Best aftermarket projector headlights??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lifesupport4u, Jan 31, 2020.
  1. Jan 31, 2020 at 6:58 PM
    lifesupport4u
    lifesupport4u [OP] Member
    Looking for some aftermarket headlights- want projectors ... don’t want halo or led bars.
    Anyone have any recommendations?
  2. Jan 31, 2020 at 7:01 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Not much besides shelling out a few hundred for a custom set. Most off the shelf headlights have poor quality projectors and are not sealed properly at times.
  3. Jan 31, 2020 at 7:05 PM
    lifesupport4u
    Where would I get a custom set or fix my cracked /yellow plastics that are beyond any scratch repair or polish
  4. Jan 31, 2020 at 7:06 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    @crashnburn80 has made a lot of threads regarding lighting on second gens
  5. Jan 31, 2020 at 8:44 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Any off the shelf aftermarket projector headlights will perform poorly and be poor quality. If you want a decent projector, use OEM grade in a custom headlight build. If you want HID, getting a retrofit with Lexus RX350 projectors with OEM HID components would be the way to go. If you are not up to building your own headlights, you will need to use a retrofitter service. The cost for decent setup will likely be around $1k or more. Might be worth asking why you want projectors, since large reflectors are actually more performant.
    This is a much more affordable high performance option using darker more aggressive looking smoked chrome OEM assemblies with high performance bulbs:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
  6. Jan 31, 2020 at 9:48 PM
    lifesupport4u
    Thought projectors would be better but if not fine to go with a regular housing. I thought I had read somewhere that 2011 oem headlamps are prone to yellowing and was hoping not to pay $400
  7. Jan 31, 2020 at 9:57 PM
    Waasheem
    Waasheem
    2007 xrunner
    Ditto.
    Someone else did tons of research there, thank goodness for Tacoma world and the ability to share one’s research and time.
  8. Jan 31, 2020 at 10:03 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You could always try and restore your existing assemblies, though it is tedious. The early OEM lamps had DRL yellowing, that was fixed in a design update with the later TSB lamps. If you get the updated model it is a non-issue.
    See post #1212 for a projector vs reflector comparison:
    https://www.tacomaworld.com/threads...ector-headlights.589465/page-61#post-20772143
  9. Jan 31, 2020 at 10:31 PM
    lifesupport4u
    Mine are beyond repair. Fronts are cracked, yellowed, scratched.... unless there is a clear plastic lens replacement for sale that can be assembled.
    Thanks, I will check out the comparison.
    Is part 4210 the smoke headlamp for 05-11? Looking at posts it’s not clear which part number is smoke v clear ?
  10. Jan 31, 2020 at 10:45 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The posts only reference the smoked chrome. Copy/paste from the headlight thread:
    OEM 2005-2011 smoked headlights:
    These are like the Pro lights, but came on select Sport models. These are the updated TSB version of the lights that do not have the melting DRL issue. TSB is available here.
    Right: 81110-04210
    Left: 81150-04210
  11. Feb 1, 2020 at 1:50 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Retrofits are legit. But pricey, my total set up was north of 550
  12. Feb 1, 2020 at 3:10 AM
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    That looks really good!
    I was in the same boat as the OP. My oem headlights were trashed. I decided to do a budget retrofit on a set of DEPO headlights and it came out pretty good with decent light output. I do wish i painted the reflector bowl though. I did mini h1 and rgb demon eyes.
  13. Feb 1, 2020 at 5:55 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    That looks awesome. I have the same set sitting in a box, and wasn't planning on doing anything more than installing them as is, but the light output on yours looks amazing.
    What's your setup (what parts were added/altered?), and what was involved in the install?
  14. Feb 1, 2020 at 9:21 AM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    I did a similar budget retrofit on my previous Tacoma, a 2005. I used the black Depo housings and Mini H1 kit too. Now I have a set of black Depo housings and a D2S waiting to be assembled. I think I spent like $350 on the ‘05 and maybe 400 on this one. So it can be done for definitely far less than a grand.
    the_black_tacoma likes this.
  15. Feb 1, 2020 at 2:04 PM
    10tacosr5
    All I used was was black housing depo headlights off ebay, I think I paid like $120. I went back and forth between wanting to use morimoto mini h1's, ended up not wanting to spend the money and started looking up reviews on Amazon mini h1s. Ended up getting Nilight 2.5" Mini H1 projectors for I think $50 for both Reviews were decent so I took a chance. You'll need a box of Butyl tape to reseal the headlights after your done also, that was $20 on ebay. And like I said I put the demon eyes in there, went with morimoto xbt controller and profile prism leds paid $118 on Ebay for them. Then all you need is a decent h1 hid kit and your good to go. For that I went with the retrofit source h1 harness and a innovited hid kit.
    It all started with the light output of the depo reflector bowls being horrible and me not being able to see anything. So I swapped the stock ones back in and built the retrofit out of the depot headlights.
    Babybluetaco and Fitz235 like this.
  16. Feb 1, 2020 at 2:44 PM
    Fitz235
    Rob
    New Hampshire
    Cool, thanks for the info.
    Looking at what's blacked out in the Depo's, I can see why the light output must suffer, like half of the reflective surface is black. They look cool as hell, but I was having second thoughts after I bought.
  17. Feb 6, 2020 at 1:17 PM
    lifesupport4u
    If I stick with the reflectors, what bulb do you think is best without upgrading the wiring harness? I would prefer a plug and play option that plugs right into my current wiring harness.
    I have bought some of the pricier bulbs from the local auto parts store and they don't seem to last very long before burning out.
  18. Feb 6, 2020 at 1:44 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Look at the output charts in the quoted thread, the data is in there. The harness is plug and play and very easy to install, it will boost the performance of all halogen bulbs.
    If you didn't want to use a harness and just wanted a bulb swap, in order of best low beam:
    1) IPF Fatboy X4 80w/60w H4s - 80w low beam for significantly improved performance, stock high beam. No blue coatings to hinder performance. The bulbs are expensive, and life is not documented.
    2) Philips Racing Vision +150 H4 - Stock wattage - much improved low beam performance, but reduced high beam performance due to a blue coating over the high beam filament.
    3) GE Xenon +120 H4 - Stock wattage - improved low beam performance but not to the level of Philips, however the high beam performance is not reduced as there are no blue coatings over the filaments.
    All performance halogens have shorter life than stock long life bulbs. The Racing Vision +150 bulbs look to be around 200 hours. Based on my use that is one year. But these are the highest performance bulbs, you can take a more balanced approach rather than choosing the most extreme performance models. For example the Philips Xtreme Vision +130 will be a good improvement in low beam output (but not match the +150s) and are rated at 450 hours, which should be good for about 2.25 years based on my use.
    If you bought them at an autoparts store in the US it is most likely Sylvania Silverstars. They are known to have very short life to the extent there was a class action lawsuit against them for mis-advertising the bulb life.
  19. Feb 6, 2020 at 1:46 PM
    bender85
    bender85 Active Member
    Dean
    New Hampshire
    2009 Red SR5 DCLB (RIP) 2017 Red TRD Sport DCLB
    Retrofit for the win. I used Depo headlights with DS2 Projectors and switchback Panamera shrouds. My came to a little under $500.
    MtnMan307 and TegoTaco like this.
  20. Feb 6, 2020 at 2:13 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    I did the exact same. Depo eBay lights. And a ni light projector kit
