Best 2nd Gen aftermarket headlights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Okreutzfeldt, Jan 16, 2021.
  1. Jan 16, 2021 at 3:42 PM
    Okreutzfeldt
    Okreutzfeldt [OP] New Member
    Owen
    2005 black Tacoma TRD
    I’m just wondering what aftermarket headlights are best to get for my 2nd Gen Tacoma.
  2. Jan 16, 2021 at 3:51 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    I think my retrofits are about as good as you can get, from @kustom54lighting. I have no affiliation with them, just impressed with their work.
  3. Jan 16, 2021 at 3:53 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
  4. Jan 16, 2021 at 4:12 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I'll answer your question with the same question I always pose to folks asking your very question. Are you looking for looks or performance?
  5. Jan 16, 2021 at 6:30 PM
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    I have a set of kustom54’s and I love them.
  6. Jan 20, 2021 at 9:48 PM
    kustom54lighting
    kustom54lighting Well-Known Member Vendor
    Thank you for the shout out :)
    JoeTacoma02 and Boyk1182 like this.
  7. Jan 21, 2021 at 9:40 AM
    JR SLASH 33
    JR SLASH 33 Well-Known Member
    Josh
    Santa Barbara CA
    2010 Tacoma 2wd TRD Off Road
    Morel Virtus 603 3 Way Components in front JL RD900/5 5 Channel Amp in 3 Channel Bridged Mode (Front + Sub) Morel 6.5" Maximo Ultra Coax Speakers in Rear Doors JL MX280/4 4 Channel Amp in 2 Channel Bridged Mode (Rear) JL Stealthbox with 2 10" W1V3-4 Subwoofers Method Race Wheels 17x8.5" Baja Designs LED SAE Fog Lights GTR Lighting Ultra 2.0 LED Headlights
    Lighting Question:
    Recently "upgraded" my headlights to Alpharex Novas, love the style and looks, lighting is fair.
    The problem I'm having is, when I'm away (and haven't been in the truck for sometimes hours) the orange DRL will light up for a minute or so then turn off. I don't have an exact picture of it, but imagine the orange on, without the low beam.
    What issue could this be? Any input would be appreciated
  8. Jan 21, 2021 at 9:43 AM
    Boyk1182
    Northern Colorado
    Ground maybe?
  9. Jan 21, 2021 at 9:47 AM
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    I've got Kustom54 as well and really like them. I'm not a lighting guru and these are my first retrofit headlights. I got a very basic setup..no halos or anything and they still look good going almost 3 years now.
  10. Jan 21, 2021 at 10:31 AM
    Too Stroked
    Tom
    Maybe its just me, but I'm struggling with how "fair" output is an "upgrade." Any wall pics of the pattern?
    igno1tus and JR SLASH 33[QUOTED] like this.
  11. Jan 21, 2021 at 10:51 AM
    TheDuke427
    TheDuke427 Well-Known Member
    Los Angeles
    2014 TRD Sport DCSB 4x4
    Are you tapped into a fuse in the engine bay fuse box? Some fuses will get power every 4 hours or so for a minute.
    JR SLASH 33[QUOTED] likes this.
  12. Jan 21, 2021 at 11:48 AM
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    verynearlypure and Boyk1182 like this.
  13. Jan 21, 2021 at 11:49 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    if your tapped into the fl12 fuse it comes on every once in a while for 30 seconds.
  14. Jan 21, 2021 at 1:48 PM
    JR SLASH 33
    Josh
    Santa Barbara CA
    1st picture: Stock reflector housings with GTR Ultra 2.0 LED
    2nd picture: AlphaRex Nova
    both with fog lights off
    TRDSport10 likes this.
  15. Jan 21, 2021 at 2:11 PM
    Too Stroked
    Tom
    Well, it's an improvement over the OEM housings with drop in LED bulbs. What would be more interesting is to compare the new housings with OEM and halogen bulbs because they produce a much better pattern than the drop in LEDs.
    BTW, I think I see why the new units are only "fair." The hot spot(s) are way too low. This limits distance projection, but gives one the impression of better lighting due to all of the light being concentrated right in front of the truck. Common problem with aftermarket lights.
  16. Jan 21, 2021 at 2:16 PM
    JR SLASH 33
    Josh
    Santa Barbara CA
    https://youtu.be/vPhQPqA8VqM
    Skip to 8min 33 sec. these were the instructions I followed, and I used the same fuse location as him.
    I will try something else if you have another suggestion, I appreciate the comments.
  17. Jan 21, 2021 at 2:36 PM
    JR SLASH 33
    Josh
    Santa Barbara CA
    Correct they are very bright up close, long range projection could be better with the low beams, however when i can drive with high beams on, it's very impressive because the low beams stay on! so thats very nice
  18. Jan 21, 2021 at 2:41 PM
    TheDuke427
    Los Angeles
    I'm not 100%, but I'm pretty sure the fuse he's connecting to is the EFI 10A fuse, which makes sense that this is the one that gets power every 4 hours or so, even when the truck is off. I think your best bet is to try and find a different fuse location that isn't "hot" when the engine is off. I know there are some in the cabin fuse box for sure, not sure about the engine fuses.
  19. Jan 21, 2021 at 3:16 PM
    Too Stroked
    Tom
    Unfortunately, that's actually very bad for night distance vision. Your pupils adjust for the short range light and thus do not allow you to see further out. Said another way, it actually negates the high beams. Very bad.
    crashnburn80 likes this.
  20. Jan 21, 2021 at 4:28 PM
    JR SLASH 33
    Josh
    Santa Barbara CA
    these are the low+high beams, on the highway, they feel very effective. My choice to upgrade my lights was mostly for the sweet DRL, and aesthetics.
