under the truck to double check/measure
    Toytec spacer + Toytec AAL which probably sources from Deaver, the same that Headstrong Offroad uses
    because if I swap out for a whole leafpack that accidentally lowers the rear some, that would mess everything up
    exactly
  12. Nov 28, 2021 at 4:15 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Those of you with medium duty leaf springs, any of you running them unloaded, no additional weight in rear beyond stock? If so how is the ride? What are you pairing them with?
    tuktoyaktuktoyota likes this.
  13. Nov 28, 2021 at 4:15 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    @ARCHIVE has leaf springs coming. Dobinsons have been decent so far for me, but they never fixed the 2nd leaf being too long and damaging the shackle when fully fixed, like many other options on the market.
    ARCHIVE and TodayWasTHeDaY like this.
  14. Nov 28, 2021 at 6:08 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I had the Icon RXT's for a bit. They were fine, but I quickly realized my truck is too heavy for them.
    I replaced them with a custom pack from Alcan and have been happy so far.
  15. Nov 28, 2021 at 8:02 PM
    ChaCha
    ChaCha Well-Known Member
    Sandy, UT
    13 DCLB
    Same route here. RXT first, then Alcan.
    Naveronski[QUOTED] likes this.
  16. Nov 28, 2021 at 8:28 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I'm going to throw the little known Ironman 4x4 leaf packs for consideration. Been running these for several years now and will eventually replace with another leaf pack from Ironman. Ride is smooth, unloaded or loaded, with zero squeaks. They have Black friday sales going on until 11/29.
  17. Nov 29, 2021 at 6:17 AM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, 16" TRD baja wheels, 265/75r16 BFG K02, 1.25" wheel spacers, TRD skid plate, N-Fab spare tire box mount.
    Stiff, even with a long box. Still a huge improvement over the stock leafs, but still would buck over sharp bumps, especially on corners. This was paired with Fox 2.0 Resi non-adjustable (digressive valving, to be fair). With Elka 2.5 DSC, on a soft low speed compression setting the rear feels a lot more planted. No bucking and more smooth than you'd expect for an empty box.
    With the Fox 2.0s, the sweet spot was about 200-300lbs in the back. With the Elka's on softer low speed compression, the sweet spot is about 100lbs in the back.
  18. Nov 29, 2021 at 6:20 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I just went from Dakar to RXT and the ride is 100x better
    jeminyned likes this.
  19. Nov 29, 2021 at 6:29 AM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    I have All Pro Expedition leafs on my 2.5gen and I love them. They gave a bit more lift than I wanted (~3"), but they ride fantastically with only a fiberglass topper - a 10x improvement over stock handling, and they flex really well off-road.
    They're also a relatively cheap option, the only complaint I have about them is that you'll have to get creative with securing the e-brake lines, there's no pre-drilled hole for the bracket and no aftermarket options fit AP leafs.
    TegoTaco likes this.
  20. Nov 29, 2021 at 11:27 AM
    ChiefBrody
    ChiefBrody Well-Known Member
    Michigan
    '12 Tacoma TRD Offroad
    Icon RXT option 3. Bilstein Pro suspension. I have a cap and a cap rack on the bed. No other weight unless I have the bed loaded up with shit.
    Rides like a dream.
