Best 2" Shackle Hitch Kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by K Williams, Dec 3, 2022.
  1. Dec 3, 2022 at 11:20 AM
    K Williams
    K Williams [OP] Well-Known Member
    Long Island, NY
    2011 TRD Off Road V6 MT
    Banks Monster Exhaust URD Stage II Clutch
    What's the best 2" shackle hitch kit? Preferably one that uses a Crosby shackle. Thanks.
  2. Dec 3, 2022 at 11:23 AM
    K Williams
    Long Island, NY
    Can a moderator move this to the Recovery sub-forum? Thanks.
    AwesomeLaw68 and reallifedog like this.
  3. Dec 3, 2022 at 11:30 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    This is so useless! All you need is the tow strap and the hitch pin. Saves weight AND money!
  4. Dec 4, 2022 at 5:09 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I hope you're joking!
    Safety is paramount in recovery. A kg or so for a proper hitch shackle is nothing compared to the weight of the vehicle.
  5. Dec 4, 2022 at 5:29 AM
    jcott329
    jcott329 Well-Known Member
    Jordan
    Northern Mississippi
    2012 DCSB TRD OR
    I just bought the Factor 55 Hitchlink Pro 2.0… seems to be the best out there. It can be used with soft/steel shackles and is cross drilled for angled pulls as well.
    RelentlessFab and J Williams like this.
  6. Dec 4, 2022 at 11:00 PM
    Vinz Clortho
    Vinz Clortho Member
    Roseville, CA
    2011 TRD Off Road Double Cab Short Bed
  7. Dec 5, 2022 at 11:02 AM
    DG92071
    DG92071 Well-Known Member
  8. Dec 5, 2022 at 11:10 AM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    I have the Agency6 in my Amazon cart. Might become a stocking stuffer.
    Also good luck with the nylon strap and hitch pin method, that SOB is not coming out unless you cut the pin off after a good pull.
  9. Dec 5, 2022 at 11:13 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    Highway robbery, Walmart compensating for all the lost sales and the people who don't read the price.
    DG92071[QUOTED] likes this.
  10. Dec 5, 2022 at 12:01 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    More likely the same reason that same thing used to happen on Amazon & Ebay years ago... they had a metric that punished sellers for being out of stock on too many items. So instead of admitting to being out of stock, sellers would just raise the price to the moon. Cuz eff it, in the event some idiot does click the buy button, for 50x going price I'll shat one out if that's what it takes.
    DG92071 and jcott329 like this.
  11. Dec 6, 2022 at 11:56 AM
    jcott329
    Jordan
    2012 DCSB TRD OR
    HIGHLY recommend the Factor 55 stuff now that Ive put hands on it. I decided to get two Crosby steel shackles, 2 extreme duty soft shackles, locking hitch pins, strap wraps and the Hitchlink Pro 2.0. They even included the third party test results with each piece (Hitchlink Pro over 50,000 lbs). Also the locking stainless hitch pins are the best design Ive seen (threaded, o-ring sealed and dust cap). Not cheap but definitely a “buy one, cry once” product. Only problem is they look so nice I don’t want to use them right away… just stare at them and appreciate the craftsmanship :D
    goforbroke123 likes this.
  12. Dec 6, 2022 at 12:03 PM
    goforbroke123
    All kinds of toys.
    :cheers:
    jcott329 likes this.
  13. Dec 6, 2022 at 12:23 PM
    HoosierBuddy
    HoosierBuddy Well-Known Member
    Phil
    2012 Base Regular Cab 4WD Manual
    2" Lift
    I bought a D-ring and welded up one. The pic below was before I bought a hitch pin for it.
