Best dashcam
Discussion in 'General Tacoma Talk' started by johnnytwotimes, Mar 1, 2022.
  1. Mar 21, 2022 at 8:31 AM
    #41
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Ok, I've gotten and installed the Redtiger camera, installed the Ucam app, and I am happy as a clam. MUCH better than my old one.
    The only thing I had to overcome was creating a special clip to attach the rear camera to the headliner without drilling holes, but once I did everything worked immediately. Very happy with the results.
  2. Mar 21, 2022 at 8:39 AM
    #42
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    I have the Garmin Mini 2. Tiny, came with a cord long enough to run around the headliner/behind the glovebox/under the center console to the USB ports in the center console (I have a SR so no power in the mirror).
    It's not noticeable from outside
    Javman, erwigg, dagsom and 3 others like this.
  3. Mar 21, 2022 at 8:50 AM
    #43
    Ashgh
    Ashgh Well-Known Member
    Ashkan
    2021 Tacoma TRD Off-road
    The viofo A129 pro duo is a really good dash cam that a lot of people use and have great experience with. There’s a thread on Reddit all about dash cams you could check out called r/dashcam that has a lot of info.
    Taco_Coma and GrundleJuice like this.
  4. Mar 22, 2022 at 2:54 PM
    #44
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    I have this one and have been mostly happy with it.
    I was too lazy to hardware to get parking mode, so used an ODI adapter. That works pretty well unless the truck sits unused for ~48 hours, then It somehow cuts power to the camera (to save the battery) like it's supposed to. Problem is when i start the Truck... the camera won't come back on correctly and needs to be rebooted (via unplugging in).
  5. Mar 22, 2022 at 3:27 PM
    #45
    Asmara
    Asmara Active Member
    2021 Super White SR5 4X4
    Hard Tonneau cover, OEM power tailgate, retro accent stripes, tailgate accent letters, retro 4WD badge, Blackvue DR750X-2CH Plus, Spiker Hood Struts
    Well, there goes the weekend. I have a Blackvue 2 channel and a plex server. Time to pick up some software. Thanks for the tip!
  6. Apr 2, 2022 at 6:24 AM
    #46
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    How do you like it the Garmin Mini 2, does it work well? does it transfer to your phone or do you have to use a cable to the phone? Trying to buy one but research and first hand knowledge is great. So Thanks ahead of time for your comments.
  7. Apr 2, 2022 at 6:47 AM
    #47
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I have the same camera and use the Viofo factory hardwire harness. No problems like you describe. Is the "ODI" adapter the thing that plugs into the OBD diag port?
  8. Apr 2, 2022 at 7:32 AM
    #48
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
    I have been using a DDPAI Mini-3 for 2 1/2 years with no issues. Has a capacitor rather than battery so no overheating issues and also has 32gb storage built in. Video quality is excellent and uses smart phone app or pc with micro USB to transfer videos and snapshots. Had it hardwired in my 2019 and moved it to my 2021. Hard to beat for this price. They have a Mini-5 available now.
    https://www.amazon.com/Dashboard-Recorder-Storage-G-Sensor-Recording/dp/B07414XNVW?crid=61DUW247KLX&keywords=ddpai+dash+cam&qid=1648909587&sprefix=ddpai+dash+cam%2Caps%2C119&sr=8-4
  9. Apr 2, 2022 at 7:57 AM
    #49
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I have an older Blackvue DR750S-2CH with a Cellink Battery Pack. Parking mode lasts about 20 hours in Timelapse mode.
    In the spec sheet it says a 256gb SD Card is the max, but I have 512gb in it for the past 3 years that works just fine, which gives me about a 3 weeks worth of recordings. With the Blackvue Downloader mentioned above, all my recordings automatically backup into my NAS server.
    I have been pretty happy with my purchase, and plan to upgrade to the newer DR750X-3CH
  10. Apr 2, 2022 at 9:09 AM
    #50
    Tacoboutkewl
    Tacoboutkewl Well-Known Member
    Thanks for the link!
    thomasburk likes this.
  11. Apr 2, 2022 at 9:34 AM
    #51
    adrew
    Leer 100XR
    I like it - unobtrusive and basically don't notice it's there. I hit the button on it when someone screws up to save the clips, then look at the clips once every few months for amusement.
    There is an app that will wirelessly transfer the files into your phone, I think they also have paid online storage you can subscribe to. You can also take the SD card out and put it in a card reader. I do that sometimes if we are on a trip, like I will dump the files from the entire day into my laptop and then make a time-lapse.
  12. Apr 2, 2022 at 9:58 AM
    #52
    sikeitsryan
    sikeitsryan MidWestMTB
    MidWest
    '22 MGM SR 4x4
    Did you follow a guide for the install? Looking to do the same on my SR but I've never wired a camera like that before.
  13. Apr 2, 2022 at 10:15 AM
    #53
    adrew
    Leer 100XR
    No, I just started at the console, pushed the wire out of the hole, then fished it along behind the center console trim next to the seat, then up under the glovebox, out around the door trim, then tucked it behind the rubber, then behind the headliner, passing behind the mirror, then over to the camera.
    The trim on the side of the console is flexible and will pull out enough so that you can grab the cable to fish it through. Once you get it pulled up to the glove box area, just tuck it all in behind the trim. I probably need to put 1 or 2 zip ties on it behind the glove box because it will fall down every few months.
    Nothing fancy at all, but let me know if you need more info and I will take a few pictures.
  14. Apr 2, 2022 at 11:05 AM
    #54
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
  15. Apr 3, 2022 at 10:14 AM
    #55
    tomgru
    Thomas
    PNW
    2021 TRD Pro
    Yessir.
  16. Apr 3, 2022 at 10:24 AM
    #56
    JPTx
    JPTx Well-Known Member
    Jon
    East Texas
    2024 4Runner Off-Road
    Have a StreetGuardian SG9663DCPRO that I bought new December 2019.
    It's losing focus which apparently is a common issue due to heat or something. Only way to adjust the focus is open the camera and turn the lens slightly, which I'm not going to try.
    Probably try a BlackVue next.
  17. Apr 3, 2022 at 3:01 PM
    #57
    rainsux
    rainsux Well-Known Member
    2021 Tacoma Off Road
    None.
    I am very happy running Viofo A119 Gen 3 cameras front and rear.
  18. Apr 9, 2022 at 4:16 PM
    #58
    marcamos
    marcamos Well-Known Member
    Marc
    Beverly, Massachusetts
    2021 Off Road 6MT
    mrtonyd likes this.
  19. Apr 10, 2022 at 7:10 AM
    #59
    AwesomeLaw68
    Lawson
    Brand new.
    What is the percentage of tint added to the front windows to match the back windows?
  20. Apr 10, 2022 at 7:13 AM
    #60
    marcamos
    Marc
    2021 Off Road 6MT
    I wish I could tell you. When I went there, all I said to the installer was, “match the rears as much as possible without making it illegal (here in MA),” and he said, “Rodger that.”
