Bent rear axle - what would you do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sworley, Jan 3, 2022.
  1. Jan 3, 2022 at 7:16 AM
    sworley
    sworley [OP] Well-Known Member
    Sam
    2021 Toyota Tacoma Limited, 1993 Toyota Supra
    Stock Toyota, baby
    Hi all, I bought a prior salvage 2015 Tacoma (was hit in rear) last summer and was told it was all repaired. It is not. It ate new Michelin rear tires in about 8,000 miles and handling can be twitchy as heck in some road conditions - scary. My buddy was following me the other weekend and he said I was crabwalking down the interstate.
    So, I've taken it to a frame guy and he corrected the frame but the rear axle is still bent. I was hoping to find a take off axle from a truck but if that's not readily available, do you imagine it would be several labor hours to swap over my guts and differential to a new axle housing? What would you do?
    https://parts.olathetoyota.com/oem-...9MjAxNSZ0PXByZS1ydW5uZXImZT0yLTdsLWw0LWdhcw==
    Thanks for any guidance.
    tacotoe and six5crèéd like this.
  2. Jan 3, 2022 at 7:19 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Find one in a junk yard that has been hit in the front end and just get the whole axle.
    jpy09, ColoradoTJ, maineah and 12 others like this.
  3. Jan 3, 2022 at 7:22 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    If it's bent get a used axle from a wrecking yard. Are you sure the pin that the axle sits in on the leaf spring is not broken and your axle is shifted a bit?
  4. Jan 3, 2022 at 7:23 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Im always skeptical when people say their rear axle is bent. How did you prove that?
    Id start simple - make sure the leaf spring centering pins are intact / not broken / located properly in the spring perch. If they are not, the axle will not be perfectly in line with the truck which will cause crab walking. Which is different than a 'bent axle'
    tirediron, Cudgel, toysrgood and 9 others like this.
  5. Jan 3, 2022 at 7:36 AM
    Pigpen
    Northwest Montana
    I agree with SR-71A
    The axle is more likely not seated correctly.
    SR-71A likes this.
  6. Jan 3, 2022 at 8:23 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I've got two trucks I've put back on the road after they were hit in the rear. One rear ended on the left/driver side and the other t-boned at the differential.
    So far you've gotten some wise advice about checking the centering pin which makes sure your differential is in the proper position.
    A differential and an axle are two different things. It is highly unlikely but not impossible that your differential is bent. Have you raised the truck to see if the wheel is wobbly as it turns? Is the rim straight? Swap a wheel from the front if it wobbles and check again. If it still has an uneven, side to side motion it is likely the axle is bent (not the dif). Axles are cheap and differentials are expensive. I'd expect to put a new bearing on an axle from a salvage yard but wouldn't do it until I'd run the axle and the bearing proved bad. Make sure the springs aren't bent, or the spring mounts.
    You are bound to get some negative opinions telling you a salvage vehicle is a bad buy, but I think just the opposite. People believe a lot of negativity if they don't have experience. All three of my vehicles are salvaged and have branded titles and they will go just as far during their time on the road as any other vehicle. I've seen people on this site that will absolutely ruin a brand new truck by replacing original parts with aftermarket mods, and my trucks do their job and keep on, keepin' on.
    You'll figure it out and be money ahead...
  7. Jan 3, 2022 at 8:28 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Axle's and axle housings are 2 different things.
  8. Jan 3, 2022 at 8:41 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    On a stock truck, the axle is way stronger than its attachments, so you'll want to make sure the leaf springs aren't deformed at the mounts, the shackle hangers aren't bent, the centering pins aren't sheared, etc.
    Have you gotten an alignment yet? Post the printout so we can see the rear camber and toe numbers.
    Complete axle assembles including differential and axle shafts are about $1000 from salvage yards, if it comes down to it.
    sworley[QUOTED][OP] and Travlr like this.
  9. Jan 3, 2022 at 11:40 AM
    sworley
    Sam
    Stock Toyota, baby
    Thank you all for the suggestions, I appreciate it! One tire shop I use performed a four-wheel alignment, or at least got specs for all four wheels. Only at a later trip, when I was having them mount two new rear tires, did they tell me my rear axle was bent. :mad:
    This is a reputable shop, I believe - I've been going there for years. I suspect they should know and would've looked at the centering pins. If not, how can I look them over? Pull them out and inspect?
    The frame alignment guy suggested a new rear axle when he was done, too.
    Alignment specs (after), damage photos and current photos can be found here: https://thecabe.com/forum/media/thumbnail_img_3220-jpg.40679/
  10. Jan 3, 2022 at 11:52 AM
    Travlr
    Middle'a Utah
    If your frame is straight and the alignment says you are aligned, then I'd be highly suspicious of a diagnosis of a bent differential housing. A bent housing would be very unusual and probably visually apparent. A kink/flat spot/broken casting in one side.
    Have you lifted the back end and run the wheels to look for a wobble?
    Again... the differential housing is not the same thing as an axle. There are two axles in the differential housing.
  11. Jan 3, 2022 at 12:29 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    First photo in the album had the VIN. Googling it turned up its auction listing. Looks like the rear axle was dislocated in the crash:
    and the repairs haven't put the axle back in its correct location. The RH wheelbase is a whole inch longer than the LH wheelbase. Page 516 of the owner's manual shows the factory wheelbase is 127.4 inch, give or take.
  12. Jan 3, 2022 at 1:05 PM
    Travlr
    Middle'a Utah
    Just like many places... these guys have no money/expense tied up in what they are telling you. If you do what they say it will probably fix the truck... but you will have put in a thousand dollar differential/axle (plus paid someone to do it?) when all you might have needed was a two dollar centering pin.
    To check out the pin you need to disconnect the differential from the leaf spring. Four nuts which hold with the u-bolts to keep the differential attached to the spring. Once they are loose you can jack up the spring while the dif hangs free. All you need is enough space to see if the pin has been sheared off. If you don't know what a pin looks like you can go to a local NAPA store and ask them to show you one. Check out Youtube, maybe.
    With the discrepancy in wheelbase it really looks like your centering pin is sheared off. TWO DOLLARS...
    You might want to check the other side, too.
  13. Jan 3, 2022 at 1:08 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    swap innards or find a good complete rear end salvage yard
    yotas get crunched everyday
    t boned
    headons
    got to be a rear axle around that aint tbent
  14. Jan 3, 2022 at 6:08 PM
    sworley
    Sam
    Stock Toyota, baby
    Thanks, all! I am excited to have this checked out and I feel a confidence this is the issue. I was thinking this issue would be my chance to sell and get into a ‘18+ third gen but now is not a good time anyway with these inflated prices.
    The old (new) tires wore only on the insides and cupping until the outsides, this hints at the theory of the axle being cocked to one side. There are also times where it feels like the axle “swings”. This could potentially be if there is no centering pin and the U joints aren’t tight enough to fully hold the axle? And the missing additional point allows for movement/play?
    I will take it into the shop this week and explicitly tell them to focus on my U joints and centering pins. I will report back. Thank you again for your help, everyone.
  15. Jan 3, 2022 at 6:40 PM
    Travlr
    Middle'a Utah
    U BOLTS... U bolts
    NOT u joints.
    Two different things...
  16. Jan 3, 2022 at 6:55 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    U bolts hold leaf springs to axles u joints allow your driveshaft to spin. Make sure you get your lingo right or the shop will be looking at the wrong thing.
    sworley[OP] and Travlr like this.
  17. Jan 3, 2022 at 7:19 PM
    Cryptictoy
    Cryptictoy Well-Known Member
    Esperance, N.Y
    Another thing to double check is if the frame has a diamond in it. You and someone else can verify fairly quick. Just pick a set of holes on bottom of rails and cross measure them . A diamond will cause the truck to dog track even if the center pin is good. You can also pull a measurement from one of the rectangle side holes to front spring bolt and then to the face of axle housing too for quick verification.
  18. Jan 4, 2022 at 8:29 AM
    SR-71A
    Zack
    Southern Maine
    It might be helpful for you to read through this PDF or something similar. This is from Icon and tells you how to install their RXT leaf pack. Obviously you aren't going to do that, but you can at least look at the pictures and get a better idea of what we are talking about, and how a leaf pack works.
    https://images.iconfigurators.app/pdf/I51101_REVB_7100.pdf
  19. Jan 11, 2022 at 5:06 PM
    Travlr
    Middle'a Utah
    So is there an update?
  20. Jan 11, 2022 at 5:22 PM
    sworley
    Sam
    Stock Toyota, baby
    Finally got an appointment for tomorrow. Fingers crossed it’s just the locating pin and a U bolt adjustment needed. We’ll see.
    Travlr likes this.
