Best Cab Mount Relocation kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by m shark, Oct 4, 2021.
  1. Oct 4, 2021 at 3:59 PM
    m shark
    m shark [OP] Well-Known Member
    Infinity QX-50, E46 M3
    Sig Taco likes this.
  2. Aug 22, 2023 at 6:36 PM
    TacoTuesday1
    FL
    did you ever figure this out
    DRT claims they're the best
    I see C4 came out with one that looks identical and seems more commonly sold with their larger 'high clearance splash shields kit'
    I think the difference is more clearance with CMR > CMC
    but much higher cost; was quoted $1k CMR out the door
    vs CMC you hear it being done for $300 all the time
    I know some people out there have gone through 2 or 3 CMC's, some even being very close to a CMR (before CMR existed) in effort to gain more clearance if they continue to get rubbing
    parts cost is different as well
    CMC plates, parts = $40
    CMR parts = $250+
    CMC may potentially be less and easier work for a fabricator to install
    the question is can you get away with just CMC, and will it work.
    I think that would be dependent on:
    -wheel offset
    -tire width, skinny 35 (10/10.5") vs wide (12/12.5")
    -alignment specs
    -suspension such as UCA, LCA pivots upgrade, etc.
  3. Aug 22, 2023 at 7:56 PM
    drtfabrication
    drtfabrication Well-Known Member
    Derik
    Ours is by far the best by fitment and overall quality standards. I’ve gotten photos of every other kit that’s out there all of which have fitment issues… TW users get 10% off also. Shoot me a message for the code.
  4. Aug 23, 2023 at 4:05 AM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    @m shark
    Interesting in knowing what you went with as well.
    I'm rubbing on reverse with CMC and considering CMR or 6" lift. Already at 4" lift but with .75" wheel spacers on 0" offset 4.75" bs wheels.
  5. Nov 1, 2023 at 10:44 AM
    cdoghump
    cdoghump Well-Known Member
    Amarillo, TX
    17' TRD OR DCSB 4x4
    Any new information on this subject?
  6. Nov 1, 2023 at 11:37 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I just installed the DRT relocation kit. Absolutely a solid kit. It moves the cab mount enough to fit 37" tires. Cutting off the factory cab mount is an absolute bitch and takes a lot of time to prep the frame for the mounting plate but once it was all tacked in place, burning in the mount was a breeze. I just moved the driver's side harness out of the way and put a heat sink on top of the frame to keep the heat from the harness.
  7. Nov 5, 2023 at 4:20 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    3 times I’ve had a customer provide a cab mount relocation from c4 and every time it doesn’t fit worth a damn. The plate doesn’t fit behind the mount so it requires a bunch of extra flap disc work to get their kit to fit correctly. I stock drt mounts so I welded one up and it fit like a glove against the frame.
    Another installer close by has had issues with c4 fitment aswell. I’ll be posting a video on my ig later showing the differences in fitment.
  8. Nov 6, 2023 at 6:46 AM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    I have had my DRT CMR for about 20k miles and have not had any issues. Quality and fit is amazing! I'm even getting ready to pull the trigger on their hammer hangers next. I will say do your home work and make sure you find a good reputable company to install it for you if you go that route.
    Also I'm pretty sure DRT Fab is a one man operation. I don't know if they hired more people but they really stand behind their work and have great customer support if you have any questions.
    drtfabrication likes this.
  9. Nov 6, 2023 at 7:06 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    DRT gets my vote
  10. Nov 6, 2023 at 7:28 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    DRT over here too!
  11. Mar 24, 2024 at 12:00 AM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    can you post a link up to the comparison? thanks!
    Bertw192 likes this.
  12. Mar 24, 2024 at 8:13 AM
    Timbo's Customs
    Timothy
    Lakeland FL
