Best Dash Cam for Taco
Discussion in 'General Tacoma Talk' started by pandataco, Jan 24, 2018.
  1. Feb 11, 2018 at 12:35 PM
    #41
    pandataco
    pandataco [OP] Well-Known Member
    Los Angeles
    2015 DCSB Sport 4x4
    Thanks so much everyone, I got an installed the Rexing but...the quality is pretty bad I should have listened to @egres
    Anyway I am going to run it for a few days and see how it works before I decide if I should keep it or not. One thing that I can't really figure out is how to install the rear view camera.
    I put it above my slider but when I view it it shows too much of my bed lol. Since the resolution is so poor you can not read the license plate before it disappears from sight. I'm not really sure how I would run it to where the rearview camera should be(next to tailgate handle?). I would probably need to drill a hole and I am not confident I know how to weather proof the camera in that case.
    You guys all mount inside cab?
  2. Feb 11, 2018 at 3:27 PM
    #42
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    I mounted my rear camera inside the cab on the rear slider. I don't think they are ment to be mounted outside the cab.
    I wouldn't be to concerned with the rear camera being able to read license plates..... if they hit you you'll have to opportunity to write it down.
    Anyways i doesn't matter the which camera it is they aren't any better than the naked eye...but they are a unbiased recored of the events and really that is what you need it to do.
    https://youtu.be/0ii5Mffrn7U
    Armed in Utah likes this.
  3. Feb 11, 2018 at 3:32 PM
    #43
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Kool.......
    may have to look into one !
  4. Feb 11, 2018 at 3:41 PM
    #44
    Alder932
    Alder932 Well-Known Member
    B.C., Canada
    2013 Tacoma Limited
    I have a front facing webcam, but am wondering whether anyone has thoughts about how to set up a rear facing webcam when you have a canopy on the bed. The view through the rear cab window and then through the canopy is pretty dark, and I can’t imagine the cam image would be of any use. Thoughts anyone?
  5. Feb 11, 2018 at 3:51 PM
    #45
    pandataco
    Los Angeles
    2015 DCSB Sport 4x4
    You might need to wire it all the way to the back of the canopy. Is the canopy waterproof? If not you may want to forego the rearview camera :(
  6. Feb 11, 2018 at 5:15 PM
    #46
    Alder932
    B.C., Canada
    2013 Tacoma Limited
    It is a new Leer canopy and, so far, waterproof. Mounting in side the canop somehow does seem to be the only solution. Wiring it all the way to the front webcam would certainly be a challenge. And I wonder if the signal strength would be sufficient to take the image that far? Haven’t looked yet to see if there might be a wireless rear cam on the market. That might provide an answer; although likely to be wickedly expensive.
  7. Feb 11, 2018 at 5:31 PM
    #47
    pandataco
    Los Angeles
    2015 DCSB Sport 4x4
    Oooh my bad man, I thought when you said canopy you meant one of those fabric things. I think if you wire it that far through a hard top it'll be fine you just need to put some stoppers and maybe silicone it in use some metal tubing around your wire to prevent people messing with it and weather etc.
    As far as I know there is no wi fi for rear view dash cam. But idk, still trying to figure out my rexing lol.
  8. Feb 11, 2018 at 5:39 PM
    #48
    Alder932
    B.C., Canada
    2013 Tacoma Limited
    Sorry, yes, canopy in my part of Canada. Thanks for your thoughts and suggestions on this. Next step is to upgrade my webcam to dual camera setup from the bewildering selection out there.
  9. Mar 7, 2018 at 10:12 AM
    #49
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    Ok, here i go. Throwing monkey wrench, but it has to be done.
    I have bought Rexing v1 3rd gen. 4k.
    Tested it and wasn't impressed, so talk to bunch of russians because they experts on dashcams.
    They told me that most manufacturers are dishonest and use falls advertisement. Thay use software to enhance video to look better then hardware ( camera) filming it. For examples they can make 720 video look like 1080. And 1080p to 2k megapixel.
    They use things like video interpolation, in simple terms they generate missing pixels. So its like digitally stretching immage and smoothing it.
    For example, its like this:
    [​IMG] Original image
    [​IMG] STEP 1: Software stretches it but now has missing pixels
    [​IMG] STEP 2: Software fills in missing pixels buy guessing collor around it.
    So software enhance video but its dishonest for manufacturers to claim higher resolution.
    I will do more reading if Rexing v1 gen 3, is just same 1080p versions with better softe.
    On side note, OP buy better cam for front and use one you have for rear.
    To guy who said that you dont need see license plates in the back, you wrong. Theres plenty of instance when someone hits your rear bumper and take off. Because they drove off so fast, front one did not capture plate #. But rear one did.
    For those who want to melt your brain and learn more about interpolation:
    Start this video around 2 minuts mark: (i know its about tv but its about picture quality enhancement)
  10. Mar 7, 2018 at 10:20 AM
    #50
    egres
    DELCO PA
    For example, we just talked about Pruveeo F5. Weeks before it was sold as 720p camera. Now they removed that from title and in description put 1080p....
    They stretching video, hardware did not change.
  11. Mar 7, 2018 at 10:31 AM
    #51
    egres
    DELCO PA
    Not true, without battery, last file before power loss (aka accident footage) will not be saved, file fill be corrupted. EDIT: i was wrong because camera he's talking about has charge stored to save footage if power cut.
    For test, unplug you cam or take out sd card when its recording. Last file will not be there or will be unplayable. EDIT: I did this with rexing cam, and it did not safe.
  12. Mar 7, 2018 at 11:44 AM
    #52
    BEE-ROCK
    BEE-ROCK Well-Known Member
    Brock
    Dallas, TX
    2013 Tacoma TRD Sport
    TRD Pro Grille, TRD Pro Headlights, Bilstein 5100's and 5125’s.
  13. Mar 7, 2018 at 12:18 PM
    #53
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    I’ll throw in a vote for anything by BlackVue. I use the DR650-GW 2ch and love it. It has been replaced by a newer model. BlackVue cams aren’t cheap but they are good and last
  14. Mar 11, 2018 at 8:52 AM
    #54
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I have a BlackVue DR590 2 ch. in both cars, they just came out with a DR590W for WiFi.
    Bought mine from the Dashcam store, good customer service.
  15. Mar 11, 2018 at 9:00 AM
    #55
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    I bought a cheap one at Walmart a year ago and when the card fills up it quits. it is supposed to loop but does not?
    Do these better units reliably loop when set to do so? I need something that I do not have to fidgit with and reset and re-program while driving. Just set it once and go.
    J
  16. Mar 11, 2018 at 9:29 AM
    #56
    Sugar Silva
    Dave
    San Diego, CA
    Yes, my BlackVue reliably loops
    3X4X4[QUOTED] likes this.
  17. Mar 12, 2018 at 5:06 AM
    #57
    redz80
    Brampton, ON
    Yes the Thinkware f750 loops as it should. The only thing is that because it is writing over previous data is that it will tell you to formatt the memory card which is done with the dash cam. It only take 2 seconds to preform and off you go.
  18. Mar 13, 2018 at 8:32 PM
    #58
    pandataco
    Los Angeles
    2015 DCSB Sport 4x4
    I am glad everyone is sharing their experiences with these dash cams. It is so hard to get good information from reviews on Amazon and even from Youtube...
    How is the Anker @BEE-ROCK ? I love that brand I wish I had searched more and tried that one.
    Interested to hear how your dash cam works too @skatefreak282 !
    My Rexing has been working okay and the video quality is not great...but I mean I figure in the case that I really need it, it should do the job. Wiring for the rearview camera was pretty easy you just need to tuck it around all the trim around the ceiling of the cab and there is even a tiny channel above the rear window that is slightly wider and allows for easier camera placement.
    The one gripe I have is that the rearview camera is difficult to position. After some practice I can get it in place fairly quickly. However, there is a plastic tab attached to it with a sticker that allows you to 'mount'(adhere) it to something but since it is tucked between the ceiling material there is nothing to stick it to firmly. So pretty much after any car wash I have to readjust it and get the angle just right. You also see a lot of truck bed and not a lot of road...or cars/trucks/vehicles behind you...
    BEE-ROCK and skatefreak282 like this.
  19. Mar 14, 2018 at 6:00 AM
    #59
    BEE-ROCK
    Brock
    Dallas, TX
    I just installed it this weekend. So far it's working great! I will post some pictures when I get a chance. If I can I'll upload some example footage. Hopefully this evening! I made my own hardwire kit for the unit and the original USB cable was long enough to route through the headliner and down the drivers side A pillar.
    EDIT: Forgot to mention video quality. During the day it is excellent! You can read license plates very clear. Night time quality is also good. However, you can't read license plate numbers. Texas does have white and black plates. Light from your headlights seems to reflect bad off the plates. This makes it difficult for the camera to pickup on the tag number. I fully expected this though because even I have difficulty reading tag numbers at night.
    For the "hard wire" I used a cheap USB 12v charger. Took it apart and soldered wires to the leads. Then used heat shrink to cover everything up. I connected the wires I soldered to the charger, to a fuse tap behind the coin tray. Pluged the USB cable in from the camera and it works great. Ill try and get some pictures of that as well.
  20. Mar 19, 2018 at 7:29 AM
    #60
    amoreland42
    amoreland42 Member
    Alex
    2014 Silver 4x4 Base DCLB
    Pro Comp 7032 Mastercraft Courser AXT 265x75x16 LED exterior/interior Aries Bull Bar Black Nerf Bars
