Best all around lift kit
Discussion in 'Suspension' started by Strikersteve57, Nov 12, 2015.
  1. Nov 12, 2015 at 10:09 PM
    Strikersteve57
    Strikersteve57 [OP] Well-Known Member
    Stephen
    Memphis,Tn
    2013 spruce mica Trd off road Prerunner
    3" Toytec suspension lift, 285/75/16, grill guard
    i need help y'all I'm going to be getting 33's for my 2013 Tacoma double cab and I need to know what's the best lift kit or leveling kit to get and one that won't break the bank I'm looking at around 800-1000 bucks
  2. Nov 12, 2015 at 10:17 PM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    5100s all around with OME or eibach lift coils.
  3. Nov 12, 2015 at 10:26 PM
    Steener
    Steener Member
    Tyler
    Dallas, TX
    2013 DCSB SR5 Tacoma 4x4
    17" Ultra Gauntlet wheels, 285/70 Cooper Discoverer ATP tires, Spidertrax, Hertz Audio Sound System with two 8" subs, Black Clazzio seat covers, Bilstein 5100 front and back (Front set at .85), Eibach 1.6" coils, 2" AAL, Weathertech floor mats, UWS toolbox. There will be more thanks to this damn Forum!
    I have Bilstein 5100s front and back with the 1.6" Eibach coil springs in the front and a 2 inch AAL and have zero complaints. Rides better than stock and fits 33s. I bought the lift through Toyteclifts.com
    Kyle01 likes this.
  4. Nov 12, 2015 at 10:44 PM
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    5100s/ome struts paired with ome 885x with top plate spacer, 5100/ome struts with ome 887, 5100s paired with eibach all work well and will be within budget. Throw in spc (light racing) uca and either a 1.5"or 2" aal and it'll run about $900 more or less. STAY AWAY from SPACERS & BLOCKS. hit up @HeadStrong Off-Road, their prices are usually the cheapest :mudding:
    FJ to Taco and T4RFTMFW like this.
  5. Nov 12, 2015 at 10:46 PM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
  6. Jan 25, 2016 at 6:39 PM
    Strikersteve57
    Stephen
    Memphis,Tn
    Was this a complete kit or separate
  7. Jan 26, 2016 at 9:17 AM
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    Did you have to do any trimming? to fit 33s?
  8. Jan 26, 2016 at 2:24 PM
    Strikersteve57
    Stephen
    Memphis,Tn
    No I shouldn't have to I haven't done anything to it yet only thing I've don't is put a grill gaurd on it
  9. Jan 26, 2016 at 2:31 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    That's going to be highly dependent on the wheels and tires you end up selecting, not so much on the lift as long as you end up around 2.5-3".
  10. Jan 26, 2016 at 3:44 PM
    SilverSurfer
    Mark
    Los Angeles
    2013 4X4 LT
    Right now I have 265/70/17's lifting up to 2.5 so hopefully they dont look too skimpy. 285's in the future but might have to change out stock UCR arms?
  11. Jan 26, 2016 at 3:52 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    I like the look of the big tires, but I don't think it will look bad with that size of tire unless they are street tires...then it might.
    What wheels do you have or what wheels will you be running with the 285s?
    Also, the UCAs won't do much for fitting big tires. They wI'll likely have a small effect, but if you have the wrong backspacing on your wheels 285s wil rub the UCA regardless of what kind of UCAs you have.
  12. Jan 26, 2016 at 4:32 PM
    SilverSurfer
    Mark
    Los Angeles
    2013 4X4 LT
    Method double standards, currently running those with General Grabber at2 but want to go to Ko2's 285's
  13. Jan 26, 2016 at 4:36 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
  14. Jan 26, 2016 at 8:06 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    Should be fine then, on the tires rubbing the UCAs that is, just so long as the backspacing on them is around 4.5". You will probably have some trimming to do on the splash guard inside the bumper and possibly fenders though. Cab mounts too if you plan on wheeling hard.
  15. Jan 26, 2016 at 8:28 PM
    SilverSurfer
    Mark
    Los Angeles
    2013 4X4 LT
    Damn! I might have to go just 275/70's then, dont feel like trimming at the moment.
    Thanks for the info
  16. Jan 26, 2016 at 8:33 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    Yup. Best bet would be to scour the builds on here and find somebody with your wheels and the tires you want or tires with the same measurements. I'm sure somebody is running that setup because that's a popular wheel and tire.
    Maybe just start a thread, "anybody with method double standards and 285 ko2s?" Then ask what lift they have or if they trimmed! Boom
  17. Apr 20, 2016 at 3:35 PM
    Strikersteve57
    Stephen
    Memphis,Tn
    Update just got my Toytec 3" suspension lift put on today and I'm going to be getting nitto terra grappler g2 tires I'm getting a tire and rim package and the tire size is 305x60xr18 will they rub at all?
  18. Apr 20, 2016 at 3:44 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    I am a thinking yes, they almost certainly will. My 285/75/16s rubbed quite a bit with a 3" lift
  19. Apr 20, 2016 at 3:48 PM
    justinalldredge19
    justinalldredge19 Well-Known Member
    Justin
    Arab, Alabama
  20. Apr 20, 2016 at 3:49 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    More than likely, yes. People rub with 285/70r17 and this is a similar size. It's 0.3" shorter but 0.8" wider, which is fairly significant.
