Best 6x9 speakers?
Discussion in 'Audio & Video' started by Babybluetaco, Aug 18, 2019.
  1. Sep 1, 2019 at 6:37 PM
    #41
    Babybluetaco
    Babybluetaco [OP] Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    I’m still waiting for my damn adapters
  2. Sep 1, 2019 at 6:43 PM
    #42
    ReconMarine
    ReconMarine Well-Known Member
    Ed
    2019 White Tacoma TRD Sport
    After doing the math it was cheaper to go with Crutchfield. I needed to trim the rear brackets with wire cutters so the speaker fit properly. I used the ********* video on how to remove the door panels. They sound great. Thinking of getting an amp now. :)
  3. Sep 3, 2019 at 6:17 AM
    #43
    generalslee
    generalslee Member
    Stephen
    28704
    2016 TRD Sport DC LB 4x4 Silver Sky Metallic
    Nice find! I was more the opinion of, if you're going to upgrade it why not add some power behind it, too! But you're right, for the size of a truck cab, lower powered systems can sound just as good and for a fraction of the cost.
  4. Sep 4, 2019 at 5:04 PM
    #44
    Babybluetaco
    Austin
    09 5 lug
    Installed the Rockford fosgates today. Wow. They bump. Left the tweeters alone and this thing sounds amazing
    Rockoma5 and ReconMarine like this.
  5. Sep 4, 2019 at 5:28 PM
    #45
    ReconMarine
    Ed
    Yea I an happy with them as well. I went ahead and bought the Subaru dash speakers. They arrive tomorrow.
    Rockoma5 likes this.
  6. Sep 22, 2019 at 12:10 PM
    #46
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    It looks to me like your speaker mounting bracket is not installed correctly. I bet a ton of sound is/was getting trapped inside your door. Your speaker should stick out, not be inset into the door.
    You're looking for something like this:
    https://us.audison.eu/products/prima-ap690-woofer-speaker/
    Boghog1[QUOTED] likes this.
  7. Sep 22, 2019 at 12:25 PM
    #47
    Babybluetaco
    Austin
    09 5 lug
    I re did them when I put in the 6x9’s and mounted them the other way
  8. Sep 22, 2019 at 12:45 PM
    #48
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    No complaints here OP?:D
  9. Sep 22, 2019 at 12:50 PM
    #49
    Babybluetaco
    Austin
    09 5 lug
    All is well
  10. Sep 27, 2019 at 6:33 AM
    #50
    hotboatrod
    hotboatrod Well-Known Member
    Rod
    El Cajon
    1996 Tacoma 4X4 V6 auto
    2 1/2" front lift and bigger tires and wheels
    I don't know what fits yet.
  11. Sep 27, 2019 at 6:38 AM
    #51
    hotboatrod
    Rod
    El Cajon
    I'm going with Infinity reference as well. Lower impedance will give a higher db with the same input, a high efficiency rating will give a higher db regardless of what the marketing department claims, and the Infinity reference speakers I looked at start around 33 hz which is great for a 6x9. Sound deadening is a must with such a low frequency range. I'll probably install mine in custom sealed fiberglass enclosures as well. If I get energetic I might even play with porting, we'll see...
  12. Sep 27, 2019 at 6:44 AM
    #52
    hotboatrod
    Rod
    El Cajon
    What's a sail panel?
  13. Oct 2, 2019 at 10:13 AM
    #53
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    33.9269893 -118.0185768
    2012 DCLB 4x4 Trd Sport
    Shortened flowmaster exhaust with a turn down pipe, under cowl intake, throttle body spacer, train horn, underhood led lights, hood struts, dual 27f yellow tops. Led ditch lights, led front roof light bar, led fogs and headlights, behind grill mounted piaa dual color driving lights. Aux fuse and relay panel. Pro comp skid plate, bilstein 5100 leveling shocks on a 2in. lift, b110 rear 5100, add a leaf, front superbumps, light racing jounce rear bumpstops, sway bar relocation, brake line bracket extension, driveline carrier bearing drop, front diff drop, on board air compressor, 10 gal pump driven fresh water tank, cb radio, pioneer 4200 hu, infinity reference component front and component rear speakers powered by rockford fosgate 4 channel, jl audio 10TW3-D4 sub powered by kx800.1 amplifier. Big three upgrade, capacitor. Full cab sound deadening and thermal insulation. Led interior including added footwell, courtesy, cupholder, center console, and glovebox lighting, rock lights, bed lights, ring gear armor, under bed ammo can storage, pistol safe, body armor sliders, roof rack, hilift, 285/70 17 nitto rodge grapplers on american racing teflon atx, tailgate strut, and tailgate lock, retrofit projector headlights(home built), rgb halos inside turbine shrouds, black out surround, black chrome reflector and shroud, white halo outside shroud, white led drl, rgb behind grill on rf control. Mods followed from a TW thread: Anytime fogs Anytime rear view camera Anytime 400w inverter Alternating blinker/running lights 110v center console outlet ABS kill switch Engine kill switch (magnetic) 12volt bed socket Rear diff breather relocation Led bed lights Cargo net anchors Grid it center console top Grid it sun visor Locking center console Instrument cluster led swap Map lights on with dome Cigarette lighter add (shifter position) Dtrl kill switch Hilux lighted 4wd selector switch. Vios hvac knobs Hood scoop led bar
    I know this is a bit old but I have infinity reference component 6×9's up front and I used infinity primus 6.5 components in the back doors. Rockford fosgate 4ch amp for power. I've tried almost every speaker brand in my cars through out the years and always seem to like infinity the best for the money. I tell everyone that asks, infinity for the doors and jl audio for my sub is my go to. Heard focal, helix, morel, ct sound, ect. They sound great but out of my price range. Infinity seems to be the ticket for me. Just my opinion tho.
    subyguy and hotboatrod like this.
  14. Oct 2, 2019 at 2:13 PM
    #54
    hotboatrod
    Rod
    El Cajon
    I think your opinion is a good one. It doesn't sound like you compete in sound offs but are actually in the real world with real world expectations.
  15. Oct 2, 2019 at 7:54 PM
    #55
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    Thanks, but its more of a real world budget, lol. If I could I would go crazy on it. I agree with hotboatrod on the sound deadening. Its worth doing. I even did the lid, floor, back wall, everything but the pillars. Thats where all my money went lol.
    hotboatrod likes this.
  16. Oct 2, 2019 at 10:30 PM
    #56
    hotboatrod
    Rod
    El Cajon
    I did a crazy amount of sound deadening on 2 vehicles. A mid 90's 4 door Civic with an insane sound system I built and a 66 Chevelle bad ass AF had everything.... it can get expensive. Lol.
    A little bit can go a long way on large flatter panels, above mufflers/cats on the floor, behind speakers, and inside front kick panels/wheelwells. On some sedans a little will help on the rear wheel wells as well. Roofs and hoods are definitely in need but be cautious and go with a lighter deadoner and you don't have to cover the whole damn thing for a daily driver with average requirements.
    SamuelJ and Boghog1 like this.
  17. Oct 8, 2019 at 11:32 AM
    #57
    SamuelJ
    SamuelJ Darkhorse
    Samuel
    I did the lid and hood although it wasn't necessary. Your right about a lighter deadener, I used too much at first and had a hell of a time getting the headliner back in. Had to remove some to get it to fit. Overall all its probably one of the best improvements in sq.
  18. Oct 10, 2019 at 6:55 AM
    #58
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Which is better, 2 way or 3 way speakers?
  19. Oct 10, 2019 at 8:06 AM
    #59
    dolbytone
    South Carolina
    09 TRD Off Road
    2 way or 3 way, if both are well designed, it doesn't matter. The end result should be anechoic flat-ish. 3-Way may handle a little more power in most cases, but that's not true globally with comparables. Active systems are a different story, but mostly due to how much control you gain. It's possible to dick up an active system though.
    Bottom line: Neither is better.
    Rottencotton[QUOTED] likes this.
  20. Oct 10, 2019 at 8:33 AM
    #60
    Rottencotton
    Stinkin Rincon
