Best dashcam
Discussion in 'General Tacoma Talk' started by johnnytwotimes, Mar 1, 2022.
  1. Mar 1, 2022 at 12:16 PM
    johnnytwotimes
    johnnytwotimes [OP] Well-Known Member
    SoCAL
    2021 TRD OR DCSB
    Hello
    Looking to buy a dash cam currently interested in either the garmin tandem or garmin mini 2. Also does the dongle adapter work for tandem?
    shotgunbilly420 likes this.
  2. Mar 1, 2022 at 12:24 PM
    SeoulMan82
    SeoulMan82 Well-Known Member
    Michael
    Irvine
    '21 TRD Off-Road DCLB - Cement
    Edit: I don't see the Garmin tandem listed on their website but I don't see why it wouldn't work with the Dongar. I'd emailed them and ask. They are great with responding.
    I have the Garmin 57W with the Dongar Tech doohickey to plug directly into my rear view mirror. Camera works without issue and starts recording as soon as the truck is turned on. A buddy of mine has the Garmin mini and its a small little thing, but since there is no screen you'd have to view videos on your phone app to make sure its angled right.
    https://dongar.tech/products/garmin57kit
    Also, I bet you'll end up getting 15 different opinions as I know Blackvue, Rexing, Viofo, and many others make decent products. FYI, I only have a front facing 57W and have yet to add a second channel to record the rear of the truck, but I also don't do enough driving to justify that.
    Good luck in your search.
    johnnytwotimes[OP] likes this.
  3. Mar 1, 2022 at 12:26 PM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
  4. Mar 1, 2022 at 12:35 PM
    Tke226
    Tke226 Active Member
    2020 VooDoo Blue TRD offroad
    I have the Garmin Mini 1st Gen, its great. I use the Dongar connection and it keeps my windshield free of cables hanging all over.
  5. Mar 1, 2022 at 12:43 PM
    johnnytwotimes
    SoCAL
    2021 TRD OR DCSB
    It’s in there.
  6. Mar 1, 2022 at 12:46 PM
    howmuch4onerib
    howmuch4onerib i sure am hungry
    Marc
    Seattle
    '21TRDORDCSBLOLOMFGTLDRIDC
    The Garmin Mini 2 has worked great for me so far. :thumbsup:
  7. Mar 1, 2022 at 12:48 PM
    johnnytwotimes
    SoCAL
    2021 TRD OR DCSB
    How well does the constant power cable work (obd2 connector) really looking for something for thief protection and vandalism. Since the truck got broken into a month ago.
  8. Mar 1, 2022 at 12:54 PM
    SeoulMan82
    Michael
    Irvine
  9. Mar 1, 2022 at 12:54 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    i have a dongar and garmin mini, got them around april 2019. works fine, but only when the truck is on. i dont need to see the screen all the time, only if there is an incident. if there is i pull the card or download the video to my phone.
    if you want an always on camera, i thought you needed to hardwire it into something and cant use the dongar thing.
    JJ Diablo and johnnytwotimes[OP] like this.
  10. Mar 1, 2022 at 1:26 PM
    johnnytwotimes
    SoCAL
    2021 TRD OR DCSB
    Right I believe garmin makes a constant power cable to keep the camera always on when parked.
  11. Mar 1, 2022 at 1:30 PM
    CaptAmerica
    Cap
  12. Mar 1, 2022 at 2:04 PM
    johnnytwotimes
    SoCAL
    2021 TRD OR DCSB
  13. Mar 1, 2022 at 3:03 PM
    TacoWorldDan
    TacoWorldDan Well-Known Member
    2020 Toyota Tacoma SR5 DC V6 A/T
    If you’re looking for the “best” dashcam for protecting your truck from false claims I would steer away from Garmin and go with the BlackVue DR900X-2CH. If you’re going to hardwire a Garmin to record while parked you have to run a separate wire down to the fuse block regardless of having the adapter that hooks into the rear view mirror so might as well upgrade. I’ve been running the BlackVue for 2 years with zero issue and the quality is amazing, true 4K front camera and 1080p rear. It also has a battery cut off so if sitting recording for days on end of the battery drops to a certain voltage it will cut power so your truck always starts up and you don’t have to deal with a dead battery and jump starting. To use your phone you just get onto the BlackVue WiFi and easily view, edit, and download videos and can even access the cameras anytime if parked outside your house. I also installed a 128gb Samsung SD card and used tap a fuses into the driver kick panel fuse block. Install only required one trim piece to be removed, the driver A pillar and was one 10mm bolt. Link to the camera below, can’t recommend it enough.
    BlackVue DR900X-2CH with 32GB microSD Card | 4K UHD Cloud Dashcam | Built-in Wi-Fi, GPS, Parking Mode Voltage Monitor | LTE via Optional CM100 LTE Module https://www.amazon.com/dp/B08D99FZ29?_encoding=UTF8
  14. Mar 1, 2022 at 3:06 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    That dongle will work with the red tiger?
  15. Mar 1, 2022 at 8:34 PM
    CaptAmerica
    Cap
    All the dongle is a pass-through power tap on the mirror to a USB-A port. I have an 8” mini-usb cable running from that to my current camera. Done. No trying to snake wiring under trim from the OBD port or 12V adapter.
    mquibble[QUOTED] likes this.
  16. Mar 2, 2022 at 9:40 AM
    jrberry55
    jrberry55 Well-Known Member
  17. Mar 2, 2022 at 9:48 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have the tandem and the dongle I use hooks up to rear view mirror power
  18. Mar 2, 2022 at 10:19 AM
    deezyc
    deezyc Well-Known Member
    +1 for the Garmin Tandem!
  19. Mar 2, 2022 at 10:39 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Another non-Garmin option that I'm now running in two vehicles is the Nexar. It's a different take on the dash cam. Super high quality video with telemetry overlayed on the video. It links to your phone automatically via WiFi while your driving and streams through to the Cloud for free. Automatic stop and shut-off when you start and stop the vehicle. Detects high G impacts as well as hard braking events. It also has the Parking Feature where it sleeps but if it sees movement in front of the lens, that would include jiggling the car, it records the event and saves to stream to vehicle when your phone is in proximity.
    Cool feature is you can immediately quick edit a video from the phone and click an "Insurance" button and it will generate a video with all your pertinant info including telemetry, location, video, and with a push of the button, zips it off to an email or share as you like. I have the smaller unit called a "Beam" but I'm thinking of stepping up a notch just because. My preference is to hardwire it as I always have done with my Garmins...which I run in the rear facing position, now.
  20. Mar 2, 2022 at 1:09 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Do you have a link to the camera you are using?
