Best CB Antenna Configuration?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SPORT, May 16, 2011.
  1. May 16, 2011 at 3:45 AM
    SPORT
    SPORT [OP] Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    As the title suggest, looking for what you all have found to be the best configuration for distance and clarity.
    Disclaimer, claiming a lot of ignorance here as I know very little about CB's
    My thought was to mount a long antenna to the rear bumper.
  2. May 16, 2011 at 4:14 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    Lrgrnr,
    Thanks
    I 'assumed' a longer antenna (which allows for longer wave length) would provide greater distance. As such the greatest length could be achieved by mounting the antenna at a lower fixed point; thus, the bumper mounting position.
    Also, any preferences for CB Units?
  3. May 16, 2011 at 4:21 AM
    jandrews
    '09 FourDubDee TRD OR
    The unit isn't what matters, it's the antenna. And you want a wilson roof-mount because there's almost no metal in the bed/bumper area, meaning grounding is less effective.
    The only downside to a roof mount antenna is drilling a hole in the roof of your vehicle. Not a big deal if you have patience and a steady hand with a drill.
  4. May 16, 2011 at 4:26 AM
    SPORT
    Rick
    TRD Off Road 4x4 V6
    Jandrews,
    Thanks.
    I'm in the process of buying and Off Road bumper from Brute Force, so there ought to be plenty of that conductive stuff. ;)
    However, it seems most here are sold on the roof mount, so I'll do a bit more research on it.
  5. May 16, 2011 at 5:01 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    What your after for optimum performance is a good ground plane.. this mean a large flat surface that completely surrounds the antenna, this allows the signal to radiate out in all directions..... thus the reason lots of us choose the roof.
  6. May 16, 2011 at 5:01 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    For your knowledge:)http://www.firestik.com/Tech_Docs/Bumper-mnts.htm
    http://signalengineering.com/ultimate/mobile_antennas.html
    Think of the ground plane as a launching pad for the radio waves.
    Now think of yourself as a radio wave, ready to bounce into the air.
    The roof of a vehicle is like a trampoline...
    A roof rack is like clotheslines.....
    Now which would work better to bounce from?
    It would take a lot of clothes lines to make a good trampoline.
    It would take a metal floor roof rack to make a good ground plane.
    Given all this, your two best mounts IMO are the roof, OR the front edge of your bed with #6 AWG groundwire (short as possible) to truck body.
    You can also get a bracket mount and do an install at the windshield end of the hood on the driver side. Your radiation pattern from that point will be directional but you still have a good groundplane.
    By the way don't forget that if you scroll to the bottom of your threadpage, you have several other related threads with more ideas and knowledge:)
  7. May 16, 2011 at 5:19 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Some rules of thumb with CB antennas are: Little antenna, little signal and the higher the better. Also do yourself a favor and don't skimp on the radio, you usually get what you pay for.
  8. May 16, 2011 at 5:24 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    :rolleyes::rolleyes:
    dont go by larrys people will never hear you:rolleyes::rolleyes::rolleyes:
  9. May 16, 2011 at 5:26 AM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    x2 i bought a shitty midland $50 radio and it sucked and fried instantly before i tuned my antenna. I got a cheapo cobra though and its mint. Also if you don't want to mount on the roof, firestik has like 90000 mounting options, check em out highly recommend. You could even mount over your hood or in your door jam, I personally have mine mounted on my tool box and have a 4 foot so that sticks over the cab and has the roof and the bed to bounce off and it works good, 100% tune your antenna though some people don't and pay the price like my self.
  10. May 16, 2011 at 8:21 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I permanently mounted a wilson lil wil roof mount which has worked great. I utilized the pre drilled hole in the roof (for satalite antenna)
  11. May 16, 2011 at 8:32 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Everyone is only talking "Ground Plane" Antennas.. Where do the "Non Ground Plane" Antennas stand here?
  12. May 16, 2011 at 8:33 AM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    I've seen a buddy mount a 6 or 7' whip between the bed and cab to the frame below. I know nothing about cb's but his sounds as clear as a radio talk show and gets some pretty good distance
  13. May 16, 2011 at 8:41 AM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    I have a 4' fiberglass firestik and it works pretty good, not too great for long range but if you're just using it for wheeling trips, mint.
  14. May 16, 2011 at 8:49 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
  15. May 16, 2011 at 9:06 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Go with a "roof mount" or "hood lip mount". I had a hood lip mount on my 05 Tacoma and I had a very good range. The most important thing is a good "ground plane" and a properly tuned antenna. Don't listen to the better radio BS. 4 Watts is the maximum tx allowed by the FCC. You aren't legally going to see a gain in performance between a cheap radio or a real expensive one.
  16. May 16, 2011 at 9:10 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    I've got the same thing, yet to install... Trying to find someone to make me a mount...
  17. May 16, 2011 at 9:51 AM
    JLink
    Josh
    Ocean, NJ
    What do you have in mind? Where do you want to mount it?
  18. May 16, 2011 at 9:54 AM
    kb1jop
    kb1jop kb1jop
    Rick
    Webster, MA
    2020 Magnetic Gray Metallic SR5 Double Cab
    Factory Towing Package OEM Bed Mat Hard Tonneau Tacoma All-Weather Floor Mats
    Agreed. The roof is definitely the best gound plane available. There's also another option which is the hood. There are mounts available for the front fender that attach inside the engine compartment. For example:
    http://www.pro-fit-intl.com/shopantenna.htm
  19. May 16, 2011 at 10:31 AM
    JayARRGHH
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    dude just get one from firestik, look on Amazon mine was like $5 i think.
  20. May 16, 2011 at 10:36 AM
    norcal4banger
    norcal4banger 11-98 MUD
    Jack
    Far Northern California
    2005 4 Cylinder 2WD 5 Lug RC Tacoma
    OP, I think you might already have the info needed, but just to tell you what I run is a uniden CB unit, (Best in my opinion and many others who I have spoke to) and a Wilson lil wil with the magnetic base on the center of my roof. Way better than the firestik knock off type antennas I believe.
