Best battery for my tacoma
Discussion in 'Performance and Tuning' started by joshy523, Mar 3, 2010.
  1. Mar 3, 2010 at 9:47 PM
    joshy523
    joshy523 [OP] Well-Known Member
    Josh
    San Antonio TX
    2010 Magnetic Grey Metallic Off Road
    all around bilstens 5100 set on high, Satoshi grill, custom JL audio system, kenwood cd deck, Clifford alarm, weathertechs, custom light bar, k&n intake, super 40 flowmaster
    Im shopping around for a good battery. I will use it for my sound systerm and light and i need your opinion on a good brand
  2. Mar 3, 2010 at 9:57 PM
    Madchild
    Madchild Well-Known Member
    Bloomington MN
    Slim's HID, Tonnau Cover
    I've always used the Optima batteries.
    If you want a good sound system that will require a lot of juice. I suggest adding another battery. The optima are dry cell and you can mount them in any position.
  3. Mar 3, 2010 at 9:58 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Die Hard Platinum (Odyssey Battery)
    Rambo MARINE Recon likes this.
  4. Mar 4, 2010 at 7:14 AM
    godofspeed
    godofspeed Washington State.
    2010 4x4 TRD OR DC
    Body Armor front bumper Body Armor rear bumper 17x8.5 Method Bead Lock 35x12.50 Camburg LT Fox coilover All Pro 11 pack leaf Fox rear shock with DSC Allpro frame slider Smittybuilt 9500 winch Cobra CB w/firestick antenna. Hi-lift Smittybuilt air compressor
    I always used Optima, It never let me down.
  5. Nov 11, 2015 at 12:30 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    What is the best warranty, price and reliability of common house brand batteries?
    I have Autozone, Oreilys, Walmart, Pepboys, Carquest, Sears and Napa within minutes of me and I want to know who sells the best battery for the best price that includes a good warranty? I want an AGM type battery and only one in this list seems to offer a good value over other house AGM type batteries; the Oreilys Super Start Platinum. There seems to be a few different sizes, but I suspect that they all should fit right? 24F, 27F, 34, 34R, and 35. Are there any differences besides physical size? Will they all fit in factory trays with factory tie downs? Searching Carquest was a bit harder since they didn't show what batteries fit your vehicle so I found the closest they had in size and CCA. I broke it down into name, price, size, warranty, cold cranking amps (CCA), battery type. NAPA's warranty seems too good to be true. 75 months? Can anyone confirm that this is true?
    Autozone
    Duralast Gold - $127.99. 27F. 5 year warranty.
    710 CCA
    Duralast Platinum - $191.99. 24F. 3 year warranty. 710 CCA. AGM
    Oreilys
    Super Start Extreme - $121.99. 24F. 3 year warranty. 725 CCA
    Super Start Platinum - $159.99. 34R. 3 year warranty. 775 CCA. AGM
    Walmart
    EverStart Maxx - $104.97 (out of stock). 24F. 3 year warranty. 750 CCA
    Pepboys
    Bosch Premium - $129.99. 27F. 3 year warranty. 750 CCA
    Carquest
    Advanced Generation - $138.99. 34/78. 3 year warranty. 850 CCA
    Advanced Generation - $138.99. 24. 3 year warranty. 725 CCA
    Platinum - $199.99. 34/78. 1 year warranty. 775 CCA. AGM
    Sears
    Diehard Gold -
    $111.24. 27F. 3 year warranty. 825 CCA
    Diehard Gold -
    $124.59. 24F. 3 year warranty. 725 CCA
    Napa
    NAPA Legend 75 Month - $127.79 .27F. 6.25 year warranty.
    710 CCA
    NAPA Legend Premium - $220.49. 24F. 6.25 year warranty. 710 CCA. AGM
    Rambo MARINE Recon and Cmurder like this.
  6. Nov 27, 2015 at 8:09 AM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    optima yellow top.
    for reasons stated above and that it still produces 95% of brand new cranking amps after 6 yrs in a vehicle. i have them in 4 of my vehicles. never had a problem...in fact we had a manager at our local auto parts store knock a hole in one and put it into a customers vehicle and then start it just to prove they don't leak.
  7. Nov 27, 2015 at 8:27 AM
    Roneyj
    Roneyj Well-Known Member
    Chandler, AZ
    06 Tacoma/05 4Runner
    Keep in mind most if not all of these batteries are made by the same company, Johnson Controls. Also just because 2 batteries of different sizes have the same CCA rating does not mean the reserve capacity is the same. If you live in an area notorious for killing batteries (extreme hot or cold) then buy a battery based on warranty, customer service and multiple locations. Remember you may not be anywhere near a Sear when your battery dies but your are most likely not far from an Autozone.
  8. Nov 27, 2015 at 8:30 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Northstar AGM 27F
  9. Nov 27, 2015 at 12:45 PM
    beavis87
    El Paso
    '10 Silver TRD OR
    That Northstar looks like a good battery as good if not better than the Odyssey. Looks like it's a Canadian brand only and hard to find here.
