Best Body Lift Kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by kwright47, Jan 30, 2012.
  1. Jan 30, 2012 at 1:34 PM
    kwright47
    kwright47 [OP] Member
    Kyle
    San Diego, CA
    1999 PreRunner Debadged
    Flowmaster 40 series exhaust
    What is the best body lift kit (moderately priced) for my taco? I have a 1999 prerunner with bilstein 5100's in the front. Spacers would work for me.
    Thanks!
  2. Jan 30, 2012 at 1:38 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    search here, someone found some custom 1 and 2 inch BL. I dont recommend either though
  3. Jan 30, 2012 at 1:41 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    None.
    Do a suspension lift!
  4. Jan 30, 2012 at 1:41 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i dont recommend any type of body/spacer lift.
    Dawdaw808 likes this.
  5. Jan 30, 2012 at 1:43 PM
    97yota4wd
    Eric
    Mesa, AZ
    Read Before you buy a spacer lift!
    Written on December 16, 2010 by admin in 00-06 Tundra, 05-11 Tacoma, 07-11 Tundra, 95-04 Tacoma, FJ Cruiser
    We get asked this question all the time. “Why are most spacer lifts be bad”? Well spacer lifts can cause a few problems and cost you big dollars to fix. First there are a few different kinds of spacer lifts, there is the kind that just bolts on the top of the existing shock that spaces it down to give lift. The problem that can come from running this kind of spacer is the shock will now be allowed to droop to far downward causing binding and damage to ball joints, 4×4 axle cv’s, and steering joints. The other issue you might have is since the shock is now just pushed down when you bottom out the suspension on or off-road instead of hitting the bumpstops you will just bottom out the shock. This can lead to some hefty damage. The next kind of spacer lift available are the preload spacers. These will usually cause the coil springs to be preloaded to give lift. The side effect to this type of lift is the shock valving is not designed for the extra preload of the spring giving the ride a bad bouncy feel that sometimes feels uncontrolled. And in some cases we have seen the spring coilbind causing damage to the shock and the frame. This is because the spring is designed to move about 1/2 its total length so when you pre-load them they are now compressed to much so near bottom out they will bind before you hit the bumpstops.
    Here are some pictures of some of the damage you can see with spacer lifts.
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    0 Comments - Leave a comment!
    2002Tacoma4x4 and Xbeaus like this.
  6. Jan 30, 2012 at 2:28 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    How big a lift are we talking? 97toyota got it right if we were speaking of spacer lifts, but we are talking about body lifts. Two different things.
    Body lifts are cheap, this makes them a great option for the uninformed buyer. But, they can take longer and usually more work to install with really no value add. If you are looking for an extra inch to clear a little bigger tire...sure, go for it. One inch is as high as I would ever concider with a body lift. Past that you really start to screw the structural integrity of the stock body mounting.
    Save money now and spend more later. This statement can be used for both body lifts and good suspension lifts(not to be confused with lift spacers).
    Save money by buying a cheaper option, and spend more down the road for repairs.
    OR
    Save your money now and spend more(but less than repairs) on a quality suspension lift later.
    Just mho here.
    jq1604 likes this.
  7. Jan 30, 2012 at 2:29 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    4 crawler 1"
  8. Jan 30, 2012 at 2:50 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    At the MOST 1''. Body lifts are junk.
    PLEASE tell me someone gets the reference....
    Tac0maSteve likes this.
  9. Jan 30, 2012 at 2:56 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    LOL! Water boy! Water sux, gatorade is better...
  10. Jan 30, 2012 at 2:56 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    :laugh:
    love that movie
    10trdtaco likes this.
  11. Jan 30, 2012 at 2:56 PM
    97yota4wd
    Eric
    Mesa, AZ
    water boy!
    edit: fuckers
  12. Jan 30, 2012 at 3:08 PM
    adt0423
    adt0423 Well-Known Member
    Alex
    Harrisonburg, VA
    1997 Tacoma 4x4 ext cab. 2021 TRD Off Road AG DCSB
    1997 - 2 in level kit, 31" tires, aluminum tool box.
    It seems like everyone around here has a 3 in body lift. thats just pretty standard for if you own a truck. Deff would recomend a suspencion lift though. its a more noticable lift. a suspencion lift will look more like the height your putting on.
  13. Jan 30, 2012 at 4:24 PM
    kwright47
    Kyle
    San Diego, CA
    I would agree that body lifts are not the right choice. I just got my 5100's installed and am just not fully satisfied. I like them a lot but I am still looking for more lift (mainly in the front). That is the reason why I asked about a spacer lift/body lift.
    stealthmode and Jon G like this.
  14. Jan 30, 2012 at 4:25 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    do you have the 5100's on stock coils set to 2.5?
    if you put some toytec coils on there you'd get closer to 3.5"
  15. Jan 30, 2012 at 4:49 PM
    TacoMX
    Jonathan
    Deltona, Florida
    spacer and body lifts are not the same thing. Spacer lifts refer to suspension spacers.
    and X2 on what your current setup is.
    And your right, a body lift is not the right choice. But adding a body lift to your truck because you dont like the way it looks is like wearing a toupee when you dont like your hair. Not the best solution and it looks like shit.
  16. Jan 30, 2012 at 5:38 PM
    livnlrn
    livnlrn Well-Known Member
    Rick
    Elkton, Virginia
    2009 TRD double cab
    I know no one on here likes body lifts, but its what ever u like. I have had a 3'' body lift on a 92 Yota for 15yrs. with no problems at all. I also totaled a 93 w/a 3'' body, & not one block was broke or moved. Id rather have a susp. lift over a body, but like I said, its what ever u like.
  17. Jan 30, 2012 at 5:39 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    How about a spindle lift since you have a prerunner
    stealthmode likes this.
  18. Jan 30, 2012 at 8:40 PM
    adt0423
    Alex
    Harrisonburg, VA
    Deff. agree with you livnlrn ^^ & reppin elkton thats aweome. your only like 20-30 mins down the road. Love seeing some really close locals on here :)
  19. Jan 30, 2012 at 8:41 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This is a trick question, since body lifts are junk, right?
  20. Jan 31, 2012 at 6:10 AM
    Afwrestler1986
    Johnstown, NY
    I went with the OME 3" kit and it looks good and works well. Are ypu planning on a winch bumper, if so the 5100s will have to go anyhow. like I said in my previous post, save up the money now and buy a quality lift later.
