Best leaf spring pack for the money
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeffrow20111, Jan 24, 2017.
  1. Jan 24, 2017 at 9:53 PM
    Jeffrow20111
    Jeffrow20111 [OP] Well-Known Member
    Jeff
    Murrieta Ca livin, from Vista Ca thou
    2011 Tacoma Pre runner
    Maxtrac spindles, Total chaos upper arms, king 2.5's, flow master exhaust, K&N intake, throttle body spacer, custom front bumper, McNeil fenders, 33"BFG's, 17" Mickey Thompson classic lock wheels.
    Looking to get some new leaf springs and shocks for the rear. Whats the best ones for your money? Deavers, all pro std or what? Fox 2.0's?
    ChadsPride likes this.
  2. Jan 24, 2017 at 9:58 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    dakars or all pro expos seem to be popular around here . it all depends on what you use your truck for and budget. I went with dakars and fox 2.0 resi for under 1,000. was gonna go with ADS 2.5 resi in the rear but they are $$. look in the suspension forum you will get plenty of reviews on everything you need to know
    https://www.tacomaworld.com/forums/suspension.18/
    eccracer104 likes this.
  3. Jan 25, 2017 at 8:58 PM
    Jeffrow20111
    Jeff
    Dakars and 2.0's sound good to me. Prob gonna go that way. Where did u buy urs from
  4. Jan 25, 2017 at 9:02 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Depends on end use
    BKinzey, ChadsPride and eccracer104 like this.
  5. Jan 25, 2017 at 9:03 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    How do you use your truck?
    What would you like your leafs springs to be the best at?
  6. Jan 25, 2017 at 9:20 PM
    JoBroTACO
    JoBroTACO Jobrotaco IG
    Joey
    Yuma AZ
    2013 TACO 4x4 4 cyl 5spd
    All pro Bumper and Armor SPC Control Arms King stock OEM RR X 4 Ironman 4X4 leafs Superbumps front #1500 sumosprings rear Sway bar delete Larger than average balls Lower than average intelligence
    Icon progressive add a leaf
    Mrbeer426 likes this.
  7. Jan 25, 2017 at 10:22 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Marie @HeadStrong Off-Road she is the best.
  8. Jan 26, 2017 at 3:47 AM
    Jeffrow20111
    Jeff
    Going to the dezert and some trails. I'm stock in the rear right now.
  9. Jan 26, 2017 at 3:49 AM
    Jeffrow20111
    Jeff
    Dezert and trails. Want something soft so not bouncing around a lot. Plus I do some highway driving every now and then.
  10. Jan 26, 2017 at 5:51 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    look into a deaver leaf pack. I ran those in a baja 1000 one year, and they preformed very well. nice soft ride and floats over chatter like bumps
  11. Jan 26, 2017 at 7:27 AM
    OZ-T
    Peter North
    British Columbia
    Dakars , not soft
  12. Jan 26, 2017 at 7:40 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Deaver or All Pro Standard.
    I run the all pros myself and they're perfect for what you're describing.
    The deaver springs give you 1-1.5" of lift, the all pro standards give 3" of lift.
  13. Jan 26, 2017 at 7:47 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    replaced the stock leafs with Dakar's and I am happy with them, but other than that I have not tried anything else yet.
    Jeffrow20111[OP] likes this.
  14. Jan 26, 2017 at 7:58 AM
    Jeffrow20111
    Jeff
    Not sure if I want 3" of lift in the rear. Thanks for the info thou. Gonna look up some deavers.
  15. Jan 26, 2017 at 8:07 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I run OME Dakars and to minimize lift, removed the third leaf.
    Slightly higher than stock, nice spring rate.
    Pairs nicely with Bilstein 5100.
    Should have been the factory setup.
  16. Jan 26, 2017 at 8:15 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    ^ also a great option :thumbsup:
    OP you could even contact companies like Alcan and have leaf springs custom made to your choosing.
  17. Jan 26, 2017 at 8:44 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I'm running Dakars with the 3rd leaf removed and Fox 2.0 rr. I purchased them from @HeadStrong Off-Road...great price and free shipping.
  18. Jan 26, 2017 at 9:38 AM
    Jeffrow20111
    Jeff
    How's the ride? Under $1k?
  19. Jan 26, 2017 at 9:38 AM
    Jeffrow20111
    Jeff
    How's the ride? On and off road?
  20. Jan 26, 2017 at 9:43 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    I've ridden in a couple trucks with dakars as they are, no leafs removed, they're actually not bad. Firmer than stock for sure but not rough. They have two overload leafs to prevent negative arch and better load carry capacity.
    As those two above stated, with a leaf removed it would lower the height a bit and yield a softer ride. They'd be a great choice as well.
    The leaf springs can be had for ~425 and shocks will vary depending on what you go with. Some Fox 2.0's can be had for 250-400 depending on reservoir or not. Just don't forget to add extended brake lines and u bolts.
    desertrunner24 likes this.
