Best fix for missing sliding rear window latch piece?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whttaco2whl, Aug 25, 2021.
  1. Aug 25, 2021 at 7:58 PM
    whttaco2whl
    whttaco2whl [OP] Well-Known Member
    KC
    North of LA
    2009 Tacoma base model, 2Whl 5Lug
    None
    The stationary piece that the sliding rear window latches too, is AWOL. Any proven fixes found here that I can copy ??
  2. Aug 25, 2021 at 8:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Key-Rei likes this.
  3. Aug 25, 2021 at 9:08 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  4. Aug 26, 2021 at 1:07 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    spitdog and dk_crew like this.
  5. Aug 26, 2021 at 6:09 AM
    whttaco2whl
    KC
    North of LA
    None
    I appreciate the replies, and that IS the simple answer I guess. Use the same method on the house sliding patio door track. The track bar is a very secure lock. But,….. I was actually wanting to be able to open and close using the OEM latch on to some replaced “target” catch similar to the one that got lost.
    If you reach over the back and open the window while riding like I do often, the Bar is an issue. The design is a weak point that’s for sure!
  6. Aug 26, 2021 at 6:54 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Install a power slider to the window.
    Self-locking, button on dash to open/close, no need to turn around to open/close.........
    Yeah, its not simple.
  7. Aug 26, 2021 at 7:03 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    3d print one?
  8. Aug 26, 2021 at 7:18 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    1/4" x 1/2" wood bar from shop... even shot it with black paint. Just an extra security measure.
  9. Aug 26, 2021 at 9:36 AM
    whttaco2whl
    KC
    North of LA
    None
    Likely will use the Track Blocker method in the evening. Simple and CHEAP!! Gotta wonder what Toyota was thinking? Do the Gen 3 trucks have the same latch issues?
  10. Aug 27, 2021 at 12:51 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Thats what i have . Did mod last fall . Use it all the time
  11. Aug 28, 2021 at 7:29 PM
    whttaco2whl
    KC
    North of LA
    None
    Easy Peezy,………
