Best coolant for intercooler ?
Discussion in 'Performance and Tuning' started by Bfz777, Apr 30, 2021.
  1. Apr 30, 2021 at 2:25 AM
    Bfz777
    Bfz777 [OP] Active Member
    Alistair
    Melbourne
    2009 hilux trd
    Haltech elite 2000, Bosch 1100cc injectors, turbo smart regulator, ceramic coated headers, 2.5 catless free flowing exhaust, rebuild engine kelford cam , kelford valve springs 460ls wilbro pump , rebuild auto with stage 2 valve body, gauges boost afr , 2.5 lift kit with over sized upper arms, trd cai.
    All,
    Have been suggested to use evans waterless coolant in intercooler , can you recommend and if someone has used evans let me know how it went
    Thanks Al
  2. Apr 30, 2021 at 2:34 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Coolant in your intercooler?
    Is this something I'm too naturally aspirated to understand?
    You have a liquid to air interface intercooler?
    Or are you talking about for a cooling mist sprayer onto the cooler?
    I genuinely can't say that I've seen an intercooler with it's own self contained recirculating coolant system so I'm rather curious about your setup.
    As for fluid, if this is a closed system I imagine it would be hard to beat distilled water and water wetter as far as thermal transfer goes.
    If this is for evaporative cooling I'd look at something like water/methanol or isopropyl alcohol perhaps if water's flash point isn't high enough.
    Either way interested in this thread just to learn.
  3. Apr 30, 2021 at 12:27 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I use toyota coolant in my s/c intercooler during the winter, and run straight distilled water during the summer
  4. Apr 30, 2021 at 12:28 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Yeah since when is there liquid in an intercooler
    Am I that outta the loop?
    Edit: :anonymous:
  5. Apr 30, 2021 at 1:09 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    That's exactly what the TRD/Magnuson SC uses. Small heat exchanger (intercooler) in the SC that cools the charge air, has its own reservoir and pump and an external radiator to dump heat to the outside air. Closed loop system.
    TVH475 and BassAckwards like this.
  6. Apr 30, 2021 at 9:14 PM
    Key-Rei
    Key
    Florida
    I thought the Magnuson was plumbed into the engine's coolant system which was one of the reasons it comes with an earlier opening thermostat?
    Didn't think it was self contained.
  7. Apr 30, 2021 at 9:59 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Nope, completely separate and self contained.
    I believe the thermostat stayed the same as stock (can't remember for sure), it just had a spacer for the thermostat housing and changes to the radiator hose to accommodate the SC.
  8. May 1, 2021 at 1:00 AM
    Key-Rei
    Key
    Florida
    Huh. Today I learned.
  9. May 2, 2021 at 2:16 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I use Toyota coolant with some purple ice. Purple ice seems to have much better reviews than Redline water wetter - has better corrosion protection.
    BassAckwards and TodayWasTHeDaY like this.
  10. Aug 17, 2021 at 3:01 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I use the Toyota pink stuff in the radiator. I use Prestone green in the intercooler. If I see pink on the ground, I know I have a coolant leak. If I see green on the ground, I know it is an intercooler leak.
  11. Aug 17, 2021 at 3:09 PM
    BassAckwards
    That’s a great idea
