Best leaf spring set up for towing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wolfwertheimer, Sep 18, 2022.
  1. Sep 18, 2022 at 7:47 PM
    wolfwertheimer
    wolfwertheimer [OP] New Member
    Wolf
    2015 Toyota Tacoma
    bilstien 5100, AAL, wheels and tires, sounds
    So I have a 2015 tacoma with bilstein 5100 set at 2.5" lift and a 1.5" AAL. My truck was pretty leveled when first installed but I am pretty frequently towing my 18ft boat with it and now sags even when nothing is in the bed. I want to install a whole new leaf pack to get my truck to sit level or have a little bit of rake when nothing in bed or towing, but still have the durability to tow. I though about just going for heavy duty springs but it seems like most of the heavy duty springs will give me closer to a 2.75-3 inch lift which I feel like is too much for having a 2.5" lift in the front. Any suggestions on what I should do?
  2. Sep 18, 2022 at 10:45 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I’d look at air bags for towing. Firestone ride rite. I used them when I towed a trailer and they are great because you can adjust them when needed. I’m sure others will chime in on the lead pack
    Key-Rei likes this.
  3. Sep 18, 2022 at 11:16 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Airbags with Daystar cradles or a fullsize truck.
    dk_crew likes this.
  4. Sep 19, 2022 at 8:46 PM
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
    OME Dakars would be an improvement
  5. Sep 20, 2022 at 1:04 AM
    wolfwertheimer
    Wolf
    2015 Toyota Tacoma
    Does the airbags add any ride height when not inflated?
  6. Sep 20, 2022 at 1:23 AM
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    No it won’t
  7. Sep 20, 2022 at 1:40 AM
    wolfwertheimer
    Wolf
    2015 Toyota Tacoma
    After doing some research, I am thinking about maybe trying out the dobinsons leaf springs and maybe air bags with that. Any thoughts?
  8. Sep 20, 2022 at 9:43 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Sump Springs, maintenance and worry free once installed.
  9. Sep 20, 2022 at 9:50 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I think the key word is "now sags," implying it didn't before. If your unloaded,unhitched height changed, fix that first. Then look into trailer aids afterward. Don't use trailer aids to fix sagging springs.
    YF_Ryan and BlkDakDave like this.
  10. Sep 20, 2022 at 10:19 AM
    BlkDakDave
    David
    CC TX
    I missed that point. Definitely time for some new leaf springs.
    Then get a set of Sumo Springs.
    Rock Lobster[QUOTED] likes this.
  11. Sep 20, 2022 at 10:34 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    What's the tongue weight on your trailer?
    I'd recommend a new leaf pack and using a WD hitch when towing. Airbags are a payload solution and not the best option for towing (they don't shift any load off the rear axle of the tow vehicle).
  12. Sep 20, 2022 at 10:35 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Get some sumo springs and call it a day.
  13. Sep 20, 2022 at 11:21 AM
    wolfwertheimer
    Wolf
    2015 Toyota Tacoma
    Okay so I think I will start by upgrading leaf pack. I think I’m gonna go with dobinsons. Should I get the lightest duty one rated for 0-200 constant weight because when I’m not towing I don’t really have anything heavier than that in the bed?
  14. Sep 20, 2022 at 11:54 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
  15. Sep 20, 2022 at 11:59 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    This.
    I have been running airbags for years and wheel with them deflated. Super flexy and never had a problem with them.
  16. Sep 20, 2022 at 12:02 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'd go with whatever spring pack you think will get you the ride height you want with your most common bed load weight. Then get the airbags for trailering.
