Best A/T or ALL Season tires for 285/65/18
Discussion in 'Wheels & Tires' started by sliptn, Nov 4, 2012.
  1. Nov 4, 2012 at 8:08 AM
    sliptn
    sliptn [OP] Member
    Idaho Falls
    09 Tacoma TRD Off-Road
    18" Rims, 285 65r 18
    Just bought me a 2009 Tacoma and need to get new tires. The tires size is a 285/65/18. I want a A/T tire but I really don't want to sacrifice MPG with the A/T.
    Any suggestions? What about All-Seasons? Any suggestions on All-Seasons vs. A/T's?
    Living in Idaho means lots of snow. That would be my main reason for getting the A/T's.
  2. Nov 4, 2012 at 8:09 AM
    mtwil9
    mtwil9 Well-Known Member
    Birmingham
    12 TRD Off Road 4x4
    Bilstein 5100 F&R Eibach at .85 with top plate spacer, 1.5 AAL,LR UCA's Tinted Windows, Weathertech Floormats, Ultra Gauge, 20" light bar behind grill
    BFG A/T or Goodyear Duratracs are the most common on here for A/T's
  3. Nov 4, 2012 at 8:10 AM
    2011whitetaco
    2011whitetaco Active Member
    Ontario, Canada
    '11 White SR5
    Duratracs. I've ahd them on every one of my trucks. Best tire for everything. Bit slippery in the wet but that makes them fun!
  4. Nov 4, 2012 at 8:12 AM
    sliptn
    sliptn [OP] Member
    Idaho Falls
    Are they heavy? Do they affect MPG much?
  5. Nov 4, 2012 at 9:09 AM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    I've got DuraTrac. They come in C and E load. Some complain the outer wall of the C load is not as strong as BFG. If you don't plan on hauling heavy loads or extreme off road you should be fine. C load is lighter than the E load and better for gas mileage.
  6. Nov 4, 2012 at 9:11 AM
    mtwil9
    Birmingham
    12 TRD Off Road 4x4
    they are some what heavy but your gonna get that with a bigger more aggressive tire. Im about to do 285's as well so im hoping it doesnt make my mpg awful but from what i have seen it will bring it down 1-2 mpg so not to bad.
  7. Nov 4, 2012 at 9:25 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Cooper Discoverer AT3
    Michelin MS2
    Hankook Dynapro ATM
    Nitto Terra Grappler
    Toyo Open Country AT
    BFG AT KO
    Goodyear Silent Armor
    General grabber AT2
    Bridgestone Dueller Revo 2
    Nokian Rotiiva AT
    and as mentioned above, Duratracs
    are all decent tires with good reviews. I tried to list ones that I know of that do well with lower rolling resistance/not that aggressive of an AT and also do well in the snow. Hope that helps for a good starting point for research for ya
  8. Nov 4, 2012 at 9:26 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Also, if you don't want to sacrifice MPGs try looking into narrower options for sizes as well as lighter weight load ratings (if you don't haul/tow much)
  9. Nov 4, 2012 at 9:42 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Narrower tires are going to be much better in the snow! here's a comparison on sizes.
    275/65/18: width 10.83
    height 32.07
    285/65/18: width 11.22
    height 32.59
    give or take .2 depending on tire tread.
    Wide tires will float in snow causing you to slip. Wide tires will be best for dirt, sand and mud. A narrower tire will hold better on ice and snow.
    I've had BFG A/T's and Grabber AT2's both good tires. I hear real good things about the duratrac's. They will be my next tire!!
    also.. stay away from all seasons!! Junk
  10. Nov 4, 2012 at 2:33 PM
    sliptn
    sliptn [OP] Member
    Idaho Falls
    Great info. Thank you guys.
  11. Nov 4, 2012 at 2:50 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
