Best battery for a 8000LB winch that needs 650 CCA minimum?
Discussion in 'Technical Chat' started by KalamaKid, Oct 14, 2011.
  1. Oct 14, 2011 at 4:39 PM
    KalamaKid
    KalamaKid [OP] Well-Known Member
    Oregon
    same shit as everyone else
    :notsure:
    Yellow top Optima battery is almost $240 and only has a three year warranty. It also only has 620 CCA. What is a cheaper option with maybe a little better warranty? It has to be at least 650CCA and group type 35. Any help is appreciated. This battery is going to power an 8000lb winch without killing my truck.
    Just want to save a few bucks :eek:
  2. Oct 14, 2011 at 7:34 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Not sure whether you're a 1st or 2nd Gen, and I don't have a winch. I am, however, running an Interstate Mega-Tron Plus MTP-24F, which provides 1000 cranking amps (800 CCA). It came with an 85-month (30-month free replacement) warranty and cost about $100. :D
    thatprerunner likes this.
  3. Oct 14, 2011 at 7:56 PM
    KalamaKid
    Oregon
    2nd gen
  4. Oct 14, 2011 at 8:03 PM
    Norton
    According to Interstate's site, the MTP-24F is also applicable to most (all?) 2nd Gen Tacomas.
  5. Oct 15, 2011 at 11:45 AM
    KalamaKid
    Oregon
    Looks like a good battery but its not rated as a "deep cycle" battery
  6. Oct 15, 2011 at 12:09 PM
    Norton
    Didn't see that among your desired specs, and I've never needed it. :confused:
  7. Apr 3, 2012 at 6:55 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Please see Sections 7.1.8 and 7.1.9 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org for more information.
  8. Apr 3, 2012 at 8:37 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Some folks really like Odyssey Vehicle Batteries for heavy electrical winch use.
    Edit: Had battery name wrong at first. :anonymous:
  9. Apr 3, 2012 at 8:51 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    I don't have a winch but if I did I'd use Exide.
    http://www.rockcrawler.com/techreports/exide_orbital/index.htm
    "Weighing in at 41 pounds, the Orbital puts out 890 CCA (Cold Cranking Amps) at 32 degrees F and 700 CCA at 0 degrees F...........We wheeled quite a bit with the battery and even though it's not a deep cycle, we really put it through it's paces. We decided that if we were going to test it, we were going to use it! We made that battery winch us up long hills and it never gave up. Just a tap of the gas pedal here and there was all it needed to keep going. If that wasn't enough, we even welded with it. Again, it came back for more."
    Also...."Exide has brought out a new deep cycle model, so if you have room for a second battery to run your winch, welder, or lights off of, the deep cycle model provides 950 CCA at 32 degrees F and 750 CCA at 0 degrees F."
  10. Apr 3, 2012 at 9:05 AM
    Bryan139
    NJ
    '09 Sport
    Just a little fyi, maybe it will help you in your search.
    Exide's ORB78DT-108 is their version of Optima's red top. *108 month warranty
    The ORB34M-36 is their equivalent of the blue. *36 month warranty
    And the ORB34DC-36 is the Exide version of Optima's yellow top. *36 mo warranty
    Just throwing it out there
    Edit - these are all BCI group size 34, but going by the chart I think it'll still work.
    They don't look to be much less expensive though, maybe even more depending on where you look.
    This is an oldy, huh? A bunch coming back to life.
  11. Apr 3, 2012 at 9:25 AM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    I've seen a few guys running Odyssey batteries in their dual setups. Also saw a writeup on one in 4wd Toyota owner.
  12. Apr 8, 2012 at 6:41 AM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    If properly discharged, charged and maintained, Spiral Wound AGM batteries like Optima and Exide's Orbital and Flat Plate AGM batteries will last longer than wet lead-acid starting (car) batteries in high vibration applications like off-roading.
