Best aftermarket Headlight housing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jack_reeves02, Dec 14, 2019.
  1. Dec 14, 2019 at 6:38 PM
    Jack_reeves02
    Jack_reeves02 [OP] New Member
    Jackson
    2013 Double cab TRD sport
    I’ve recently been looking into new headlights. My old boots had some how managed to rot, leaving my headlights with moisture. I’ve been looking on tacoma beast and like their halo projector lights. Any thoughts? I want something that’s gonna last and be reliable, but not looking to retrofit the stock headlights. Thanks
  2. Dec 14, 2019 at 6:43 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    the OEM stock are best maybe get new boots and rehab the lenses, aftermarket ones don't get high grades compared to the OEMs
    Norton and crashnburn80 like this.
  3. Dec 15, 2019 at 2:26 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    I've had good luck with depo brand. Granted I took them apart to retrofit, resealed them and used PPF on the lense
    freddy2923 and MtnMan307 like this.
  4. Dec 15, 2019 at 4:41 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    A few days ago, I started a similar topic. Some of the replies were helpful, some less helpful. Overall, the replies indicated stock is best, but considering cost of headlights themselves, and the ability to upgrade light output if desired, aftermarket seems a worthy choice too. Provided they are decent quality and I would believe DOT approved.
  5. Dec 15, 2019 at 5:14 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Two words: Lighting Forum and Search. (There are three kinds of people in this world. Those that can count and those that cannot.) This topic has been discussed quite often. In short, OEM is the best.
    BTW, If you want an education on automotive lighting, this might help:
    https://www.tacomaworld.com/threads/automotive-lighting-101.534393/
    ace96 likes this.
  6. Dec 15, 2019 at 9:23 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    My passenger side clear lens cracked. Anyhow I replaced them with ANZO from Rock Auto.
    https://www.rockauto.com/en/moreinfo.php?pk=8486612&cc=1445515&jsn=472
    I went with these because the lens is polycarbonate which is supposed to be more impact resistant, the down side is Polycarbonate is more susceptible to scratching.
    I'm not impressed with how they assembled into the stock mounting points nor the light output. Compared to stock light output, I think I the stock light out put over the ANZOs. I see no light output advantage over the stock OEMs. Rockauto list them as a performance item and the only performance benefit I see is the lens material. With this being my only experience with after market headlights, I'd say go with OEM.
  7. Dec 15, 2019 at 10:38 AM
    Too Stroked
    Tom
    I'm not 100% positive, but I believe the lens on the OEM housings is polycarbonate too.
  8. Dec 16, 2019 at 3:28 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Have searched the Lighting forum. Unfortunately, the information there typically reverts to oem is best but need to be modified.
    Not everyone is desiring additional light output or wants to retain oem lights.
    Pretty much each topic regarding Gen 2 early style lights avoided offering a good alternative, for an out of the box aftermarket headlight replacement that was acceptable.
    That said, the best legal lights with no mods are stock. Aftermarket legal lights based on others posts are junk out of the box.
    Not that I have plans to upgrade light output, but the topic I did read had the person using a non contact style digital temp gage and the additional heat from upgraded halogen bulbs was considerably more than oem.
    It would still be worthy to know, what headlights are a quality replacement for stock headlights at lower cost than oem.
  9. Dec 16, 2019 at 5:00 AM
    Too Stroked
    Tom
    I'm sorry if either I misled you or the other posts did not answer your question. Let me try to answer it directly.
    If you want to replace your stock / OEM headlight housings with something less expensive, you are guaranteed to take a performance hit. None of the aftermarket housings equal the OEM housings where it comes to light output / distribution, resistance to moisture intrusion or resistance to oxidation of the lens from the sun's rays. That said, if you're willing to take hits in those areas, the best you're going to find are CAPA Certified housings. CAPA Certified means that these parts meet the minimum requirements set by insurance companies for use a "crash repair parts." Unfortunately - and not surprisingly - you're going to find that the insurance companies don't care as much about quality, performance and longevity as the OEMs do. All they care about is (low) price.
    So I guess the big sticking point amongst those of us who are really into automotive lighting comes down to your statement "What headlights are a quality replacement for stock headlights at lower cost than oem?" And the answer is simply: None of the lower priced replacements even come close.
  10. Dec 16, 2019 at 8:52 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The issue here is optics and focus. The OEM lights have a high degree of engineering to ensure peak optical performance, which means less glare and higher intensity output. Aftermarket lights lack that level of engineering, especially those that completely change the style of the headlight, which are amount the worst performers. So while the products look the same, they do not perform the same. People seem happy with brands like Depo but that doesn’t mean it will at all compare to the performance of OEM. Checkout this great post below.
    Norton likes this.
