Best camper shell?
Discussion in 'Tonneau Covers, Caps and Shells' started by TacoTuesday1, Nov 21, 2021.
  1. Nov 24, 2021 at 7:38 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I will post pics when I get it. Should be any day now.
  2. Nov 25, 2021 at 6:59 AM
    mikeorav
    mikeorav Active Member
    Denver, CO
    2008 TRD Off-Road
    What kind of roof rack is that?
  3. Nov 25, 2021 at 7:27 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I went with a Leer 180 because I wanted the biggest opening in back for standing up garbage cans, big boxes, head room & furniture. I also didn't get the frameless door because that didn't fully flip up in back. Did AAL and get no sag fully loaded. No complaints.
    TheWildMan and Steves104x4 like this.
  4. Nov 25, 2021 at 7:32 AM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Nice setup too with the windoors
    Simon's Mom[QUOTED] likes this.
  5. Nov 25, 2021 at 7:43 AM
    Windmill Road
    Windmill Road Well-Known Member
    TX
    20’ White DCSB OR (MT) / 02’ Black AC SR5 (MT)
    Big fan of the RSI Smart Cap on my Tundra…running a camper on my Taco
  6. Nov 25, 2021 at 11:01 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Have an ARE Z Series.... in the 7 years I have owned it I have had to:
    Replace e-lock palm handle twice (on my 3rd)
    Replace gas shocks for back hatch
    Replace brake light
    Overall I like it, but the palm handle is definitely a bad design as it seems they only last a couple years. I have opened them up to find the solenoid is all rusty so water finds its way in and eventually causes failure. The brake light took about 5 years before I noticed condensation inside before it failed. Replaced it with one off of Amazon that had poor reviews saying that one immediately takes on condensation. Knowing this I put a bead of silicone around it and it has been solid for over a year. The gas shocks for the back I believe just failed due to normal use, they lasted 6ish years before the hatch stopped opening all the way. Replace those with exact fit amazon ones for 20 bux.... quality of the shell itself is really good, paint matches perfect, inside is carpet lined. Has tilt out rear windows, wish i would have gotten the windows that lift up like the rear hatch to make more accessible..... sorry for rambling, just offering my thoughts and opinions...good luck.
  7. Nov 25, 2021 at 1:53 PM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    only you can answer that question because it depends entirely on how you use your truck, whether you have a platform in back, dogs, if you plan to camp in the back, your budget, etc etc
    i picked up a leer commercial cap for a few hundred on CL w/ sidedoors on it and i've been very happy with it. Combined with a platform and drawers its been really handy
  8. Nov 26, 2021 at 5:52 AM
    SJBlack
    SJBlack Well-Known Member
    I have your bare bones ( side sliding windows w/screens, sliding front window) Ranch cap and it's fine. Never hear much about them but it does it's job.
  9. Nov 26, 2021 at 7:55 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I've had a few different canopies over the years, I hike/ski a lot in winter so they get put to the test when it comes to water intrusion.
    Any Leer with the "rain gutter" lip that hangs down over the bedsides will do pretty good against leaks between the bed rails and cap. I never had to get crazy with glue or sealer up near the front of the bed behind the cab.
    I have however, never seen a pop-up side window that didn't leak.
    Those flimsy thin aluminum canopies are cheap and simple but the sheet metal will crease and bend easily. Just having 4-6 inches of snow on the roof made mine crumple downward
    Never had a soft-top, i need to be able to lock up skiing gear safely
    My 100xr with windoor sliders poured water in around the seals and glass.
    I had a alu-cab that POURED water in through all the doors (sides and rear). The fancy latches would freeze in the snow and become unusable. By the time I got rid of it I was using a butter knife to pry them open when they froze. I guess it doesn't snow in south africa.. the only thing the Alucab does right is the strength to weight ratio. Very sturdy and far lighter than a fiberglass cap
    I'm currently waiting on a 100XQ from my local dealer. Those are the only ones I've seen that truly keep gear dry in the bed
    But again, I'm driving through rain and snow storms all winter going up into the mtns
    TheWildMan likes this.
  10. Nov 28, 2021 at 9:56 AM
    Airdreams
    Airdreams Well-Known Member
    Boise
    2005 access cab
    Softopper, 2022 TRD suspension, 2020 TRD Wheels, Pioneer stereo, K&N
    I've been running a soft-topper for a 1980s Toyota pickup... It does fit OK, but is not 100% waterproof. I get a little bit of leaking issues at the very front and rear corners. But again this is not made for the Tacoma. But Hey at less than a $100 I wasn't complaining.. Not to mention the fact that I had bought it already for a prior project. Anyway 4 bolts that clamp onto the rail is eat real and I can pop this thing off and carry it in one hand. When you're out running around and you find something you need to carry home, it folds down and allows you the space to carry things. The only thing I wish this one had was side windows.. I found 1 local to me and am thinking about going and getting it it's still going to be about a 400 mile trip, But it does have the side windows and is for a Tacoma... One other downside worth mentioning is that it's not really as secure as a hard top. If soyeah it's good if somebody wants whatever you have in the back, it is gone
  11. Nov 28, 2021 at 6:36 PM
    04TacoRunner
    04TacoRunner Toyota Junkie!
    CC TX
    Alu Cab is a nice option I bought mine before the price of them went crazy. They are super light and have a lot of options for building them out... IMG_0353.jpg
    TheWildMan, omegaman2 and dirtnsmores like this.
  12. Nov 29, 2021 at 7:04 AM
    acdubstaco
    acdubstaco Well-Known Member
    Adam
    NorCal
    2011 TRD OR
    It's a Prinsu Designs rack, they are awesome. A bit pricey in my opinion but I got this one second hand for a great deal. Makes securing things down a heck of a lot easier and they have holes on the side to put lights and stuff on.
    mikeorav[QUOTED] likes this.
  13. Nov 30, 2021 at 10:16 AM
    micah323
    micah323 Well-Known Member
    What shells are strong enough to have a rack on top with a rtt? I know the alucab and rsi are, but can you put that on the snugtop / leer/ or are models?
  14. Nov 30, 2021 at 3:34 PM
    Windmill Road
    TX
    ARE sells a model with reinforcement on the interior that will support a RTT, not certain of the others
  15. Dec 5, 2021 at 8:00 PM
    #35
    Windmill Road
    TX
    My favorite has been the Flippac, no longer made, but many similar options from AT, Vagabond, GF…. Most have a tall interior and double as a camper.
  16. Dec 5, 2021 at 8:11 PM
    #36
    Windmill Road
    TX
    The RSI on our Tundra has been good the short time we have had it; plenty strong, access on all sides. Have heard of latch issues in cold environments, but no issues for me so far
  17. Dec 5, 2021 at 8:22 PM
    #37
    PFL_Customs
    PFL_Customs Pulling pitch
    2019 Tacoma Off Road
    PFL Customs roof rack, Body Armor Hi-line bumper. X20 Gen 2 Smittybilt winch, PFL Customs bed rack. Dirt bound rack supports.
    The camper shell was my biggest decision, ultimately I wanted a half shell, but could not find one anywhere. So I made my own.
    The front section is a locking water tight storage, the rear section is molle panels. Has locking doors on both passenger and driver side, the rear wall can be removed so the whole bed length can be made available. Its heavy but comes apart in three pieces and I can take it on and off by my self in about 20 mins
    Have made several attachments for it including dog kennels and fold out kitchen.
    I wanted the half shell mainly cause when my roof top tent is on I wanted it below the roof line to save on gas mileage, I use this truck for work and lots of time that leads me to sleeping in remote locations in the rtt. I wish Someone with the capabilities would make a good half shell cause thisnwas a bigger job than I thought.
  18. Dec 5, 2021 at 8:24 PM
    #38
    Windmill Road
    TX
    Very Nice fabrication!
    PFL_Customs[QUOTED] likes this.
