Best aftermarket headlight Lens assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 737mechanic, May 25, 2022.
  1. May 25, 2022 at 7:08 PM
    737mechanic
    737mechanic [OP] Member
    Dallas Tx
    2011 Tacoma 4X4 Access Cab
    Need to replace the headlight lens assembly on the 2011 Tacoma. I want a pair that has a good reputation as far as not leaking water on the inside and not yellowing in a year.
    Does anyone have any recommendations?
    Thanks
  2. May 25, 2022 at 7:11 PM
    wudafxtht
    wudafxtht Member
    david
    2011 Double cab long bed 4x4
    The alpha Rex headlights are really nice if your willing to shell out the $$
    Pearson likes this.
  3. May 25, 2022 at 8:57 PM
    Ryman12233
    Ryman12233 Active Member
    2011 Tacoma Trd
    Camburg long travel And rear long travel List goes on
    I don’t have personal experience but my buddy loves the Amazon ones haha, never had an issue!
    ToyoTaco25 likes this.
  4. May 26, 2022 at 12:05 AM
    SomeGuy_GRM
    SomeGuy_GRM Well-Known Member
    2009 Tacoma SR5 TRD Off Road
    I just replaced mine with Spyder LED Halo lights. So far no complaints. OEM is probably better quality though, if you're that concerned about the housing.
  5. May 26, 2022 at 12:33 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    All the 100-150 aftermarkets will leak within a year or two - sealing the seam with aquarium grade silicon will help make them last. The lens is cheaper grade plastic so they will also scratch faster than OEM if you offroad on tighter trails with bushes/tree branches/sage. Some aftermarkets have a longer-term warranty you can buy thru like Allstate or others as base is like 90 days. Good luck.
  6. May 26, 2022 at 10:31 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    IMO it's better to refinish old lights than buy aftermarket. The only problem with the OEM lights is that they get hazy. But that's a fairly easy fix if you sand and spray with appropriate clear coat. A little bit of work but likely cheaper than new lights. Or fork over a little more and pay someone to refinish them for you.
    But above all, you must realize that ALL headlights, doesn't matter if they're OEM or aftermarket, ARE going to get hazy. UNLESS you make a concerted effort to prevent that from happening. You need to regularly apply wax or some sort of sealant (which are UV protectants) just like you do to the paint on your truck. If you don't protect your exterior surfaces and materials from UV then they WILL be degraded over time.
    And if the lights are actually damaged beyond what refinishing can fix then I'd buy used OEM before aftermarket, personally. New OEM would be best but obviously a bit pricy.
    12TRDTacoma likes this.
  7. May 26, 2022 at 10:44 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    I took a chance on some fleabay aftermarket ones and surprisingly they have held up quite well, no leaking & only starting to get hazy. I've had them a few years now.
    The bulbs suck tho, had to replace within a week. & the adjuster broke on the passenger side (luckily it was close enough). But for $100 to my door, I really can't complain.
  8. May 26, 2022 at 10:45 AM
    scoomas
    scoomas Well-Known Member
    Scott
    2006 Silver Tacoma TRD/OR
    retrofitted OEM housings will always be best
  9. May 26, 2022 at 1:01 PM
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    Better price Better product!
  10. May 26, 2022 at 7:18 PM
    737mechanic
    Dallas Tx
    Do you mean higher price better product?
    Amazon only has about 50 different manufacturers so that is a broad statement.
  11. May 26, 2022 at 7:25 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    OEM. No question
    clenkeit likes this.
  12. May 26, 2022 at 7:33 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Depo is the best after oem and alpharex are relabeled Chinese garbage. Just ask @crashnburn80 hes done multiple test with them showing how crappy there light output really is. Otherwise a proper retrofit led or hid projector are the best options I think.
    ace96 likes this.
  13. May 26, 2022 at 7:40 PM
    BlueT@com@4×4
    2015 TRD PRO Tacoma
