Best H11 halogen replacement bulbs.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thegenerik1, Aug 25, 2018.
  1. Aug 25, 2018 at 8:41 AM
    Thegenerik1
    Thegenerik1 [OP] Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Thinking about swapping out from the stock to something a little brighter. Don’t think I want to go LED/HID. I’ve seen some members running the Phillips bulbs. I looked some up but quite a range of colors/brightness. Never upgraded headlights before so educate me.
    Let’s see some suggestions and hopefully some night pictures.
  2. Aug 25, 2018 at 9:09 AM
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    I did PIAA bulbs. I like em, but I only have 9500 miles on my truck so no info on longevity.
    Thegenerik1[OP] likes this.
  3. Aug 25, 2018 at 9:13 AM
    ANTupLIFE
    ANTupLIFE Well-Known Member
    Anthony
    Chester, VA
    '16 TRD Sport 4x4 DCLB SW
    I'll be honest with you. Don't waste your money on anything at the local parts store. Buy Philips WhiteVision bulbs. They last so much longer and do not yellow as quickly. The output for me has been better than the Ultras I had before.
  4. Aug 25, 2018 at 9:16 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    If you want to stay halogen but want much better lighting, do the H9 retrofit. The H9 is a much better bulb and it fits with a slight modification of the retention tabs on the bulb.
    tonered and Thegenerik1[OP] like this.
  5. Aug 25, 2018 at 9:38 AM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    I'm a fan of the Philips X-TremeVision bulbs myself. I've had way better life out of them than Silverstars in the past and they're on par for output.
  6. Aug 25, 2018 at 9:47 AM
    GF8er
    GF8er Well-Known Member
    MT. Hood
    18 MGM DCSB TRD OR 6MT
    Osram night breaker unlimited H11 halogen bulbs are pretty good also.
    Thegenerik1[OP] and ANTupLIFE like this.
  7. Aug 25, 2018 at 10:18 AM
    weezykid
    weezykid Well-Known Member
    2023 TRD OR DCSB 4wd
    I have run the Sylvania Silverstar Ultras in my previous 4runner and now my Taco. Have had great luck with them and they have lasted a long time for me.
  8. Aug 25, 2018 at 11:19 AM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    So it sounds like philips xtremes or sylvania silverstars are the favorites. Hoping for a some more night pictures of these. Obviously not expecting HID performance but for $30 why not make the stock lighting better.
  9. Aug 25, 2018 at 11:57 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    The Phillips are very good. Much better than stock. Won't last as long but easy to change out. Just make sure you don't get bulbs with the blue coating over the entire capsule. Sure, it's raises the Kelvin but also considerably lowers the lumens as well.
    I was curious about running H9's so I bought a couple (same bulb as your high beam), ground down the upper tab and installed just one. Now remember that the H9 is *basically* the same as an H11 but 65W vs 55W for the H11. So I had one Phillips H11 and on Phillips H9. Projected on my garage door and then measured with a Minolta Flashmeter 6 using the incidence metering mode in various areas of both beams and there was not a meaningful difference between the two. Everything within 1/10th of an f/stop between the two. I was pretty sure they looked the same visually but by actual measurement they really were. But the proof was driving back from Idyllwild last week at midnight on a dark mountain highway with no lighting: Those Phillips bulbs are more than adequate and they measure just over 3400 Kelvin on a Sekonic C700U color meter.
    This is what I bought: https://www.amazon.com/gp/product/B00BQWQN1Q/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    eurowner and Thegenerik1[OP] like this.
  10. Aug 25, 2018 at 1:14 PM
    choose for me
    choose for me Not Sure
    Northwest Florida
    2017 Toyota Tacoma TRDOR
    Flux Capacitor
    Sylvania Silverstar Ultras. Sylvania and Osram are or used to be part of the same company. I've also seem Osram stamped on PIAA, Hella, and Phillips bulbs, so at best, you're getting second-best from those brands. The Silverstar Ultras are the most luminous bulbs they make. The ZXEs have a nice color, but it comes at a cost to brightness and longevity due to the coating on the bulbs.
  11. Aug 25, 2018 at 8:42 PM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Interesting, most people have said the Phillips are better.
  12. Aug 26, 2018 at 4:30 AM
    choose for me
    Northwest Florida
    Flux Capacitor
    I'm not saying that all of Phillips' bulbs are made by Osram, nor am I suggesting that Phillips doesn't make a better, brighter bulb. The Ultras are the best bulb, in my opinion, that Sylvania makes, and I've never had one fail. Interesting side note, my factory bulbs were stamped with Osram, Made in Germany. Other than the color temp, the apparent brightness seemed nearly identical to the Ultras that I bought to replace them. Our factory headlights are very bright.
  13. Aug 26, 2018 at 5:37 AM
    Chasespeed
    Chasespeed Just a monkey with a wrench
    In the woods...
    2018 TRD OffRoad
    Some stuff
    I've used the SilverStars in the past, and haven't been disappointed.
    I haven't even driven my taco in the dark yet......
    I'm more concerned with trying to find a good selective yellow H11 for the foglights.....
    Chase
    Ck1010 likes this.
  14. Aug 26, 2018 at 5:51 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I used silverstars before in a previous vehicle. I don't think they lasted 6 months, one side failed about a month before the other. I also feel initially the output was better, but quickly faded. I definitely wasn't a fan.
    tonered likes this.
  15. Aug 26, 2018 at 6:17 AM
    choose for me
    Northwest Florida
    Flux Capacitor
    I went with Hella for my fog lights. They project a lower, wider, flat beam that does not bleed into my headlight beams. I can't swear that these are the exact ones as I'm not at home to verify, but it'll give you some idea.
    http://www.myhellalights.com/index.php/products/bulbs/optilux-xy-bulbs/
    I do question their durability, but I've had them for a year with no issues.
  16. Jul 3, 2019 at 4:00 PM
    xcmfz
    xcmfz New Member
    Ohio
    '16 TRD Offroad
    Nokya Hyper Yellow fog lights are my go to on all my vehicles. I’ve never had one fails and the yellow light it puts out is second to none, color wise.
  17. Jul 3, 2019 at 7:05 PM
    NevadaNick
    NevadaNick Well-Known Member
    2017 Access Cab 4wd 4cyl MT
    Philips became famous for making flashbulbs.
