Best battery replacement options for off roading?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TexDeuce, Nov 10, 2023.
  1. Nov 10, 2023 at 8:04 AM
    TexDeuce
    TexDeuce [OP] Member
    I was looking to get an AGM battery but doing some research there is a vocal group of people saying our Tacomas can't charge them properly.
    Is that real or BS?
    If it is real, I don't want to mess with doing anything special to a battery. Any other options brand/size for someone who off roads a lot?
    Thanks
  2. Nov 10, 2023 at 8:08 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Off-roading won't determine what battery you choose. If you camp a lot and deep cycle your starting battery, I would look into dual battery systems. Yes, AGM needs a higher charge voltage that you can change with a tune. Otherwise, I'm a fan of Deca and Interstate lead acid batteries.
    Bertw192 and Chew like this.
  3. Nov 10, 2023 at 8:13 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I've been running my Northstar AGM 27F for the last 4 years no issues, not a 3rd gen rig but I'd say you would be fine.
    TacoManOne likes this.
  4. Nov 10, 2023 at 8:19 AM
    Bishop84
    Bishop84 Well-Known Member
    AGM is better for off-roading in the sense they are sealed.
    lead acid standard batteries don’t like vibrations and bouncing. My last regular battery constantly leaked
    agm prefers higher voltage, so they typically sit more discharged when in a standard charging system. We just recommend charging it once a month or so if you remember.
  5. Nov 10, 2023 at 8:20 AM
    TexDeuce
    Why are there so many recommendations to get a AGM for people that are constantly vibrating and tipping to the side in their vehicles? Not questioning you just trying to educate myself thanks
  6. Nov 10, 2023 at 8:21 AM
    TexDeuce
    What happens if you don't charge your AGM battery in the Tacoma and just let it ride like a normal battery?
  7. Nov 10, 2023 at 8:21 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    It is not BS. Our smart alternators don't put out high enough voltage to fully charge an AGM. People run them without modifications/tunes but they aren't getting the full capacity out of the battery (assuming a deep cycle AGM). 2nd gens required a voltage booster that tricks the computer into cranking up the voltage from the alternator, 3rd gens have the option of a tune that ups the output voltage.
    The voltage booster made a BIG difference in my house batteries (I had a triple battery system).
    As for your need for an OFFROAD battery... that makes zero difference in what type of battery you want. If you want something with higher capacity (without dual battery), and deep cycling capabilities for a fridge or lots of lights, that is different.
    Chew and henryp like this.
  8. Nov 10, 2023 at 8:33 AM
    TexDeuce
    I'm not concerned with charging accessories. Just vibrations and excessive tipping of the battery when off road.
  9. Nov 10, 2023 at 8:33 AM
    Bishop84
    Decayed performance and storage. Suboptimal.
  10. Nov 10, 2023 at 8:40 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    There is a KDmax tune for AGM batteries. Works great for all the people who have had that tune option
  11. Nov 10, 2023 at 8:42 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I think you are over thinking this. A regular battery will do just fine IMHO.
    Chew, YF_Ryan and Kwikvette like this.
  12. Nov 10, 2023 at 8:46 AM
    YF_Ryan
    Kent, WA
    Yeah, a normal battery will do the job you want.
    Chew likes this.
  13. Nov 10, 2023 at 8:47 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I've had regular flooded batteries spill acid from the vents just transporting them a few city blocks in the footwell of a car. I strongly recommend an AGM sealed battery for off-road use. The flooded battery would still work after spilling acid, but your inner fender area may get heavily corroded.
    The white plastic tray under the battery is Toyota's solution to spilled acid...
    Canadian Caber likes this.
  14. Nov 10, 2023 at 8:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There are tons of actual wheeling rigs in the real world, shit boxes on 40s with an old Autozone battery that run laps all day long
    Way overthinking this
    Off-roading has been a thing for many years, it's not a new hobby
    Chew, gudujarlson[QUOTED] and YF_Ryan like this.
  15. Nov 10, 2023 at 9:03 AM
    airforceb2cc
    Don
    KCMO
    AGM is more for awkward mounting. If you need to mount it on its side or upside down, AGM is the way to go. If you will be rolling your truck often, yes, I would go AGM. But your engine will run out of oil before your lead acid battery spills all over itself in off-camber rock crawling and typical off-roading. I've never had an issue with lead acid when it comes to vibrations.
  16. Nov 10, 2023 at 9:05 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Get the 12v kind!
    Chew likes this.
  17. Nov 10, 2023 at 9:10 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It's maintenance either way.
    Flooded- towel off the top every time you pop the hood, clean and grease the terminals, and check the water levels once in a great while.
    AGM - check the charge once in a while, put it on a trickle whenever you have a quiet weekend.
    Off Road- I'll say the opposite of the campers. Go as small as light as possible. Stick with the 24F so that you don't stress the undersized tray that's in these vehicles.
    3JOH22A, Chew and RustyGreen like this.
  18. Nov 10, 2023 at 10:07 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    search for longest warranty and best price on standard drop in, and be done w it in less than an hour.
    It's funny how many seem to over think this, but many seem to wait until their battery dies before replacement.
    I just buy a name brand drop-in battery, and replace it a year sooner, rather than going with fancy shit.
    as mention- camping and such is a different story,, I am referring to stock battery for stock demands.
    Canadian Caber and Rock Lobster like this.
  19. Nov 10, 2023 at 10:18 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Good point. I replaced mine at the first slow start, which is far better than the first no-start. I got 5 years out of the stock battery, that ain't bad.
    Took it to the VatoZone, and not only did they take off the core charge, they offered to discount the AGM just because. And then they said "I know you have the tools to do it, but let me. It's a nice day outside and I need a break from the counter." Damn, can't say no to any of that.
    :cookiemonster:
    Canadian Caber and Chew[QUOTED] like this.
  20. Nov 10, 2023 at 10:23 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    ahh,,, the fake chrome fender vent capital of the world!
