Best Aftermarket Fender Flares
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fatal_Paradox, Oct 26, 2018.
  1. Oct 26, 2018 at 11:57 AM
    Fatal_Paradox
    Fatal_Paradox [OP] Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    Okay I'm looking for some better fender flares for tire clearance. I have an 03 DC with factory fender flares. I wouldn't mine to just remove them, but of course the square holes. I like the Fiberwerx set for the front. It doesn't seem they have a rear option though. I don't like the riveted look at all so there goes the bushwhackers. Does anyone else know of any else taking suggestions for front or rear. Thanks. Here is a picture of my rear tire when stuffed in the wheel well. As you can see it rubs the back corner and is close to hitting everything else. IMG_20180707_175747742.jpg
  2. Oct 26, 2018 at 12:02 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
  3. Oct 26, 2018 at 12:03 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    OME ones with an angle grinder or dremel cutting tool :sawzall:
    There really aren't that many aftermarket flare options for us unless you want the Bushwhacker flares or the long travel fenders
  4. Oct 26, 2018 at 12:03 PM
    Fatal_Paradox
    Bardstown, KY
    @DashMaple Correct! But its the entire bed side.
  5. Oct 26, 2018 at 12:04 PM
    Fatal_Paradox
    Bardstown, KY
    @eon_blue Long travel flares... Please continue.
  6. Oct 26, 2018 at 12:04 PM
    DashMaple
    Louisiana
    Correct...I've only seen the bushwhackers, stock, and entire bedsides. You could just trim
    eon_blue likes this.
  7. Oct 26, 2018 at 12:05 PM
    DashMaple
    Louisiana
    Long travel being entire bedside like I linked
  8. Oct 26, 2018 at 12:05 PM
    eon_blue
    Azusa, CA
    DashMaple likes this.
  9. Oct 26, 2018 at 12:07 PM
    Fatal_Paradox
    Bardstown, KY
    yeah still more bedsides only though. So about the cutting. Im not opposed to it, but will it create an open hole?
  10. Oct 26, 2018 at 12:11 PM
    DashMaple
    Louisiana
    That is true, although for the rear unless you get a wider axle is going to look silly since LT doesnt widen the rear. I was planning on getting Methods with some offset and running spidertrax spacers then picking up some fiberglass bedsides since my have some dents.
    Also not to thread jack, but hows the light throw on the Hellas
  11. Oct 26, 2018 at 12:13 PM
    eon_blue
    Azusa, CA
    Light throw on them is okay, they're halogens so not usually as good as LEDs. I moved the halogens to point rearward and have 4 LEDs up front now instead.
    yeah I think some LT guys run wheel spacers in the rear to widen the rear stance, but to me it's most the front that looks 'off' if someone has the wide front LT flares and no LT suspension.
  12. Oct 26, 2018 at 12:26 PM
    2BeersPlease
    2BeersPlease Well-Known Member
  13. Oct 26, 2018 at 2:26 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Maybe. But nothing a small sheet of rubber or plastic couldn't cure. From the looks of the pic, it looks like it might be barely rubbing, so you shouldn't have to trim much.
  14. Oct 27, 2018 at 6:54 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Why not just get an axle relocation bracket? I think it will push your axle forward a little bit and you don't rub on the back part of the fender anymore.
  15. Oct 27, 2018 at 10:55 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Bushwacker makes the extended A fender flares which look very similar to oem ones.
  16. Oct 29, 2018 at 10:42 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Do you know what the coverage on the 01-04 OEM flares is? Feels to me like they are also about 1.5", so not sure the Bushwackers would be any different.
  17. Oct 29, 2018 at 12:23 PM
    Duvorak
    Duvorak Well-Known Member
    Rian
    WA
    2002 DC Tacoma Limited TRD
    Just stick with the factory ones man, you already have the bigger ones that come on are trucks, and they are on there way better then any aftermarket one that only mounts to the lip of the fender.
    So either trim some to fit, bump stop your travel(might save your springs life) or lift your truck some.
  18. Oct 29, 2018 at 12:24 PM
    Duvorak
    Rian
    WA
  19. Oct 29, 2018 at 5:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Idk what oem coverage is
